Help With Frame Rails Please
I have my CB in pieces and on a lift. Could some kind person please let me know how level (the angle would be great) that the bottom frame rails (just below where the side stand is mounted) are when the bike is up straight with no rider?
I know it's a pain, but it would be a huge help.
I should have measured this when the bike was whole, I know....
Thanks,
Carl.
(01-06-2019, 11:49 AM)Cafe Project_imp Wrote: I have my CB in pieces and on a lift. Could some kind person please let me know how level (the angle would be great) that the bottom frame rails (just below where the side stand is mounted) are when the bike is up straight with no rider?
Thanks,
Carl.
I can’t imagine how that would matter but the answer is probably something like “fairly level”?
Can I ask why you think that would matter to the degree (pun intended) that a measured angle would be important?
The relative angle between the frame and ground isn’t fixed due to the suspension so I’m struggling to understand how it would matter for any modification. I would think any angle that mattered would be between the frame and the modification, not the ground.
That angle on my bike has changed as I have modified the suspension.
Cafe, will this help? Both lines are straight and parallel, but the ground is not level.
(01-06-2019, 03:18 PM)pekingduck_imp Wrote: Cafe, will this help? Both lines are straight and parallel, but the ground is not level.
Thanks, that's close enough.Level it is.
Thanks,
Carl.
With new front and rear ends, everything is up for grabs; ride height and angle. I wanted the bike to sit and look correct and not handle too badly. I assumed that the frame should sit level and it looks like it does. If the answer was a 5 degree downslope, I would have tried to achieve that. I'm kind of particular, I like things to be right. I could not live with my bike being off with suspension mods. Not everyone is the same (wink emoji).
Having said all of that, it's probably going to end up with it's arse in the air and it's head in the sand and handle like a drunken sailor on shore leave. It will look pretty though.
Thanks for the input.
  Black Frame Paint spechg 12 1,019 06-24-2026, 08:12 PM
Last Post: HondaLou
  frame gusset threaded hole question tdbru 0 219 10-27-2024, 11:27 AM
Last Post: tdbru
  Opinion on frame damage MxHansen_imp 29 2,093 11-16-2021, 11:46 AM
  remove the valve cover from the frame (ex 2014) Enzofour_imp 20 1,282 12-02-2020, 02:06 AM
Last Post: Enzofour_imp
  Mystery dent on frame? Should I be worried? bertypower_imp 14 1,115 10-04-2020, 02:41 AM
Last Post: bertypower_imp
  2014 cb1100 frame fork stem specs ck1100-smithbros_imp 13 864 04-13-2020, 05:47 AM
  Garnish/grab rails Chris Goldson_imp 2 256 01-05-2019, 11:00 AM
  tips for busting extremely tight frame bolts? misterprofessionality 54 3,641 10-04-2018, 01:59 PM
Last Post: SportsterDoc
