First oil change
At 10 days old, my CB1100E turned 519 miles today.
With blowing dust forecast for Las Vegas Valley, tomorrow, I decided to forgo a ~100 mile ride tomorrow (to reach 600 miles) and change the oil today.
Gave her a coat of wax while the engine was cooling…saves dropping the drain bolt/crush washer in hot oil…not that I have EVER done that!
1. Drain bolt broke lose easy (too easy?) I have a new crush washer, but reused factory.
2. Factory oil filter over torqued. It required a factory cap wrench, 17 mm 6 point socket and a breaker bar to break lose. Cap wrench came off old filter with the tap of a mallet.
3. Cleanest break-in oil I have ever seen. Color only a tad darker than new Honda GN4 10W-30.
4. Four quarts took it very close to max level on site glass.
5. Oil pressure light went out about one second after start-up.
Lubed the chain for the first time. Had some PJ1 left over from my XT250
A couple sheets of cardboard made cleanup easy
Maybe Saturday I can find out if the snorkel mod makes any difference climbing from 3,000 to 8,500 feet. Probably not discernible, especially since I have not previously run it steady over 5,000 RPM, but I do like the intake sound.
Post 7: http://cb1100forum.com/forum/showthread.php?tid=11787
This bike is so ridiculously easy to change oil on. THey should all be like that. Unfortunately most aren't.
Very cool. I agree with Ferret, stupid easy oil change. I did mine at 525 miles and it looked very clean as well. Feels good to get that break in oil out though dont it? I got my new 14 back in September and im just assuming the oil was from when it was built and really wanted to change it right away but i just said screw it and racked some miles on it pretty quick and then dumped it. Feel good now hehe
(11-16-2017, 12:51 PM)The ferret_imp Wrote: This bike is so ridiculously easy to change oil on. THey should all be like that. Unfortunately most aren't.
I like the spin on filters and all is very accessible, especially on the center stand.
Don't want to start an oil thread (not even winter!), but probably will switch to 10W-40 as the weather warms. Not uncommon to ride at 115 F+ here.
My owner's manual only lists 10W-30 and I have read of valve noise issues using 10W-40 (think that was my pre-purchase research on this forum).
GN4 is not expensive at $6.99 a quart (and much less by the gallon), but since the local dealer does not recycle my GN4, I am annoyed and considering Castrol 4T or maybe Castrol Power 1 synthetic, as used in my 2012 Bonneville. Seems fair to buy from where I will recycle (AutoZone or O'Reilly's).
Used Castrol 20W-50 in all my bikes until the Sporters, then used H-D 360 (2.8 quarts per change) for them.
The Bonneville was prepped with Castrol Power 1, so I continued to use it. Don't know if it was the factory oil cooler, twin oil pumps and/or synthetic oil, but the Bonneville never seemed to know it was hot. Went across the desert to SoCal and back more than once.
The recent Yamahas used Castrol 4T ($6.49/quart)
The Moto Guzzi required 10W-60 (not a typo), so I got introduced to Motoul. Good oil, but VERY expensive.
Concern switching from GN4 10W-30 to GN4 or Castrol 10W-40 would be valve noise. Switching to synthetic should not affect clutch, as it had no issues on the Bonneville.
However, the recommended 4,000 miles between changes with dino oil is farther than my comfort zone. Probably will go only 3,000. Maybe 4,000 if synthetic used.
Use/do what makes you comfortable. It doesn't get much above 90 here or much below 32. I change oil every 4000 in all my bikes.
(11-16-2017, 01:42 PM)greekcb_imp Wrote: Very cool. I agree with Ferret, stupid easy oil change. I did mine at 525 miles and it looked very clean as well. Feels good to get that break in oil out though dont it? I got my new 14 back in September and im just assuming the oil was from when it was built and really wanted to change it right away but i just said screw it and racked some miles on it pretty quick and then dumped it. Feel good now hehe
Yep, the messy part was getting the old oil into the 4 bottles!
The dealer did not have 10W-30 in gallons.
The dealer prep mechanic referred to the factory oil as break-in oil.
Don't know if it is any different than GN4, but I like to do the first oil change early on any vehicle.
Both the 2017 and 2018 Yamahas had metal particles on the oil filters/screens at the first change. I did not cut open the filtger, but think the CB1100 motor was assembled sanitary!
(11-16-2017, 01:49 PM)The ferret_imp Wrote: Use/do what makes you comfortable. It doesn't get much above 90 here or much below 32. I change oil every 4000 in all my bikes.
The northern part of Las Vegas Valley gets about one week of slightly below freezing weather every 2-3 years. Bit rough on our citrus trees.
But we get snow in the nearby mountains.
I have finally become accustomed to 4K intervals in my 4WD, using synthetic blend...but it is mainly long distance miles to SoCal or AZ (Canada when it was new).
A significant plus with the CB1100 is the oil capacity.
I live at 8,000' and have taken my CB to 14,000' many times (also joined by the Ferret and Offroad on their CB's). No issues with the stock air intake, or anything else, at those elevations. The bikes work great up there and have plenty of power, precise fueling, and excellent drivability. No need to overthink this.
Did they have "synthetic blend" when Canada was NEW?
You could get away with some old pork fat on the axles in those days Wink
Eh!
Circa 1987-1992, I managed contracts for the CA office of Automation Tooling Systems, headquartered in Kitchener, Ontario (ATS since moved to London, Ontario),so I can appreciate jokes with a Canadian accent. Traveled there yearly for sales meetings. Beautiful countryside.
(11-16-2017, 02:35 PM)LongRanger_imp Wrote: I live at 8,000' and have taken my CB to 14,000' many times (also joined by the Ferret and Offroad on their CB's). No issues with the stock air intake, or anything else, at those elevations. The bikes work great up there and have plenty of power, precise fueling, and excellent drivability. No need to overthink this.
I like the intake sound, whether air flow is improved or not.
Reminds me of buying a taller air filter for a 4 barrel carb to allow air flow around the circumference, rather than just through the silencing tube...or the open element on the Carter AFB on the 350 in my Datsun pickup.
Also, the air filter can be inspected by only removing the right side cover.
  tire change Tom_imp 7 710 05-31-2021, 11:37 PM
Last Post: Tom_imp
  First oil change for this heathen koehlerk_imp 67 4,465 02-20-2021, 02:42 PM
  Oil Change interest? Scotty_imp 10 878 09-15-2020, 09:40 PM
  Oil Change Time! Jambo_imp 57 3,928 09-06-2020, 08:40 AM
Last Post: Jambo_imp
  Oil change before/after winter? HikerToo_imp 11 808 02-09-2019, 05:08 AM
  Oil Filter Change: Every oil change or every other? dbarkdoll_imp 22 1,226 04-17-2018, 12:46 AM
Last Post: Knave_imp
  Oil change questions... ride4now_imp 16 1,002 04-12-2018, 02:12 PM
  fork oil change Houtman_imp 4 400 03-12-2018, 08:46 PM
Last Post: Wisedrum
  Completed second oil change (DIY) venturer434_imp 5 456 05-11-2017, 07:47 PM
Last Post: Rocky_imp
  First Oil change Ltrypsin_imp 13 901 10-25-2016, 07:18 PM
