Opinion on frame damage
Backing up for a minute, the discussion of what's next for your bike assumes that you have the bike in your garage, and that it currently is not in a repair shop, correct?
If not, and it is in a repair shop, good chance that they have already contacted your insurance company to have them come to reinspect the bike.
(11-16-2021, 02:23 AM)Gone in 60_imp Wrote: Backing up for a minute, the discussion of what's next for your bike assumes that you have the bike in your garage, and that it currently is not in a repair shop, correct?
Bike is in the garage, I took it home before I removed the crash bars. The adjuster seemed like a decent guy, was open to the notion that I didn't want it totaled out, but suggested to me that I remove the crash bars and inspect the mounts before we finalized the claim.
(11-15-2021, 07:12 PM)j3gq_imp Wrote: Hello Mx, there are many shades of gray, and your frame is one of them. Many useful comments have already been made. But there is still one aspect which hasn't been worked out. You do not want to invest into this work without 100% insurance that a) the fix will last and b) the symmetry of the frame is preserved after the work is done.
My take, the bike's frame has to be striped of all other parts (that is expensive or time-consuming), another cradle (frame) needs to be build which allows to hold the bike's frame while welding AND allows sub-millimeter measurements of the position of a number of critical points on the frame. Whether your welder tells you this same story (or not) is one way for you to tell about his seriousness.
(11-15-2021, 03:54 AM)MxHansen_imp Wrote:
(11-15-2021, 02:33 AM)Gone in 60_imp Wrote: That crack looks like it's on a weld (middle photo). Is that the case? If so, it's probably compromised now, but maybe a welding shop could repair it. However, if that is indeed the case, your insurance company may elect to just total the bike based on a cracked weld on the frame, while they could see a scrape and minor dent as a cosmetic issue.
That crack is *right on* the weld unfortunately. The crash bar compressed the tube, kinda makes me wonder....what is the point of the crash bar if its just going to thrash the frame. Oh well, I walked away from the crash, grateful for that.
Thank you for the reply.
Mx
Thanks for pointing this out, so far I have been unable to find a welding shop that will even look at the bike, let alone consider what the work would entail.
Mx
*Update*
FWIW, my local chopper shop (read heavily tattooed HD enthusiasts) assure me this is no big deal, and that they can TIG weld this back up so that it is stronger than original build. Should take them maybe an hour, and no need to remove electronic components from bike.?.?
Lots to consider, I appreciate all the help from this forum...sometimes I wish I didn't love this bike so d@mned much. I am the second owner, the original owner only put 300 miles on it and purchased it from a dealer in 2018 who still had it unassembled in the crate at that time.
Thanks again guys.
Mx
Sounds like you've got someone who can fix it. Good news if that's how you'd like to go!
Hopefully this means that the damage is less substantial than I thought. Good luck!
I would at least unplug the ECU. They are expensive. There is still an arc with TIG and MIG welding.
(11-16-2021, 06:07 AM)Lord Popgun_imp Wrote: I would at least unplug the ECU. They are expensive. There is still an arc with TIG and MIG welding.
Thank you, I will absolutely do this if I decide to get it fixed.
(11-16-2021, 05:56 AM)j3gq_imp Wrote: Hopefully this means that the damage is less substantial than I thought. Good luck!
I hope so, its kinda hard to say, I just showed them the same pics I posted here...so...
Have you seen the price on the gauge cluster? It is all circuit board from the looks of it on the fiche. As such I suspect it is pretty sensitive to high currents. I would try and disconnect more than the ECU if possible.
I welded some small brackets to the frame when I was modifying the rear fender and nothing got fried. I didn't disconnect anything on the bike. From my experience, you should be fine welding it up, but it never hurts to be safe!
Good call on the gauge cluster!
(+1) Good call Popgun.
  Black Frame Paint spechg 12 1,101 06-24-2026, 08:12 PM
Last Post: HondaLou
  frame gusset threaded hole question tdbru 0 234 10-27-2024, 11:27 AM
Last Post: tdbru
  remove the valve cover from the frame (ex 2014) Enzofour_imp 20 1,421 12-02-2020, 02:06 AM
Last Post: Enzofour_imp
  Mystery dent on frame? Should I be worried? bertypower_imp 14 1,224 10-04-2020, 02:41 AM
Last Post: bertypower_imp
  2014 cb1100 frame fork stem specs ck1100-smithbros_imp 13 918 04-13-2020, 05:47 AM
  Help With Frame Rails Please Cafe Project_imp 3 382 01-08-2019, 12:17 PM
Last Post: Cafe Project_imp
  tips for busting extremely tight frame bolts? misterprofessionality 54 3,930 10-04-2018, 01:59 PM
Last Post: SportsterDoc
  I need your opinion if you have the 2013 honda cb1100 jae667101993_imp 7 584 04-21-2014, 10:35 PM
