ROX 5cm bar riser report
Nightengale_imp Offline
Threads: 7
RE: ROX 5cm bar riser report
(05-23-2017, 03:42 AM)Lord Popgun_imp Wrote: Go welcome some new members Nightengale...
Yeah, thought about that... I've got thousands of posts 'elsewhere', just not here. Generally I don't say much on the boards.
I haven't tried the risers again, but will. Just got my new-to-me Arrow slip-on installed, sounds great. Too sore for a ride (split several cords of wood today) and it's just not smart to ride when tired to try out the new 'tunes on the bike.
Good grief. Post 7.
05-25-2017, 09:36 AM
Threads: 7
Definitely a no-go on the 2" or 2 1/4" Rox Risers (Standard 2014 model bike), so I sold them. The third install attempt included attempted adjustments of the front hydraulic brake line to optimize best angle and best routing. I don't know if my bike has a extra short front brake line or not - but there was absolutely no way these were going to work. It was easy to see that the front brake line would be seriously overstretched and the risers still weren't fully pivoted into the correct position, so I gave up.
Just got in some SW-Motech 1" up - 1" rearward riser inserts. Too cold and dark to try these out, but I expect them to fit, since they're used and came off of another CB1100 and they fit the previous owner. They have half of the rise as the Rox's I tried.
My goal is to improve the riding position. I want to have a more sit up then the stock lean forward position, which with stock bars, stock risers and my size torso / arms, the stock setup requires a forward reaching / leaning position.
The snow is still going to be on the ground so all I'll be able to do this winter is try these out in the garage and see how they feel.
Liking the Arrow by the way. Easy install, quality fit and finish, very nice sound, summer rides with it were definitely enjoyable.
01-16-2018, 01:43 PM
jimgl3_imp Offline
Threads: 27
well, I was looking at them too, but the price just kept keeping me away. I'm a skinflint! so, I find these Chinese made ones on EBay for $16. first go round they wouldn't quite tighten up in the stock clamps, so I put duct tape around the bottom things that go in the stock clamps where the handle bar used to go and walla! they tighten right up and you can't even see the duct tape. it is hidden completely away inside the clamps. I chose to undo the brake line retainer that also holds the horns. that allowed the brake line to reach without getting tight and I can't see any danger in it binding on anything. I'll keep a close check, and if I see trouble, I'll get the stainless steel lines I've been wanting anyway.
01-17-2018, 05:47 AM
jedd_imp Offline
Threads: 27
I tried the rotating Rox risers, only to have found out that the rox wasn't able to be clamped down tight enough to prevent the bar from rotating. A firm push or tug was all it took to rotate them, despite cranking down heavily on the top clamp bolts like a gorilla. Thus, I returned them back to Rox.
I then decided to go with the fixed position of SW Motech offset risers. In the interim, however, I rotated my bar back, and then repositioned the levers to fit my arms' ergos. It's not ideal, but that accomplished my single goal: to scoot 1"-2" farther away from the gas tank so I dont' scratch tank w/ my zipper. That was 1 yr ago, and as of date, I have no problems having my bar rotated back and down
01-18-2018, 04:00 AM
jimgl3_imp Offline
Threads: 27
really liking these things!! no more bending forward! should have done this a long time ago!
01-21-2018, 12:34 PM
  FOBO tire pressure monitoring system report.. Chuckk_imp 120 8,421 11-28-2020, 10:38 AM
Last Post: Chuckk_imp
  Handlebar riser Ale72_imp 21 1,234 12-30-2019, 04:38 AM
Last Post: lash_imp
  Options for handle bar riser itstuantran_imp 1 310 06-21-2019, 03:49 AM
Last Post: Bazbro_imp
  Low Bar (CB500) with Riser Flip - Perfect Sport Ergos Ulvetanna_imp 32 2,380 06-17-2019, 12:19 PM
  INSTALLED: Rox Pivoting Riser 2" rise x 7/8 stem clamp x 7/8 " handlebar Mandrau_imp 11 832 10-24-2018, 12:29 AM
Last Post: Mandrau_imp
  I inch riser Mscb1100_imp 12 969 10-16-2017, 10:58 PM
Last Post: Mscb1100_imp
  Arrow full exhaust system report daskraut_imp 3 369 05-15-2016, 10:43 PM
Last Post: JF Coastal_imp
  Handlebar Riser Search Motogeezer1949_imp 5 470 03-18-2015, 03:57 PM
Last Post: JustPassinThru_imp
  Report on K&N Filters CIP57_imp 28 1,978 10-02-2014, 12:07 PM
Last Post: Dakota_imp
  Anyone have a Daytona Cozy Seat Report? LiveToRide_imp 1 205 01-18-2014, 08:59 AM
Last Post: CB4ME_imp
