Hesitation? Not running smoothly?
Mine has had the stumble/surge for a while, PCV and ECU helped but did not fix 100%, I would like to try this...but would be funny if it reset my ECU to stock default again :-)
It doesn't reset the ECU, but calibrated the TPS. Basically it's telling the ECU what the full open and full closed values are so it can meter the fuel properly. It doesn't change the fuel map or spark curve, just tell it when to start and stop and the gradation in between.
After further review of our wiring schematic, we have a non contact sensor or Hall or inductive. The TPS talks directly to the ECU there is no manual adjustment on the throttle bodies. My GSXR 750 had a manual TPS which could be adjusted. I'm not sure how or if this gets reset but it would make perfect sense that full throttle on and off could synchronize the setup.
I tried this last night even though my bike ran smoothly, and I didnt notice any difference yesterday but today its so much more responsive. In my opinion all our bikes could benefit from doing this.
This also calibrates the hand position sensor(brain). I can't even turn the grip to full throttle with my normal grip. I have to grip at zero throttle with my wrist curved and hand more over the top so that I can go from z to 100% with my hand/wrist turn. I do this a bunch of times then go for a ride. The bike is now a rocket. What happened? My grip at zero has changed so that what seems like my usual hand inputs result in more actual throttle .
(09-25-2014, 01:51 AM)Deanohh_imp Wrote: This also calibrates the hand position sensor(brain). I can't even turn the grip to full throttle with my normal grip. I have to grip at zero throttle with my wrist curved and hand more over the top so that I can go from z to 100% with my hand/wrist turn. I do this a bunch of times then go for a ride. The bike is now a rocket. What happened? My grip at zero has changed so that what seems like my usual hand inputs result in more actual throttle .
Huh
I'm not sure I understand what you are doing either. Are you saying that you have trained the TPS to think that partial throttle is now full throttle? If so, could you go through the exact process once more?...
I'm not sure how it would know where your hand is, only what constitutes fully open or fully closed throttle.
Thanks,
Thanks,
Thanks, My brain (or yours), not the bikes brain.
Thanks,
Now I get it...muscle memory, like "Wax on, wax off", or, in this case, "Throttle on, throttle off" Wink
Thanks,
Thanks,
Its a method Deanohh uses, he's been around for a whileROFL
  PCV, autotune, not running properly TK421_imp 9 629 07-09-2022, 10:49 AM
Last Post: TK421_imp
  1 cylinder running rich? frank_imp 33 1,920 01-05-2021, 10:35 PM
  What kind of oil is everybody running tate_imp 108 8,574 05-25-2020, 05:47 AM
  Does bike know when it's running? AZrider_imp 26 1,625 07-06-2019, 03:18 AM
  Running rough sethrose_imp 6 905 08-24-2018, 06:31 AM
Last Post: sethrose_imp
  Low end sputter, hesitation NHCB_imp 131 10,529 06-30-2018, 08:22 PM
Last Post: itstuantran_imp
  2013 running rough huxley2_imp 19 1,064 12-30-2017, 02:50 PM
Last Post: flynrider
  Deactivating front running lights rsp123_imp 17 1,116 08-06-2016, 10:40 PM
  Running in procedure J.W._imp 8 612 08-05-2015, 12:11 AM
Last Post: ClassicVW_imp
