Thinking about a wider rear tire
FUZZY_imp Offline
Threads: 18
RE: Thinking about a wider rear tire
My service manager said going up 1 size is all that's recommended. When I wear this one out that's what I'll do.
07-26-2013, 01:08 PM
Randy B Offline
Palm Bay, Florida USA
Threads: 85
Likes Given: 133
(07-26-2013, 12:19 PM)Jim21680_imp Wrote: This probably isn't true, but I would hope any good service shop would refuse to mount a 180 tire on a 4" rim. I wouldn't even risk a 160. Now, if going to a 150 gave me better or more diverse tire options, that's definitely something I would consider (sadly, it doesn't Sad ). But I would be really weary about going over a +10 on the tire width. Good luck to you Sil, keep us posted about what you decide, and how it works out.
Think about this and then take a good look at TOO MANY of the imports running around on wheels and tires that shouldn't even be in the same zip code with one another, let alone mounted to each other and then postulate the chances of someone mounting the incorrect tire on a too narrow/wide of a rim for it. There are stupid people out there and unfortunately they walk among us.
07-26-2013, 02:46 PM
silascopathic_imp Offline
Threads: 28
Thanks for looking out for me guys. There is a bunch i do not know about tires obviously.
(07-26-2013, 01:08 PM)FUZZY_imp Wrote: My service manager said going up 1 size is all that's recommended. When I wear this one out that's what I'll do.
I may do exactly this when it's time to change
07-26-2013, 10:09 PM
2013 CBXX_imp Offline
Threads: 0
I have a BT-45 Radial 150/70/R18 and it fit perfectly.
not much more room to clear the swing arm pivot
but plenty around fender. Would not go any wider.
07-27-2013, 02:36 PM
The Spaceman_imp Offline
Threads: 42
Two of the reviews I read on the CB commented on how flickable the bike is with these tire sizes compared to supersports with 180/200s. I noticed in a few hundred miles that I had no "chicken strips" on the rear, and very narrow ones up front. That's tough to do in South Florida....the land of flat and straight roads.
07-27-2013, 09:25 PM
wildezt_imp Offline
Threads: 9
#26
150 is the max one should go IMHO , anymore and the bike would lose its aesthetic appeal on what it should reflect..apart from all the technicalities around it... Going too wide would change the statement the bike makes, but hey everybody has their own statement to convey as well ... Big Grin.. Beauty always lies in the eye of the beholder...
07-27-2013, 09:59 PM
CB4ME_imp Offline
Threads: 183
#27
(07-27-2013, 09:25 PM)The Spaceman_imp Wrote: Two of the reviews I read on the CB commented on how flickable the bike is with these tire sizes compared to supersports with 180/200s. I noticed in a few hundred miles that I had no "chicken strips" on the rear, and very narrow ones up front. That's tough to do in South Florida....the land of flat and straight roads.
Spaceman,
That's pretty good. I still have close to 3/8" wide chicken strips on the front, and I got them that "small" by playing around in parking lots.
I used to grind down the peg feelers on my Bonneville, but that was kid's play. I don't think I've come close or ever will come close to touching peg feelers on the CB.
07-27-2013, 10:01 PM
yetanotherGerman_imp Offline
Threads: 0
#28
A 160/60-18 rear tyre is officially recommended by Bridgestone in Germany as a possible replacement of the original 140/70-18 BT54.
Note the 160 is a /60(per cent of the width) whilst the 140 is a /70 so the outer diameter will be similar.
They have two different versions of sport touring tyres (brand new Battlax T30 and few years old BT-023 model) which can also be combined.
See the pdf here, sorry the text is in German but the basics (standard rims and tyre sizes) are clear anyway: http://moto.bridgestone.de/~/media/Files..._SC65.ashx
11-07-2013, 12:50 AM
ingobohn_imp Offline
Threads: 2
#29
I would not recommend to use wider rear tires, you simply lose too much agility. And that's what I basically like at the CB 1100: it is a compact and very agile bike.
EDIT:
The problem here in Germany is that you have not much choice of tires for your CB 1100 (if you do not go for wider ones):
- Dunlop Sportmax D205 (one of the two stock tires)
- Bridgestone BT54 (the other one - but very old tire model)
- Pirelli Sport Demon
When my tires are used up, I will first try the Bridgestone tires. Unfortunately, my bike was shipped with Dunlops, and as far as I understood these tires are worse compared to the Bridgestones.
11-07-2013, 01:44 AM
Threads: 0
#30
You could also consider the classic BT 45 as it is available in the right dimensions. It is however NOT recommended by Bridgestone, so you'd run on your own risk.
11-07-2013, 02:00 AM
  Wider handlebars, Tracker style. JLEECB 18 1,904 05-16-2021, 09:31 PM
Last Post: Zee9_imp
  Thinking of a new gadget... Csory_imp 296 19,325 07-14-2020, 12:06 AM
  Goldwing Rider Pegs (wider than stock ones) Huladog_imp 17 1,149 06-30-2016, 03:42 AM
Last Post: Papa Weeley_imp
  Thinking about belt conversion Ralph_imp 12 1,104 10-19-2015, 08:41 AM
Last Post: Ralph_imp
  Givi Rear Rack vs. Honda OEM Rear Carrier lagoje_imp 29 1,855 04-24-2015, 06:03 AM
Last Post: specialist8
  larger rear tire aquasition_imp 26 1,803 11-04-2014, 11:29 AM
Last Post: jose_imp
  Thinking about gaiters the Ferret 10 717 08-06-2013, 02:04 PM
Last Post: BuffaloBill_imp
