Hum Coming From Gas Tank Area
#31
(06-29-2021, 10:00 AM)Lord Popgun_imp Wrote: Ok, I didn’t take a pic, but if you have one you can see it easily. Look below the right air cleaner cover. Below it is a little triangular frame piece. Below that and above the rear of the engine case is a space you can look into and see the canister.
At least Honda tried to hide it (well it appears).
The carbon canister rarely needs replacing, but you'd think Aprilia could try harder to disguise it ...
Mine does this too and it sounds like it is periodically circulating the fuel. It is electrical and definitely deliberate, if you time it you will find it is at perfectly timed intervals to a fraction of a second.
(06-24-2021, 04:50 AM)le_penseur_imp Wrote: Hi All,
Just received my 2017 EX yesterday. Will post some pics soon.
I noticed there's a periodic hum sound coming from the gas tank after shutting off the bike. Is this normal? I searched the forum and didn't see anything about it. It's sounds like a little pump or electric motor. I'm guessing it's the EVAP system, but I think it's been humming periodically all night since yesterday so why would it still be happening?
Thanks, any help is appreciated.
Salut Le Penseur
I am also hearing this hum coming from the gas tank every 30 seconds or so after I shut of the engine. I rode the bike today for about 45 minutes. Got home and put it in the garage on its stand and then started hearing this intermitten hum every 30 secnds or so. I have had my 2017 CB1100 EX for 10 months now and still does that. I always thought it was the fuel pump resetting itself but don't know if that is it. You say it is a solenoid?
Fred
It is the evap system rebalancing. There are no electric pumps running when the ignition key is removed.
(09-15-2023, 08:50 PM)GoldOxide_imp Wrote: It is the evap system rebalancing. There are no electric pumps running when the ignition key is removed.
^^ +1 ^^... and in internal combustion engines, there is no electric pump for EVAP system at all. Engine is EVAP's vacuum pump.
  Regina HPE chain-kit - looking forward to these coming in our size. Tev62 13 1,076 04-20-2021, 06:45 AM
  black spots cilinder head bolt cover area - sealing problem or nothing? Riko_imp 11 741 01-13-2016, 10:52 AM
  15k Mile Look See Coming Up Motogeezer1949_imp 4 431 10-12-2015, 09:01 PM
Last Post: Motogeezer1949_imp
  Clicking Noise from Rear Wheel Area Chapomis_imp 31 1,895 08-02-2015, 12:38 AM
  Replacing a '13 tank with '14 tank: is it possible? The_Last_of_Ben_imp 13 1,128 04-29-2015, 07:43 PM
Last Post: magic_imp
