Emgo fairing
capttwb136_imp Offline
Threads: 12
Emgo fairing
So, did anyone ever get one of those Emgo fairings that were mentioned here a few weeks back? If you did, did it come with mounting hardware? I've seen them on ebay real cheap, I ordered one and it came with no mounting hardware or instructions. I won't be putting it on until next spring, but I was wondering how to make a bracket for the bottom mount. If I could see a bracket it would really help.
11-28-2015, 07:18 PM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
RE: Emgo fairing
Capt,
Apparently it does not come with much hardware for mounting. Check out this pic: http://www.revzilla.com/motorcycle/emgo-...fe-fairing
Guess you do have to fab your own.
11-28-2015, 10:27 PM
Threads: 12
RE: Emgo fairing
http://www.pdi-racing.com/emgo-venom-fai...-70-52505/
Thanks Popgun. I ordered the EMGO Venom fairing. The only hardware I received was the little screws that attach the screen to the fairing.
11-29-2015, 02:55 AM
Likes Given: 789
RE: Emgo fairing
Don't these type of fairings just normally have forked brackets attached which slide under the bolts for the headlight bucket? dOes this fairing not have those?
11-29-2015, 01:30 PM
Capo Offline
Sea Girt, New Jersey
Threads: 51
Emgo fairing
I bought one years ago for a Bonnie, and it came with a few bent and drilled brackets that looked like they were banged out in a Chinese forced labor camp, utterly useless. I made a few brackets, mounted it, but I didn't dig the look on that particular bike. I adorns my garage wall now.
11-29-2015, 09:26 PM
Threads: 12
RE: Emgo fairing
(11-29-2015, 01:30 PM)The ferret_imp Wrote: Don't these type of fairings just normally have forked brackets attached which slide under the bolts for the headlight bucket? dOes this fairing not have those?
No, no brackets of any kind. Or instructions what so ever.
11-30-2015, 12:56 AM
Toddman_imp Offline
Threads: 6
RE: Emgo fairing
There are two screws that go into the headlight and you will need to 'hog out' a little for the the headlight screws to go in and you will need to remove a tiny bit of material where the turn signals are. It's a very small amount. Use a dremel if you have one. There exists a hole in the bottom front of the fairing to connect a bracket to the horn brace but you'll have to fabricate one or get a small L bracket from your favorite hardware store. I didn't put a brace on the bottom but I probably will this summer. It works fine without one. As far as the sturdiness of the the fairing, it seems fine to me. I'm liking it for under $60.
11-30-2015, 02:05 AM
Lord Popgun Offline
Virginia
Likes Given: 142
RE: Emgo fairing
That L bracket would be extremely easy to make. The Road Comet comes with one and it does stiffen up the cowl and holds it so it doesn't want to rotate any around the headlight bolts. That's been my experience anyway.
Capt., in case you didn't know, the L bracket fits on the stud for the horn bracket mounts. Basically, remove the nut, install the L bracket and put the nut back on. Bolt cowl to the other end. Yours should be pretty much the same. If you need a pic, I have my RC off for the winter, but the L bracket is still installed (I have a Street Shield EX on for cool/cold weather. Unlike Ferret, I'm a wimp. Smile
11-30-2015, 04:13 AM
immgunn_imp Offline
Threads: 6
RE: Emgo fairing
I installed one on my '14 Std around 5 months ago. Just used the headlight bolts and then some strip insulation with self adhesive on top of my gauges and horn to deal with rubbing & noise. As mentioned above, I did have to trim it. I used a jig saw & taped the area I was cutting.
11-30-2015, 05:33 AM
Threads: 12
RE: Emgo fairing
Thanks fella's. So as I understand I'll use the two screws that currently hold the headlight onto the headlight brackets, but first I have to make the holes in the fairing a little bigger. Also fabricate a bracket to attach it to the horn bracket. I also have to trim a little off the fairing with a dremel tool where the fairing fits up to the turn signals. Is this about right?
Popgun, if you could snap a picture of the bracket you have attached to your horn bracket I certainly would appreciate it.
Thanks again fella's, I love this forum!Clap
11-30-2015, 06:20 AM
  power port and Samurider Road Comet Fairing 1 tdbru 9 1,012 05-04-2025, 07:20 PM
Last Post: tdbru
  I installed the Emgo Reverse Cone Universal slip on danieljrmurray_imp 2 396 05-15-2023, 04:29 AM
Last Post: 3rd Gear Steve
  Batwing fairing ISO Griz53_imp 1 345 01-22-2023, 03:11 AM
  Road Comet Fairing Catbird_imp 47 4,490 08-16-2022, 10:33 PM
  Rebel 500 SE style fairing? LayerCake_imp 0 304 06-12-2022, 09:03 AM
Last Post: LayerCake_imp
  vetter fairing help Canadianredneck_imp 12 1,067 03-31-2022, 12:51 PM
Last Post: rboe
  road comet fairing vfrpaul98_imp 75 5,315 10-21-2021, 02:41 AM
  fairing ? rich_imp 14 1,204 04-22-2021, 02:13 AM
Last Post: 17-CB-002
  Lookey what I got, Emgo Venom Mark ll mvk24_imp 22 1,606 03-26-2021, 12:36 PM
   Saturday morning project - Road Comet 2 Fairing LuckyNLife_imp 11 947 09-16-2019, 11:36 PM
Last Post: Cobalt23_imp
