New key won't work in ignition
#31
I found the spare key earlier this week. It appears my problem was the key wasn't cut to go deep enough into the ignition. I haven't been back to the dealer to have them fix the keys they made for me. I'm interested to find out why the keys weren't cut correctly.
(05-30-2014, 01:10 PM)jodyz_imp Wrote: I found the spare key earlier this week. It appears my problem was the key wasn't cut to go deep enough into the ignition. I haven't been back to the dealer to have them fix the keys they made for me. I'm interested to find out why the keys weren't cut correctly.
the blank must be clamped in the key machine so that the "shoulder" of the blank where she notches will end or maybe its the tip of the blank in this case is indexed perfectly at a "stop" which is part of the key cutter. If that stop is off or they have the clamping a little off, then the new key will bottom out on the lock plug(the part that turns) before the notches move the discs enough to let it turn. If they have an old key to copy then they can easily check this on the new key. Starting from just the code they didn't have the cutter and / or blank set up good enough.
(05-22-2014, 10:40 AM)Flynrider_imp Wrote:
(05-22-2014, 01:15 AM)AzBob_imp Wrote:
(05-21-2014, 03:14 PM)Elipten_imp Wrote: The tank and helmet lock suck big time! What a poor design. Other than the hard seat, it is the feature I hate the most. I. Will bet over 25% of users will bend the key when in the helmet lock.
How does one bend the key in the helmet lock? Insert key, turn... where's the bending? I've had no problem whatsoever with either the gas cap or the helmet lock.
I'll tell you how I did it. Put key in lock to take off the seat. Put bike on the centerstand. Key will bend against your leg as the bike moves up on the stand. I almost bent a second one just by walking close to the left side while the key was still in the lock.
Easily avoided by always taking the key out of the lock after using it.
I was probably the first one here to bend a key this way, but at least a few others have done it since.
D'oh! I have OCD and can't leave the key in the helmet/seat lock because it's just too juicy a target for whacking against accidentally. As soon as the seat is off, the key comes out. Next step is after that. Sometimes OCD is a good thing. :-)
Lol AzBob I have OCD also! And the older I get the worst it gets lol. Does that mean I'm normal? Smile most
of us CB owners are OCD. WITH all these mods and farkles we are something lol
I'm just catching up with this thread.
I used the helmet lock for the first time the other day and had a devil of a time with the long key. What a PITA!!
I have a Helmet Guardian that I may install behind the licence plate and works well. I also have a Helmetlok device so have options other than that fiddly helmet lock.
I think it must be hit or miss. I have a harder time getting the key to start entering the ignition cylinder than I do with the tank or lock.
Same here shdwghst. It's caused by a bent key. Try your other key
  Key won’t go to ignition Presasx2_imp 17 1,378 09-27-2023, 07:49 PM
  International Ride To Work Day emptysea 22 2,675 06-16-2020, 05:08 AM
  Malfunctioning ignition lock geosar_imp 25 2,051 02-01-2019, 11:41 PM
  Frequent/occasional difficulty inserting key in ignition? jerrycon_imp 23 1,601 10-15-2017, 07:57 PM
Last Post: Rocky_imp
  June 19, 2017 - International Ride to Work Day emptysea 30 1,872 06-19-2017, 12:35 PM
Last Post: Ole
  Might be able to use my bike for work! ryanschillinger_imp 10 723 03-25-2016, 12:29 AM
Last Post: ryanschillinger_imp
  One advantage to riding to work... Guth_imp 8 608 01-16-2016, 01:16 AM
  Traveling for Work Nemo_imp 3 311 01-14-2016, 08:25 AM
Last Post: kmoney_imp
  What Warranty Work Have You Had Done? Motogeezer1949_imp 25 1,587 09-23-2015, 12:30 AM
Last Post: johnnyj_imp
  Warranty Work johnnyj_imp 7 653 09-14-2015, 01:47 PM
Last Post: CBXBob_imp
