How To :19 tooth front, and now, a 37 tooth rear sprocket on 2013
#31
had come with a 42/17
[Image: 71adf22657a83e012eb8ddba32c8f69f.JPG]
ROFL
I feel like the stock gearing on my 2013 is perfect. Then again, my 1982 CB750C turns at 5000 rpm at 60 MPH. I don't mind 3500 RPM after that.
Hikertoo, I can do bicycle sprockets too... Lol. I DoD a 26t skip tooth, which is a 52with ever other tooth removed.
(05-09-2015, 02:18 AM)ChipBeck_imp Wrote:
(05-08-2015, 11:53 PM)mustakoira_imp Wrote: I think I'm going to buy these and do this based on what I have read here. I too am often looking for the nonexistent 6th gear.
Chip, did you go with aluminum or steel?
Must,
Both the front and rear 7th Gear Designs sprockets are steel. The rear has beautifully machined slotted lightening holes so it's about 1/3 lighter than the stock rear. It really is a piece of art. I intentionally did my test rides 2 up to determine if 1st gear would be too high. I weigh 200 and Renea weighs 120 so I had 320 lbs on the bike and I started with a lot of stop & go riding. It only took a couple minutes to get use to launching from a stop with the new gears. Still the old gearing has a slight advantage there. Once underway there is a huge advantage in every gear. The CB1100 has a very wide torque/horsepower spread and the new sprockets have me in each gear longer. Even 2 up the CB pulls the 10.5% taller gearing effortlessly and the maddening high rpm, I gotta shift up, feeling at highway speeds is gone. Now the bike feels like it's in top gear and it feels right.
In 5th gear with the new sprockets your speed is almost exactly double the tach indication. 3000 rpm = 60 mph, 4000 rpm = 80 mph. I cruised on the highway at 65, 70, 75, 80, and 85 mph last night and it's so much better (calmer with less vibration) and more comfortable at every speed. But again the biggest benefit is that I wasn't constantly pulling in the clutch and trying to shift up to a higher gear that wasn't there because the engine is spinning way too fast and it felt wrong. Now it feels like it should feel going down the road.
A Honda design goal for this bike was "a relaxed ride". Perhaps in Japan with a maximum speed limit of 62 mph the stock gearing provided that but it never felt that way to me. Even at 60 I was always trying to shift up to calm things down. But at US speeds the stock gearing felt more frantic than relaxed. Honda acknowledged this when they added a 6th gear in 2014 and slowed top gear rpm down 20%.
In any event, this is one of the best mods IMO yet and it's a massive improvement on 2013 CB1100's. All the best.
Chip
Well I'm into day 5 of motorcycle #2 ownership and I'm already here. With so many others chiming in it can't just be coincidence. Motorcycle #1 is a '98 Triumph Thunderbird with a 885cc three cylinder engine. When the three carbs were out of sync it vibrated to hell and back. But did I test drive the 2013 CB1100 before I signed the dotted line? No. I owned a Honda Civic once and knew they had great craftsmanship. Even though it was used too. And I'm not really unhappy here Smile But geez what a mod to try out, and if it doesn't work out, I can always put back the old sprockets.
Thanks Chip, Peking and the rest here! New to the forum and will be ordering the sprockets soon!!
~CB1100
I'd like to do what the op did, and also have a set-up for the drag-strip to see what she'll do, as far as quickness!!
I started a new thread instead of a reply here because I didn't want to confuse doing this modification with questions the technical aspects of the data raised to me. My question has to do with the Tx gear ratios, .... I posted an image of the ratios in a table format and their algebraic relationships (ratios) - don't mean to get fancy. The new thread may be seen directly on the forum at http://cb1100forum.com/forum/showthread.php?tid=7304
A quick thank you to all contributors. I looked at this bike for two years and found a used cream puff with low miles. I was initially disappointed with the buzziness. If I hadn't read this thread prior to the test ride, I would not have purchased the CB1100.
I installed the front and rear sprockets after only 300 miles and absolutely love everything about the new gearing. It is hard to understand why it didn't come from the factory this way.
Thanks again CB1100 Forum!!
good deal Rod!
(11-10-2015, 02:13 AM)rodsmith123_imp Wrote: A quick thank you to all contributors. I looked at this bike for two years and found a used cream puff with low miles. I was initially disappointed with the buzziness. If I hadn't read this thread prior to the test ride, I would not have purchased the CB1100.
Rod,
I have a couple thousand miles with this new gearing and it is so much better. I'm glad it worked out for you as well.
Chip
  Rear indicator (Turn signal) relocation bracket 2013 model AndyBeeMD 15 1,519 08-16-2025, 05:01 PM
Last Post: bflint
  Chain and Sprocket Options? Yata-Garasu_imp 22 1,986 12-23-2024, 04:47 AM
  Chain or sprocket problem ? The Gecko_imp 14 1,217 07-30-2024, 10:05 AM
  Rear only tire on the front? mattmcuomo@yahoo.com 5 586 10-09-2023, 06:05 AM
  Front sprocket bolt cant be moved misterprofessionality 55 4,462 03-13-2023, 12:18 PM
  Front drive chain sprocket wear 1970Cadillac_imp 15 1,176 11-29-2022, 07:49 AM
  How to remove 2013 Rear ABS/Speed sensor danieljrmurray_imp 16 1,385 06-03-2022, 01:16 PM
  17 tooth CS sprocket install, comments. Bike #12_imp 11 955 01-03-2022, 08:30 AM
  Another chain and sprocket question bflint 20 1,485 10-13-2020, 01:00 PM
Last Post: tod.branko_imp
  Alloy Sprocket woes Ninemeister_imp 22 1,638 09-24-2020, 09:23 AM
Last Post: Ninemeister_imp
