Anyone using the Kaoko throttle control?
mvk24_imp Offline
Threads: 18
Likes Received: 2 in 1 posts
RE: Anyone using the Kaoko throttle control?
(06-07-2023, 11:44 PM)Tev62_imp Wrote: My throttle lock is called an R1250GS.
[Image: a69b69f5b07eec407d9513369747adce.png]
06-07-2023, 11:47 PM
Funny, ... guy!
06-08-2023, 01:40 AM
KiowaEagle_imp Offline
Threads: 36
I have a Kaoko on my Concours and I like it for what it is. One good thing about it is it's easy to make fine adjustments once you set it. So you don't have to keep releasing it and resetting it.
06-08-2023, 05:55 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
The throttle lock is EXPENSIVE but at least they throw in a motorcycle Tongue
06-08-2023, 06:48 AM
(06-08-2023, 05:55 AM)KiowaEagle_imp Wrote: I have a Kaoko on my Concours and I like it for what it is. One good thing about it is it's easy to make fine adjustments once you set it. So you don't have to keep releasing it and resetting it.
(+1) Agreed.
06-08-2023, 07:38 AM
Tbhart89_imp Offline
New to the Forum
Threads: 0
#26
I added a brakeaway to mine. Looks better than expected and seems to work well so far. Won't know for sure until my upcoming long ride. I do like that it cancels when you grab the brakes
06-21-2023, 08:26 PM
The Gecko_imp Offline
Threads: 43
#27
You seem to have too much money to feel entirely comfortable in this forum ?! Angel
If I read this thread right (??) Kaoko and other, similar devices are not necessary all the same quality. Could this explain away the differences seen in user happiness?
06-30-2023, 04:44 AM
#28
I believe Kaoko offerings are professionally engineered and machined devices.
However, like people are different, throttle lock approaches are different. In addition, people feel more comfortable with one implementation versus another.
I have met people who could not adjust (no "pun" intended) to the Kaoko. Others, rave about its convenience. Like tires, saddles, and engine oil.
06-30-2023, 06:12 AM
Threads: 698
Likes Given: 789
#29
I had real cruise on my FJR. No throttle locks seem good enough anymore. I tried a GO-Cruise on my CB and it worked "ok-ish" on long perfectly flat straights ...sorta.
06-30-2023, 07:20 AM
#30
I like the [real] cruise control on the Moto Guzzi V85TT. It seems to just work.
The only thing I somewhat dislike is I think they should have reversed the status LED on the instrumentation cluster. Instead of flashing when cruise control is [enabled+not engaged], and solid not flashing when [enabled+engaged], I would like these to swap behaviour.
But the Kaoko I find okay too as a throttle lock.
06-30-2023, 07:48 AM
  Handlebar control symmetry Uncle Sixer 17 1,716 08-07-2025, 05:24 AM
  What cruise control are you using for your CB1100? goldeneye_imp 51 3,432 11-16-2023, 12:26 PM
  KAOKO cruize control ozigoo 6 542 05-27-2020, 01:14 PM
Last Post: 17-CB-002
  CBR RR throttle bodies TrickyNicky089_imp 29 2,423 08-13-2018, 06:26 PM
Last Post: Bradders_imp
  That ugly round blank on the throttle body the_undecider_imp 85 6,223 01-12-2018, 08:29 AM
  Foot Control Relocation Kit reinie_imp 6 624 01-10-2018, 12:13 PM
Last Post: Nightengale_imp
  Kaoko Cruise Control Kit 17-CB-002 12 845 07-19-2017, 02:10 PM
Last Post: Nortoon_imp
  Quick Turn Throttle olekzap_imp 15 1,359 08-24-2016, 10:02 AM
Last Post: Ulvetanna_imp
  I got booted out of Twisted Throttle Chapomis_imp 13 1,235 04-14-2016, 09:35 PM
Last Post: Chapomis_imp
  Brake Away throttle control Razor 25 1,664 07-16-2015, 10:05 PM
Last Post: redbirds_imp
