Seat lock stuck problem
(11-22-2016, 11:41 AM)Lord Popgun_imp Wrote: This is different than the latch under the seat being stuck. After doing what Ferret suggests, I suggest that you get your other key and try that. Are you using an OEM Honda key?
The problem is apparently what MTC said. The key isn't turning enough to unlock the seat latch. Easy things first. I'd suspect the key before the lock.
Yes, I am using only the OEM keys and have tried both. Tried oiling the key lock last night too. Still no luck! ;-((
The last thing I did with the seat off is put on a renewed license reg sticker to the DMV license plate and store the newly renewed paper registration form under the seat on top of the battery under the hold down strap in an envelop, same as before with the expired registration. Is it possible this somehow disturbed the latch mechanism anywhere near that location???
Thanks for all the help and suggestions everyone. We'll get her licked sooner or later.
I'll ditto what popgun says. You might have a problem with the key. Mine has been known to be "finicky" at times. Does your key go into the lock very far? It will only go maybe 1/2" or so. Try this: See if the helmet latch will move up or down. You might have it jammed, thus the lock cylinder not turning very far. Have patience. You'll get it to work. Go easy with the key in that lock.
Don't think the license paperwork has caused this problem.
Here is a link to the seat parts list.
http://www.partsfish.com/oemparts/a/hon/...a41/seat-1
I wonder if you can get ahold of the barrel behind the helmet holder on cable 2 and pull it to release the seat latch, or remove bolt 10 ( breakaway bolt so probably have to be drilled out) and pull the whole assy to release the seat latch?
Thanks for the illustrated parts list Ferret. I think you're on to something . . . its too dark in my garage now at this hour, so further troubleshooting will have to wait until tomorrow.
Yea that was White Dog that provided the link, so thanks to him for that.
I'm thinking you can unbolt the helmet lock and disconnect the cable to pull it with pliers.
dsinned, if you can't turn the key past 1 o'clock, it seems to me highly unlikely that it has to do with the seat lock. Is it possible that the mechanism for the helmet holder has become bent so the friction is so great the key won't turn?
Ferret, I looked last night and they have a plastic cover over the mechanism so you can't get to the cable to pull it with pliers or something. I couldn't see a way around it. [ Edit to add: It looks like the cover is part of the plastic inner fender, called Fender B on the fiche]. As far as the seat latch I couldn't see a way to get to that either. That plastic cover isn't shown on the part list posted by White Dog. I haven't looked to find where it is shown.
He may have to do as you suggest and drill the breakoff bolts to get to the cable end. The bolts can then be replaced with new ones.
What about removing rear wheel and fender to access the cable and mechanism that holds seat in place?
I think I would try a lock lubricant as others have suggested.
Have you tried moving the seat lock lever slightly up or down while turning the key?
  CB1100 Idle speed instability problem ericlo69_imp 1,434 119,146 07-26-2026, 01:51 AM
  idle problem update 1973cb750 37 2,143 05-12-2026, 08:38 PM
Last Post: rdprdp01
  Stuck Gear Linkage Nut — Can’t Loosen Without Twisting the Rod Narciso 5 1,680 10-10-2025, 09:24 AM
  "Seat Lock" cable unseated. 17-CB-002 10 1,029 08-27-2025, 08:19 AM
  Chain or sprocket problem ? The Gecko_imp 14 1,274 07-30-2024, 10:05 AM
  O ring chain problem Mixagon_imp 7 666 10-17-2023, 07:28 AM
  About the problem of high idling. (2014 cb1100ex) DDUMZI_imp 62 4,868 08-02-2023, 05:38 PM
Last Post: DDUMZI_imp
  May have a problem the Ferret 12 858 01-20-2023, 04:53 PM
Last Post: max
   2017 EX Headlight Dimmer Switch problem? sleeper_imp 24 1,905 10-08-2022, 12:27 PM
  Fast Idle Problem Solved Nachodaddy 17 1,516 10-08-2022, 09:18 AM
