Yoshimura RSC full exhaust rusted in less than a year
Likes Given: 82
RE: Yoshimura RSC full exhaust rusted in less than a year
(04-26-2015, 03:40 AM)Headbanger02_imp Wrote: I'm looking at the yoshimura RSCV full exhaust black stainless steel, doe's anybody have a set of these, I'm curious to how the coating will hold up, any advice maybe, I'm not a diehard all weather rider, I don't ride it when the roads are wet, I ride for an hour most days when the weather is awesome out.
I have these. However, I have only logged about 1000 miles on the bike since the install. It is probably good to point out that Yoshimura had two different sets of black headers available and that the set that rusted was the "hand bent" ones which, probably coincidentally, do not seem to be available any longer (at least the last time I checked a few weeks ago).
@ CIP...could you point me to more information about the fender extender please?
04-27-2015, 01:30 AM
ChipBeck_imp Offline
Threads: 29
(03-30-2015, 02:14 PM)Rebel73_imp Wrote: So the stainless steel pipes shouldn't rust? Would there be any issue with black pipes? I'm looking at the Moriwaki black 4-2.
Rebel,
That's correct. Stainless steel will not rust. In the 1960's all auto makers used mild steel for exhaust pipes. It was easy to bend and form into long complex shapes. BUT every time a car is shut down the rapid temperature drop causes condensation to form like it does on the outside of your ice tea glass. Those steel pipes were constantly wet inside even in dry weather and they rusted through. Replacing exhaust pipes was common back then. Stainless steel is a bi**h to bend into complex shapes without special equipment. This is why "hand bent" exhaust systems are still often made out of mild (rustable) steel. Avoid them if you want a durable system. Today, all auto makers use only stainless steel in exhaust systems and they never rust and still work great after hundreds of thousands of miles. The stock exhaust on the CB11 is stainless steel. Cheers.
Chip
04-27-2015, 04:18 AM
Motogeezer1949_imp Offline
Threads: 66
I believe there are 2 types of Yoshimura systems for the CB.
The expensive one, which is stainless steel and ceramic coated.
The less expensive one, which is steel and painted.
When I was researching which set to get Eric, I recall the description for the less expensive one saying it would require the occasional repaint.
04-28-2015, 01:39 PM
  Yoshimura RS3 replacement for an '13 Jurlie_imp 7 618 07-28-2024, 01:47 PM
Last Post: Glockrocks83_imp
  Yoshimura RSCV Full Exhaust System Stealth128_imp 43 3,608 11-29-2022, 10:38 AM
Last Post: mrded_imp
  Dart flyscreen and a little Yoshimura stain magic 1985CB450_imp 19 1,715 10-24-2022, 04:12 AM
Last Post: 1985CB450_imp
  PCV with full exhaust worth getting tune?? gretle_2.0 4 441 05-24-2022, 03:43 AM
Last Post: gretle_2.0
  Arrow full exhaust gretle_2.0 2 341 05-17-2022, 11:38 AM
  Moriwaki 4 into 1 full pipe GS1100_imp 9 689 01-30-2022, 12:59 PM
Last Post: rich_imp
  full delkevic exhaust outback_imp 27 2,065 01-14-2022, 11:12 AM
  Yoshimura RS3 Install. 2013 Kit on a 2014 and sorted the center stand issue! rdtshaw_imp 17 1,234 01-05-2022, 10:54 PM
Last Post: Nibis_imp
  Arrow full system exhaust tsmetjen_imp 19 1,324 07-29-2020, 03:46 PM
Last Post: tsmetjen_imp
  Delkevic full system?? juliang_imp 4 438 07-29-2020, 05:50 AM
Last Post: Bheezy27403_imp
