i tested til out of gas on my standard 2013 cb1100
Well, you will be on countdown mode lol
thank you!!!
Great info. I haven't taken it to the last drop unlike you did, but I pushed it as far as I could comfortably. I was on my 2013, going to work when the last bar started blinking at 140 miles. When I finally decided to fill up, I was at 166.9. I sat there and filled it up, and let it settle down several times trying to get it maxed out. Finally I got 3.755, into her. Ended up getting around 44 mpg on 87 octane. Now the question I have is how close to running out did I truly get as I always fill it up past the bottom of the filler neck and let it settle.
I thought filling up past the bottom of the filler neck, introduces a variable in the capacity in excess of that quoted by Honda changing the tank volume comparison with others.
One day soon I will do the ride to empty challenge on my 2011.
I'll let you know how it went.
Regards
Strap an old oil quart full of gasoline to your seat, and stick close to gas stations when your last fuel bar has been blinking for a while!!
  CB1100 2013: what is the original chain relation? valkyrie_rider_imp 6 788 08-26-2024, 12:23 PM
Last Post: Randy B
  Oil change CB1100@2013: photos valkyrie_rider_imp 12 1,081 02-14-2024, 11:25 AM
  Brake fluid flush CB1100@2013: photos valkyrie_rider_imp 0 241 02-13-2024, 10:28 AM
Last Post: valkyrie_rider_imp
  Clutch fluid change CB1100@2013: photos valkyrie_rider_imp 0 237 02-13-2024, 10:27 AM
  2013 cb1100 chain appears to be rubbing against center stand?? Kirbythefat_imp 4 484 05-22-2023, 12:25 PM
  Short shocks for 2013 CB1100 Griz53_imp 2 383 03-23-2023, 11:38 AM
Last Post: Griz53_imp
  Wider tyres than standard..whose got them? ozigoo 38 2,249 05-23-2021, 03:49 AM
Last Post: jimgl3_imp
  2013 cb1100 Left Directional Light wont cancel. M3-SRT8_imp 15 1,118 08-01-2020, 07:16 PM
Last Post: max
  2014 standard tank and parts Gone in 60 0 170 03-22-2020, 02:37 AM
  How to adjust the front forks on a 2013 CB1100 and a 2017 CB1100EX. michael1954 13 943 02-28-2020, 07:56 AM
