Sprocket change.
Lol Dengie. Stop and go
Hauling the freight. Wow! Who says the CB1100 is not fast enough? It is not a super bike but would out do most bikes except for the super bikes. No doubt in the top 5% of all motorbikes that exist in the world on the streets.
I did notice your shift point in first at 42 I'm at 52 with stock gearing. I'm not seeing any gains though with the shorter gears. I timed my stock 50-100 at 5.8 ( Yoshi at 5.3)and yours at 6.3
I see your in NY I'm in Westchetser.
I dunno. Riding it there is a lot of difference. When I first got it it was disappointingly sluggish all around. I know it isn't a sport bike, and never will be. But coming off a 919 to the CB1100 was a let down. The gear change got rid of that disappointment.
Quantifiable? Doesn't matter.
I had a corvette pull up to me at the red light yesterday on the way to my bike's annual safety inspection. He gave me the varoom varoom . I smoked him and I was not trying and I'm not a fast rider or experience at hole shpts. It was fun!
(06-29-2014, 08:13 AM)U.S.Cavalryman_imp Wrote: I dunno. Riding it there is a lot of difference. When I first got it it was disappointingly sluggish all around. I know it isn't a sport bike, and never will be. But coming off a 919 to the CB1100 was a let down. The gear change got rid of that disappointment.
here's a link to the two runs on an uphill grade ( Stock and Modified )
http://cb1100forum.com/forum/showthread.php?tid=3354
CIP57, You are pulling hard. If all that is changed from the factory is the exhaust then I am down on power for some reason.
(06-29-2014, 10:29 PM)U.S.Cavalryman_imp Wrote: CIP57, You are pulling hard. If all that is changed from the factory is the exhaust then I am down on power for some reason.
C,
The stock video is completely stock, the Yoshi is with a flashed ECU with stock PC5 map, Pair mod and closed air box. Your tach is running up real quick but your gears are much shorter. I did these runs for comparison to see my gains between mods. I have a run with the ECU flash running stock exhaust which only had a .2 gain. I'm glad i find your video it gives us a good idea of gear changes.
The PC5 is next on the list. Seems like it's a must have item
  Chain and Sprocket Options? Yata-Garasu_imp 22 1,906 12-23-2024, 04:47 AM
  Chain or sprocket problem ? The Gecko_imp 14 1,162 07-30-2024, 10:05 AM
  Front sprocket bolt cant be moved misterprofessionality 55 4,326 03-13-2023, 12:18 PM
  Front drive chain sprocket wear 1970Cadillac_imp 15 1,114 11-29-2022, 07:49 AM
  17 tooth CS sprocket install, comments. Bike #12_imp 11 911 01-03-2022, 08:30 AM
  tire change Tom_imp 7 663 05-31-2021, 11:37 PM
Last Post: Tom_imp
  First oil change for this heathen koehlerk_imp 67 4,186 02-20-2021, 02:42 PM
  Another chain and sprocket question bflint 20 1,436 10-13-2020, 01:00 PM
Last Post: tod.branko_imp
  Alloy Sprocket woes Ninemeister_imp 22 1,545 09-24-2020, 09:23 AM
Last Post: Ninemeister_imp
  Oil Change interest? Scotty_imp 10 792 09-15-2020, 09:40 PM
