black spots cilinder head bolt cover area - sealing problem or nothing?
Hmm,
did some riding in the city today, and after inspection I noticed what seems to be black spots on the right hand side cilinder head cover area, hard to describe so I encircled the spots in green:
I'll try to wipe it away as good as I can (its hot at the moment and quite far to reach) and keep an eye on it after a ride.
Does this look like a classic issue of a cilinder head cover not tightened enough to spec?
Cause when I google this small neglect, the leaks don't occur in that spot but rather on the outside on the top fins...but there its all dry..
http://cb1100forum.com/forum/showthread.php?tid=6564
What do you guys think?
Thx
Inspect less and ride more. LOL
2014 CB1100 DLX
2013 CB1100 Std
1990 BMW K75 RT
yeah I'm paranoia that way.
I think its false alarm Smile
Heck a lot of oil leaking and parts dropping off never stopped HD riders. Ride it until it fails.
2014 CB1100 DLX
2013 CB1100 Std
1990 BMW K75 RT
Take the tank off and re-torque the cover bolts... they will be about 90-95 inch / pounds but look up the torque spec. They often have to be torqued in a specific pattern for best seal.
I wouldn't worry, I'd call that a minor sweat, and not a leak. Just wipe and monitor, and if you desire re-torque the bolts as mentioned above.
It is nothing. Wipe it with a rag and ride the bike.
That would be the valve cover gasket right? The manual calls it a cylinder head cover, says torque to 10 Nm (7 lbf ft) in a crisscross pattern in 2 or 3 steps. If you have already had a valve adjust it is possible that is oil that just got squished out and not wiped down. If not, I would feel safe to just keep an eye on it and wait for the next valve adjust to correct it.
I understand your concern. I abhor leaks, even weepy leaks. Some times the wife with her smaller hands can get up into spots like this and work miracles.
You would have gone insane riding my 1964 Sportster. If it stopped leaking that was the time to get scared! I never see a drip on the garage floor under by Hondas or BMW.
2014 CB1100 DLX
2013 CB1100 Std
1990 BMW K75 RT
(01-03-2016, 03:20 AM)Elipten_imp Wrote: Inspect less and ride more. LOL
2014 CB1100 DLX
2013 CB1100 Std
1990 BMW K75 RT
(01-10-2016, 01:26 PM)Elipten_imp Wrote: You would have gone insane riding my 1964 Sportster. If it stopped leaking that was the time to get scared! I never see a drip on the garage floor under by Hondas or BMW.
2014 CB1100 DLX
2013 CB1100 Std
1990 BMW K75 RT
Like your style Elipten. Your Sportster is like my '61 Bonneville. It sits on a drip tray and I never bother with a complete oil change. I just add after every ride. It sounds better if I call it a Preventative Maintenance Continuous Lubrication Cycling System. And before the Oil Addicts start, let me remind them that bike was manufactured in '61 and is still going strong. I don't know how many miles the bike has done 'cause the bloke who sold it to me nearly thirty years ago was an unconscionable scoundrel, with a passing resemblance in both manner and accent to Arthur Daley*, who had wound the speedo back.
*Our British members will know Arthur. "A nice little earner" has since passed into the vernacular and, sadly, Arthur has since passed on.
  CB1100 Idle speed instability problem ericlo69_imp 1,434 119,529 07-26-2026, 01:51 AM
  idle problem update 1973cb750 37 2,145 05-12-2026, 08:38 PM
Last Post: rdprdp01
  Chain or sprocket problem ? The Gecko_imp 14 1,287 07-30-2024, 10:05 AM
  O ring chain problem Mixagon_imp 7 669 10-17-2023, 07:28 AM
  Hum Coming From Gas Tank Area le_penseur_imp 34 2,744 09-15-2023, 08:59 PM
  About the problem of high idling. (2014 cb1100ex) DDUMZI_imp 62 4,897 08-02-2023, 05:38 PM
Last Post: DDUMZI_imp
  Front sprocket bolt cant be moved misterprofessionality 55 4,611 03-13-2023, 12:18 PM
  May have a problem the Ferret 12 860 01-20-2023, 04:53 PM
Last Post: max
   2017 EX Headlight Dimmer Switch problem? sleeper_imp 24 1,918 10-08-2022, 12:27 PM
  Fast Idle Problem Solved Nachodaddy 17 1,520 10-08-2022, 09:18 AM
