Electrical problem maybe?
#31
Ok, maybe i should have also told you what his symptoms were just in case your technical German was not up to scratch;
Apart from the faulty generator repair ( Zam did not touch the battery during that time ) the bike started to splutter and the warning light came on, the rider was able to limp it into Zam's workshop with a "check engine" warning light.
That usually means there is a code "set" in the e.c.u. so Zam connected the healtech diagnostic software on his pc with an extended usb cable to the diagnostic connector on the Honda only to find out no code has been set but the battery voltage showed an unusual 13 volts without the engine running which is not possible, so then he went back to basics and did the very important visual inspection.
That is when he found the problem with the battery terminal bolt which was tight but too long for the thread inside the terminal, no amount of electrical testing would have pointed to this fault, it even started the bike many times, the battery and connections must be ok for that to happen, right?
In a previous job we had a Scottish electrical inspector checking all the switchboards we manufactured, one day he walked over to me and said " have a look at this, can you see what's wrong with this connection? "
Initially all looked ok to me until he pulled the cable out of the big crimp lug, it had been perfectly covered in heat-shrink but he spotted something did not look right, the two cables next to it were crimped normally but this one was not..........
He prevented a switchboard fire that day and all electrical tests showed no faults; experienceThumbs UpThumbs Up
Again, thank you, Max. My German may as well not exist and Google Translate does not work well on the spoken word. Sad
Update: Max, flipping the side stand up and down consistently returned 0.00v in the up position. I got no change jiggling the wires either. Next step: test ride.
Cheers Cormanus, looks like you were on the right track with that terminal.
Went for a most agreeable 70km ride in the late autumn sun. No electrical problem. Thanks all for your help. And generous instruction.
bacon
This outcome truly deserves a salute of sizzling bacon*.
*Vegetarians feel free to substitute chilled avocado.
Hi Max. I just wanted to say that you have always been a tremendous help to everybody on this forum. I know you sold your bike, but you continue to visit this incredible forum and provide expert advice to all. I just wanted to tell you thank you from ALL of the forum members, and I hope you continue to support us for a really, really long time.
Hear, hear. Except it was SportsterDoc who sold his bike, Dave. He’s just bought a Ryker though.
  CB1100 Idle speed instability problem ericlo69_imp 1,434 122,040 07-26-2026, 01:51 AM
  idle problem update 1973cb750 37 2,170 05-12-2026, 08:38 PM
Last Post: rdprdp01
  Chain or sprocket problem ? The Gecko_imp 14 1,341 07-30-2024, 10:05 AM
  O ring chain problem Mixagon_imp 7 683 10-17-2023, 07:28 AM
   Light problems/electrical Dude_imp 6 605 09-13-2023, 07:21 PM
Last Post: Dude_imp
  About the problem of high idling. (2014 cb1100ex) DDUMZI_imp 62 5,105 08-02-2023, 05:38 PM
Last Post: DDUMZI_imp
  May have a problem the Ferret 12 863 01-20-2023, 04:53 PM
Last Post: max
   2017 EX Headlight Dimmer Switch problem? sleeper_imp 24 1,953 10-08-2022, 12:27 PM
  Fast Idle Problem Solved Nachodaddy 17 1,565 10-08-2022, 09:18 AM
  Another High Idle Problem emptysea 60 4,321 07-05-2022, 11:41 AM
