Lookey what I got, Emgo Venom Mark ll
mvk24_imp Offline
Threads: 18
Likes Received: 2 in 1 posts
RE: Lookey what I got, Emgo Venom Mark ll
(03-26-2021, 11:59 AM)Lord Popgun_imp Wrote: MKV, don’t worry about no stripe. The Road Comet does not have one unless you order it. I ordered mine without. And like it like that Smile
I'm curious what kind of windscreen bolts the comet uses? I ordered the rubber well nuts because that's what I have on all my yamahas. This Emgo just came with nut, bolt, washer for both sides of the screen.
Surprised there was not even rubber washers used to help with flex, vibration, and helping not to crack the ABS if you over tighten
03-26-2021, 12:06 PM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 143
Lets see if I can remember. First it comes with a spacer/mount/bolt that replaces the front bolt on the headlight shell. The Comet has grommets with internal metal sleeves. Then screws to hold the comet on. I forget exactly what screws as I can’t find mine. I am using Allen heads.
The bottom is held with a L bracket. Short leg on the horn mount stud and the Comet on the other end with a screw. No grommet here. Again, I use an Allen head.
I remove the RC for cool/cold weather and install my Street Shield EX. I don’t remove any of the RC mounts so remounting the RC in the Spring (pretty soon now) is a 5 minute job.
Wait, do you mean the actual screen? Its held on to the fairing with stainless steel screws. A plastic washer on top and stainless washer and nut on the bottom (inside)
03-26-2021, 12:32 PM
mvk24_imp Offline
Threads: 18
(03-26-2021, 12:32 PM)Lord Popgun_imp Wrote: Lets see if I can remember. First it comes with a spacer/mount/bolt that replaces the front bolt on the headlight shell. The Comet has grommets with internal metal sleeves. Then screws to hold the comet on. I forget exactly what screws as I can’t find mine. I am using Allen heads.
Nice having options like that, I ended up cutting the mount on the bottom off as I needed a little more clearance to push the entire fairing back a little further to line up with the front headlight bolt.
With the pressure against the foam protectors at the cluster and the headlight bolts tightened it won't budge so I just made sure to cut away a little more on the bottom so there will be no touching and vibration.
03-26-2021, 12:36 PM
  I installed the Emgo Reverse Cone Universal slip on danieljrmurray_imp 2 402 05-15-2023, 04:29 AM
Last Post: 3rd Gear Steve
  Emgo fairing capttwb136_imp 20 1,422 03-09-2021, 02:32 PM
  Mr.P's CB mods, mark II misterprofessionality 18 1,473 05-21-2020, 06:45 PM
  Emgo euro handlebars Jaychaynes_imp 6 513 05-24-2017, 03:34 AM
Last Post: Toddman_imp
  Emgo fairing capttwb136_imp 81 5,634 05-10-2017, 06:56 AM
Last Post: kennyw
  New Emgo shorty reverse cone exhaust on my 2014 CB1100 uscgmac_imp 21 1,612 11-12-2016, 04:15 PM
Last Post: ryanschillinger_imp
  Emgo Exhaust?? mgoodie_imp 62 3,627 07-11-2016, 04:44 AM
Last Post: dsinned_imp
  Emgo Tail light cbfan_imp 21 1,566 11-23-2013, 07:32 AM
Last Post: gogoAZ_imp
