CB1100 assymetrical cam timing, lift, and duration.
If as LWJ says, the ignition timing is adjusted for cyl 1&2 due to the inlet valves opening 10 Deg late, will having the ECU flashed by ghul overwrite these settings?
I'm just wondering out loud.... any ideas?
I figure the ignition is retarded on 1&2 on the std set up. Actually I'm sure the ignition is retarded on all the cyl. Between some revs in the first 3 gears for emissions. Ghul Motors remove this when the ecu is flashed. I wonder if that overwrites the delay on 1&2. If it does then that could be bad...
Thoughts?
Best
Kev
Did this project actually happen? I'd be curious how much smoother the motor would be with stock, but symmetrical timing.
The thing is that valves are opened by the cams, not the ECM.
if I could afford to do things like this I absolutely would !
  Cam Chain Tensioner/Lift ? bflint 6 902 07-18-2025, 10:56 AM
  I've already put my CB1100 up on the lift Guth_imp 21 1,728 12-09-2021, 01:18 AM
Last Post: Raceman_imp
  What ‘Bike Lift’ do you recommend? ride4now_imp 17 1,154 01-11-2021, 02:05 AM
Last Post: j3gq_imp
  Asymmetric Cam Timing Honda.1100_imp 7 559 01-19-2017, 01:28 PM
Last Post: Cyclic_imp
  Harbor Freight Motorcycle Lift Frulk_imp 10 828 03-15-2016, 04:30 AM
Last Post: AzBob_imp
  Work Lift Question Ron in MO_imp 17 1,153 12-17-2015, 03:22 AM
Last Post: redbirds_imp
  Anyone know of a front head lift stand compatible with the CB1100? chync_imp 5 500 10-23-2015, 08:31 AM
Last Post: kennyw
