Rear Fender Elimination.
silascopathic_imp Offline
Threads: 28
RE: Rear Fender Elimination.
the wires are shielded and the bottom of the seat is exposed. What I plan on doing is making a template out of cardboard of the underside of the seat and exposed areas, then using that template, making an aluminum plate to hide all that and protect. shouldn't be too hard. I will post pictures. But that will probably not be until next week (unless i find time in the next day or so.)
07-29-2013, 11:01 PM
Mackerel_imp Offline
Threads: 4
(07-29-2013, 11:01 PM)silascopathic_imp Wrote: the wires are shielded and the bottom of the seat is exposed. What I plan on doing is making a template out of cardboard of the underside of the seat and exposed areas, then using that template, making an aluminum plate to hide all that and protect. shouldn't be too hard. I will post pictures. But that will probably not be until next week (unless i find time in the next day or so.)
Hmm I may consider buying another fender and cutting the end off as someone else suggested. Not sure how much I trust my own metal working skills Undecided
07-29-2013, 11:18 PM
Threads: 28
the way i see it, the piece of aluminum will be about $15-$20 with about 30 min of labor. definitely beats $200 and then cutting it in half. Mackerel, if I can come up with a template I'll make an extra and send it to you
07-30-2013, 12:46 AM
Threads: 4
(07-30-2013, 12:46 AM)silascopathic_imp Wrote: the way i see it, the piece of aluminum will be about $15-$20 with about 30 min of labor. definitely beats $200 and then cutting it in half. Mackerel, if I can come up with a template I'll make an extra and send it to you
That would be amazing Big Grin
I'll keep checking back for your updates. Hopefully I can at least be the first to try those separate handlebars so I can give something back.
07-30-2013, 02:03 AM
Threads: 28
yea man!!! those are definitely an "oooooh la la " upgrade that I'm sure we are all wondering what they really look like and feel like
07-30-2013, 07:42 AM
wildezt_imp Offline
Threads: 9
#26
any more progress made silascopathic..? Exclamation
07-30-2013, 12:53 PM
Threads: 28
#27
not yet. I was hoping that the tail light would come in. I bought some solder yesterday and some heat shrink in anticipation of the project. But i'm going away for 5 days and the project will have to wait until next week.
07-30-2013, 10:00 PM
ChipBeck_imp Offline
Threads: 29
#28
(07-29-2013, 10:46 PM)Mackerel_imp Wrote: My only other big concern was how much protection there is underneath the seat area without the fender. Are any of the wires or anything susceptible to water/corrosion damage because it no longer has the metal shield blocking everything getting slung from the tires?
Gentlemen,
If I was going to do this, to try and accomplish this look, I would use the flat black fender similar to the one on the Mugan CB1100. A smaller and properly shaped taillight is incorporated into this flat black shorty fender which virtually disappears once you put it on the bike. Your stock fender and taillight assembly could come off intact and could be replaced at any time. The bottom of your seat and the wires would all be covered up because a fender would actually be in place in that area. The license plate mounts directly to a flat black section of that fender and the license plate is also protected by it. Best of all, for about $230 bucks you can buy it, just bolt it on and you're done. This fender is sold by Samurider. For members trying to achieve this who don't want to put a lot of effort into fabricating something from scratch this may be a solution. All the best.
Chip
[url=http://s288.photobucket.com/user/chipbeck/media/Fender.jpg.html][Image: 706136f53ce634f5b6136064c21b0a4a.jpg]
07-31-2013, 04:11 AM
Threads: 28
#29
i also looked at this and it may be an option eventually! but ill keep you posted on my fabrication
07-31-2013, 04:15 AM
Threads: 4
#30
Hmm I contacted a local motorcycle machine shop and explained what I was trying to do. He came back with "First of all, this is illegal in the USA. Please call me so we can talk about it."
I asked what exactly was illegal, maybe he was confused by some part. I was just curious how much it would cost if I had someone professionally do it vice order one (the $350 above) or fabricate one myself like silascopathic. He gave me the standard $90/hour, but who knows how many hours it may take them...
EDIT: Ah, it was in reference to the actual tail light. We already knew that one isn't DOT certified. All clear!
07-31-2013, 06:16 AM
  Front fender options Azika_imp 29 3,797 11-17-2022, 02:52 PM
Last Post: Azika_imp
  Ryujin Fender Eliminator curated_imp 2 409 08-22-2022, 03:14 AM
  MIZ front fender and tail cowl on Samurider CB4ME_imp 16 1,647 06-27-2022, 12:52 PM
Last Post: CB1100CB_imp
  Front Fender Splash Guard Wagonpeddler_imp 26 1,970 03-03-2022, 05:45 PM
Last Post: jtopiso_imp
  Powder-Coated Front Fender, New Seat, Fender Eliminator, Etc. andyferd_imp 7 692 10-08-2021, 06:23 AM
Last Post: ender_ong_imp
  Fender eliminator Kdogg2077_imp 7 775 06-27-2021, 12:48 AM
Last Post: Kdogg2077_imp
  Tail Tidy or short rear Fender (Mudguard) beardyweirdy@me.com_imp 9 986 06-18-2021, 10:07 PM
  Fender Eliminator that isnt $275 0011bc_imp 54 4,672 07-10-2020, 06:44 AM
Last Post: kennyw
  Custom fender eliminator & 2017 grab bar with LED strip tail light mod CBhooligan_imp 33 2,932 05-10-2020, 06:24 PM
Last Post: Jfro5687_imp
  Fender colour change Buzzard Biker_imp 14 1,066 01-18-2020, 06:39 AM
Last Post: Obleo
