Unhealthy Engine Knock / Noise
Just curious Phil. You mentioned the problem occurred after the first oil change at 600 miles. Was that when you put on the K&N filter? I see in the video an OEM filter was in place. Was that replaced later?
I would also recommend using a mechanical stethoscope to try and pinpoint the noise source. They're cheap ($4 at Harbor Freight) and very effective.
Any resolution on this issue since you first posted?
No resolution yet. Been traveling for work. I am actually trailering the bike to the dealer today. I will circle back with status when I have more.
This is an old thread, but I'll add my two cents. I had a similar knock/rattle from the engine that appeared around 18,000 miles on my 2013 CB1100. It would rattle on startup and then disappear after about 20 seconds. At around 19,000 miles it seemed to be getting worse, so I checked this forum. I saw CuryJoe's comment about the balancer backlash adjustment. I did this adjustment (5 min) and it solved the problem. The adjustment is on p. 11-33 of the 2013 service manual.
Thanks for the help guys!
Welcome Oldhondaguy.
Cool. Welcome Oldhondaguy.
If the service manual is not available:
Loosen the balancer shaft holder pinch bolt. Turn the balance shaft counterclockwise until resistance is felt, then back it off three graduations using the punch mark as a measure.
Warm up the engine and let it idle. If balancer gear noises are excessive, adjust the balancer backlash as follows:
Turn the balance gear shaft counterclockwise until the gears begin to make a "whining" noise. Then turn the gear shaft clockwise until the gear "whining" noise disappears.
Tighten the balancer shaft pinch bolt. After all gear backlash adjustments are done, snap the throttle and make sure the gear noises are not excessive.
If the gear "whine" noise is excessive, the backlash is too small. If the gear "rattling" noise is excessive, the backlash is excessive.
Back in the day, the composite wheel on the cam chain tensioner that rides against the cam chain was somewhat notorious for wearing down, resulting in cam chain slap/knock. Another source of noise back then was valve tappets out of adjustment. That said, and from what I saw in your video, it would appear that the noise is loudest on the lower front right portion of the crankcase, where the back lash adjustment is located, so I would have to agree with curlyjoe and sportsterdoc that the back lash adjustment is the more likely culprit. As others have mentioned, K&N filters have not had a very good reputation lately, and have led to oil leaks that others have also posted about. I always use the specified Honda OEM filter, as I do not want any question about an off brand filter potentially causing an engine problem down the road.
(06-01-2017, 02:46 AM)spakins_imp Wrote: No resolution yet. Been traveling for work. I am actually trailering the bike to the dealer today. I will circle back with status when I have more.
Houtman:
"It would be nice and useful to all of us that after a problem is solved the original poster comes back to the Forum and tell us the outcome. Many times we never hear anything again !"
... ^ + and what is the final resolution, Spakins???
Confused
Good luck getting an answer, peter. Spakins hasn't been here for nearly 18 months.
  Front wheel bearing noise? MagnaRider 20 1,927 03-31-2026, 08:20 AM
  Engine clicking/ticking metallic noise! WTF? Tortuga_imp 28 2,381 10-11-2024, 04:53 AM
  2014 rear wheel knocking noise dunebuggy_imp 7 981 08-05-2024, 03:33 AM
Last Post: Yata-Garasu_imp
  Front ABS Brake"Rain Stick" noise bflint 3 475 07-12-2024, 08:36 AM
Last Post: Race_ca1
  Fuel pump noise? Ben70_imp 15 1,025 07-16-2022, 12:22 AM
  Valve noise (i think) Maturecheese_imp 6 663 07-08-2022, 03:41 AM
Last Post: 1973cb750
  Brake disc rubbing noise mrded_imp 8 744 08-17-2021, 03:20 AM
Last Post: furious_blue_imp
   Ticking noise from top part of engine Kingkong_imp 40 2,919 03-18-2021, 01:22 AM
  Strange wizzing noise LoyalKhan664_imp 28 2,246 10-02-2020, 05:58 AM
  Lower engine knock airenping_imp 33 2,473 09-20-2020, 12:19 PM
