First oil change
Fleetwood it is an aluminum washer designed to crush and swell, therefore sealing, hence the name crush washer. Are you sure yours doesn't have one? It could be stuck on either the bolt, or the engine case or could have dropped in the oil when draining, like My latest one did.. Yes, its supposed to have one if yours doesn't you need to get one.
Ferret which oil did you use on this first oil change? Reg or syn?
3 rights make a left
Regular Honda GN4 10w30.
Check out the how to do 600 mile service on 2014 dlx thread.
Ok will do
(04-21-2014, 10:05 AM)The ferret_imp Wrote: Fleetwood it is an aluminum washer designed to crush and swell, therefore sealing, hence the name crush washer. Are you sure yours doesn't have one? It could be stuck on either the bolt, or the engine case or could have dropped in the oil when draining, like My latest one did.. Yes, its supposed to have one if yours doesn't you need to get one.
Thanks ferret. I looked at the plug, the washer stuck to the block. I was quite relieved when I found it haha
  tire change Tom_imp 7 705 05-31-2021, 11:37 PM
Last Post: Tom_imp
  First oil change for this heathen koehlerk_imp 67 4,447 02-20-2021, 02:42 PM
  Oil Change interest? Scotty_imp 10 875 09-15-2020, 09:40 PM
  Oil Change Time! Jambo_imp 57 3,920 09-06-2020, 08:40 AM
Last Post: Jambo_imp
  Oil change before/after winter? HikerToo_imp 11 807 02-09-2019, 05:08 AM
  Oil Filter Change: Every oil change or every other? dbarkdoll_imp 22 1,224 04-17-2018, 12:46 AM
Last Post: Knave_imp
  Oil change questions... ride4now_imp 16 999 04-12-2018, 02:12 PM
  fork oil change Houtman_imp 4 397 03-12-2018, 08:46 PM
Last Post: Wisedrum
  First oil change SportsterDoc 30 2,154 11-28-2017, 09:24 AM
Last Post: SportsterDoc
  Completed second oil change (DIY) venturer434_imp 5 455 05-11-2017, 07:47 PM
Last Post: Rocky_imp
