2013 running rough
Guys, don’t post often.
Got a 2013 cb1100. Bought new in mid 2014, so had it about 3 1/2 years.
Don’t ride often, it has 410 miles on it. Have changed the oil couple of times,
New battery, Staintune pipe, nothing else. Ride it once every 4-6 weeks I’d say, but not far, as you can tell.
Problem - starts great, tends to run good in 1st. Warm it up, shift to second, it is stumbling and missing, but wind it up a little and seems better. Almost seems like running on 3 cylinders until cleans up.
Done this last 2 or 3 times. What could this be? Bad gas, but use no ethanol and stabilizer. Ignition or fouling plug? Take to dealer?
I know, ride it more, run it harder maybe. Just don’t want to have to walk.
Any ideas or comments/suggestions?
It is complaining about not being ridden!
Pull the plugs (14 mm socket) and see how they look
No codes?
My theory on keeping injectors clean is to run WOT on a regular basis.
Take it out for 100+ miles and see if it improves.
Stale gas. Try using up what's left in the tank, then refill with fresh and see if that doesn't clear things up. A little Seafoam or fuel injection cleaner in the tank wouldn't hurt either.
(12-02-2017, 05:25 AM)LongRanger_imp Wrote: Stale gas. Try using up what's left in the tank, then refill with fresh and see if that doesn't clear things up. A little Seafoam or fuel injection cleaner in the tank wouldn't hurt either.
Good thought. May also be a bit of water in the bottom of the tank.
I'd dump about 5 -7 oz of seafoam in it, in a fresh tank of gas, and take it out for a good spin, and see if that doesn't clear it up.
My goodness 410 miles in 3 1/2 years. No wonder it isn't running well.
Most motorcycles are not worn out, they are neglected to death.
Good suggestions guys, will try all of the above.
+1 with bad gas. Wind that puppy up!
Yep, it sounds like a prescription of fresh gas + seafoam + rev therapy might be all that your CB is in need of. Good luck.
The condition you describe sounds very similar to what I experienced about two years ago, but much worse. You most-likely have an issue with bad gas, like all of the other replies are stating, but I suggest that AFTER you get fresh fuel in it you perform the throttle position sensor reset: With the motor off, and the key on, slowly twist the throttle from full closed to full open slowly, and then back to full closed, slowly. Repeat two more times. Start your motor - that's all there is to it.
Good luck.
Thanks to all for the suggestions. Will report back soon. And Dave, will also do the reset, and see if it helps.
I have the old gas out, really strong and foul smelling. Put in fresh gas and seafoam. Rode about a mile and a half, still same problem. Suspect I need to ride it further and a little harder to give the fresh gas a chance.
  Idle a little rough and miss fire when revved johnnyH_imp 3 435 09-15-2024, 12:16 AM
  Honda CB1100 Rough Idle Solution dickie1951_imp 56 4,493 09-06-2023, 01:36 AM
  PCV, autotune, not running properly TK421_imp 9 696 07-09-2022, 10:49 AM
Last Post: TK421_imp
  Hesitation? Not running smoothly? mininsx_imp 74 6,004 01-26-2022, 10:49 PM
  1 cylinder running rich? frank_imp 33 2,214 01-05-2021, 10:35 PM
  What kind of oil is everybody running tate_imp 108 9,784 05-25-2020, 05:47 AM
  Does bike know when it's running? AZrider_imp 26 1,858 07-06-2019, 03:18 AM
  Running rough sethrose_imp 6 966 08-24-2018, 06:31 AM
Last Post: sethrose_imp
  Deactivating front running lights rsp123_imp 17 1,258 08-06-2016, 10:40 PM
  engine rough after oil change....? eric_imp 12 911 04-06-2016, 06:16 AM
Last Post: eric_imp
