I inch riser
Mscb1100_imp Offline
Threads: 49
I inch riser
I just added some 1 inch risers and it made a great improvement.
Thanks to ca200 for a good deal on pair he didn't need.
The extra inch up and a slight tilt back on the bars takes some weight off my hands and shoulders and makes the ride more pleasant.
09-25-2017, 10:18 AM
Threads: 698
Likes Given: 792
RE: I inch riser
Good deal
09-25-2017, 12:25 PM
Banned_imp Offline
Threads: 18
RE: I inch riser
(09-25-2017, 10:18 AM)Mscb1100_imp Wrote: I just added some 1 inch risers and it made a great improvement.
Did you have to change the stock cables or were they long enough?
09-25-2017, 03:06 PM
Threads: 49
RE: I inch riser
They had plenty of room
Can easily turn bars full lock side to side
09-25-2017, 08:10 PM
Ban_imp Offline
Threads: 4
RE: I inch riser
Mscb1100: what is your model? I plan to raise my RS handle bar a bit up but wonder if the stock cables are enough.
10-01-2017, 06:33 PM
Threads: 49
RE: I inch riser
(10-01-2017, 06:33 PM)Ban_imp Wrote: Mscb1100: what is your model? I plan to raise my RS handle bar a bit up but wonder if the stock cables are enough.
Mine is a 2014 standard
10-10-2017, 02:14 PM
Scooter12_imp Offline
Threads: 0
RE: I inch riser
I used these Genmars on my 2014 STD and they worked fine.
http://www.genmarmfg.com/shop/universal-...etail.html
The relieved the pressure on my hands, much more comfortable.
10-10-2017, 11:09 PM
Threads: 49
RE: I inch riser
(10-10-2017, 11:09 PM)Scooter12_imp Wrote: I used these Genmars on my 2014 STD and they worked fine.
Scooter, did you have to make any modifications regarding moving brake/clutch or throttle lines.
Do you still have full lock to lock turning with these.
If so I will order a pair today as mine just raised it a inch,
I clicked on the link and they look like they are up and back 1 inch
thnks
David Mscb1100
10-11-2017, 12:19 AM
Threads: 0
RE: I inch riser
No mods for me. The cables and brake/clutch hoses are just long enough. I thought at first that the brake hose was too short, but it's not under any tension, just maximum reach. Any more rise or setback and it would not have worked. They are up 25mm and back 35mm, so 1 inch up and 1 3/8 inch back. Yes, full lock to lock travel, scares me every time the horn button hits my tank bag.
10-11-2017, 12:50 AM
will866_imp Offline
Threads: 5
RE: I inch riser
My 2" Rox risers wourked great without modification to cables. 2014 Deluxe.
10-16-2017, 01:29 AM
  Handlebar riser Ale72_imp 21 1,229 12-30-2019, 04:38 AM
Last Post: lash_imp
  Options for handle bar riser itstuantran_imp 1 310 06-21-2019, 03:49 AM
Last Post: Bazbro_imp
  Low Bar (CB500) with Riser Flip - Perfect Sport Ergos Ulvetanna_imp 32 2,379 06-17-2019, 12:19 PM
  INSTALLED: Rox Pivoting Riser 2" rise x 7/8 stem clamp x 7/8 " handlebar Mandrau_imp 11 830 10-24-2018, 12:29 AM
Last Post: Mandrau_imp
  ROX 5cm bar riser report Voitus_imp 24 1,479 01-21-2018, 12:34 PM
Last Post: jimgl3_imp
  job completed 17 inch conversion rmack_imp 15 1,184 02-24-2017, 02:57 AM
Last Post: CB Cycles_imp
  Handlebar Riser Search Motogeezer1949_imp 5 470 03-18-2015, 03:57 PM
Last Post: JustPassinThru_imp
  17 Inch Wheels jasonlim_imp 14 928 11-23-2013, 02:07 AM
Last Post: ingobohn_imp
