Deciding 37 vs 35 tooth rear sprocket on 2013, 19 on Front is correct
Thanks rbike. What price were you quoted?
(11-20-2015, 03:57 AM)redbirds_imp Wrote: Thanks rbike. What price were you quoted?
I'm getting two sprockets - a 19 Front & 35 Rear. Both are being made in steel. Honestly due to difficult communications, I am not sure if they are plain steel or stainless like Chip's sprockets. I am assuming the later.
Price slightly over $135 included s&h.
I ordered & picked up yesterday, spare wheel studs, front sprocket washer & bolt, rear wheel lock nuts, and 2 (1 spare) chain master. I will cut/shorten the chain as necessary and re-rivet it with the new master to the correct size. I will also install new lock nuts to the correct wheel torques.
I just heard from 7GD, "The sprockets are clear coated only, they are made from 1045 stock." That's why they look stainless. Common misperception, SS is always better - reality SS is not as strong as good steel.
Here are technical #s for simple comparison purposes - don't look if you are prone to headaches
http://www.onealsteel.com/carbon-steel-bar-cd-1045.html
http://www.onealsteel.com/stainless-steel-bar-304.html
http://www.onealsteel.com/stainless-steel-bar-316.html
Update 11/25/2015: I am going to finish the 19T front sprocket I receive from 7GD in Bright Nickel and the rear 35T in Yellow Zinc. The bright nickel (think of as chrome) is the strongest/best finish for durability (lack of rust) with the yellow zinc just behind it. With that in mind, the Yellow zinc will have a great personality and add to the bling of my mod - oops farkles.
I'll be posting pics when it is done for all to decide for themselves.
Update 2/12/2016 This thread is closed as a 35T is impossible to manufacturer - see http://cb1100forum.com/forum/showthread....#pid123002
I'm reopening (new Post) this item because I should receive my steel 35T rear sprocket in the next week or two- YEAH! I expect this to be the best farkle of mine yet. I'll post pics when I get it & installed.
I'm going to continue this thread (consolidate on to) on my Mod Thread instead of here starting on page 3 [url=http://cb1100forum.com/forum/showthread.php?tid=7605&page=3]http://cb1100forum.com/forum/showthread....605&page=3
hi can any one tell me were
i can get a 19 tooth front sprocket from for my 2013 cb1100
(06-03-2016, 10:40 AM)lol_imp Wrote: hi can any one tell me were
PM me if you are serious, I have a sprocket plus the guard; decided not to change out.
Hello,
Did anyone find a new source for a 37t rear sprocket - steel or aluminum ?
I'm running the 19t front and for my personal preference and use, I would like to try out and pair the 19t front with the 37 rear .
For my own riding requirement, I realized it's not dropping freeway rpm or mpg but compared to my other bikes I need the least amount of rpm/engine breaking/jerking at throttle esp in 4,5 gears . The 19t front is much better but would like to experiment as the CB is def not too tall in first gear yet.
Thanks.
To all that have been following this thread - No excuses, but I have been overwhelmed with ..... I have all the parts, but have not yet installed them. I look forward to doing the 35/19 mod in the next few months.
I am also going to Redo my Tank - stand by for that!
FYI, I just picked up a new RV - Prior New TT (traded In) and now the New RV have taken most of my time.
  Rear indicator (Turn signal) relocation bracket 2013 model AndyBeeMD 15 1,522 08-16-2025, 05:01 PM
Last Post: bflint
  Chain and Sprocket Options? Yata-Garasu_imp 22 2,009 12-23-2024, 04:47 AM
  Chain or sprocket problem ? The Gecko_imp 14 1,220 07-30-2024, 10:05 AM
  Rear only tire on the front? mattmcuomo@yahoo.com 5 589 10-09-2023, 06:05 AM
  Front sprocket bolt cant be moved misterprofessionality 55 4,479 03-13-2023, 12:18 PM
  What is the Correct Chain Size for a 2014 Model? chync_imp 12 1,150 02-28-2023, 01:16 AM
Last Post: Maturecheese_imp
  Front drive chain sprocket wear 1970Cadillac_imp 15 1,195 11-29-2022, 07:49 AM
  How to remove 2013 Rear ABS/Speed sensor danieljrmurray_imp 16 1,398 06-03-2022, 01:16 PM
  VIBRATION - deciding too much; and living with it. JustPassinThru_imp 132 10,650 05-31-2022, 07:47 AM
  17 tooth CS sprocket install, comments. Bike #12_imp 11 965 01-03-2022, 08:30 AM
