 Rotella T5 10w30 + CB1100 = HAPPY!!!
i run Purolator i have seen the inside of engines that used only the purolator filters and at 300k the rod and mains looked almost new still honda have a very good filter too
[url=https://www.amazon.com/gp/product/B01G6FPCTG/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1]https://www.amazon.com/gp/product/B01G6F...UTF8&psc=1
(06-11-2023, 10:23 PM)m in sc_imp Wrote: 4.2 gallons? lol
i pay 16bucks for a honda filter w a crush washer and about 10 bucks a qt, for full synthetic. far as i know, no one has ever had an issue with a honda filter regardless of where it was made. but to each their own.
Typo... Meant 4.2 quarts. But 4.2 is still wrong. And so is charging $20 for a Chinese filter! Lol
T5 10w30 is an excellent oil for the CB1100.
(06-12-2023, 07:56 AM)m in sc_imp Wrote: 4.2q is fill from dead empty never run. just fyi.
they are made in multiple locations but run whatever you wish, they will all work well. in todays world, anything is better oil and filter wise than it was 20-30-50 years ago.
Nope.
So per the manual, it's 4.1 US quarts when changing the oil filter.
That's incorrect. It's less than 3.9 quarts.
There's a video on Youtube where a guy dumps 4 quarts into his Cb1100 and it completely fills the sight-glass.
There's another one where the guy puts in 3.5 quarts and then tops it up until the sight-glass is accurate.
My experience is in line with the second guy. Put in 3.5 quarts, while on the center stand, and then gradually top it up until the sight glass is where you want it.
4 quarts is too much. 4.1 quarts is way too much... lol
I am talking about the 2014 Standard, aka the "black one". I can't speak to other model or year variations.
But the manual for the 2014 is incorrect. Even the Honda shops that follow the manual are overfilling these bikes.
Ps. Im using the Fram PH6017a. Another typo... No wonder I got D's in accounting! Good lord I hated that class...
I have more often than not found that the quantity of oil in owners manuals for motorcycles is excessive. Sometimes it probably makes no difference but on others this excess oil ends up in the airbox. This is the case for all brands and models I've owned from BMW, Kawasaki, HD, Honda, Yamaha, Guzzi, and on.
When changing oil on my 2014 CB1100 I warmed it up first then let the oil drain on its center stand while I removed the filter. After it completely stopped dripping around 10 minutes later I installed the new filter and put the plug back in finger tight, parked it on the side stand, removed the plug and over 1/2 a cup more came out. Plug back in, tip the bike to the right and hold it there for 10 seconds, back up on the center stand, removed the plug and almost another 1/2 cup drained out over night.
Next day I added 3.5 qts, started the bike letting it idle for a minute, then checked again a few minutes later and had to add some (but not all) of the remaining 1/2 qt to get it to just below the top of the sight glass. So I'm saying probably around 3.75 qts puts mine near max.
On center stand, sight glass = truth.
My approach is consistent generally with what m in sc and Ollie said already.
(06-12-2023, 12:37 PM)GoldOxide_imp Wrote: On center stand, sight glass = truth.
Agreed.
It's not necessary to disassemble an entire engine to discern the proper amount of oil needed to fill a CB1100... LOL
But it's important to know that the Owners Manual for the CB1100 is inaccurate.
If the correct fill quantity was known to be less than 4 quarts, why did people on this forum (and my Honda dealer) continue to preach (and install) 4+ quarts?
And until this thread, I haven't seen anyone else addressing the inaccurate manual or the correct fill amount.
If this was common knowledge before, then please pardon me for resharing common knowledge that my dealership and I initially missed.
Hopefully others will be able to avoid the same mistakes.
For the pro mechanics here who already know everything about the CB1100, thanks for your patience while us amateurs figure it out as we go.
It's a very strange thing, Yata-Garasu. I'm not saying your report is incorrect; but, to the best of my knowledge, you are the only person to have reported this phenomenon.
I have a 2011 model and I have always put 3.9 litres (or 3.88005 US quarts) of oil in the crankcase when I change the oil and filter. That does not overfill the bike. [url=http://cb1100forum.com/forum/showthread.php?tid=17955&pid=318810#pid318810]As previously noted, the workshop manual for the 2013-2016 says that the required amount of oil is:[ul] [li]3.8 litres or 4.0 US quarts or 3.3 Imperial quarts after draining;[/li] [li]3.9 litres or 4.1 US quarts or 3.4 imperial quarts after draining and replacing the oil filter;[/li] [li]4.9 litres or 5.2 US quarts or 4.3 Imp quarts after disassembly of the engine)
[/li][/ul] Something's going on. But what?
(06-12-2023, 06:19 PM)Cormanus_imp Wrote: It's a very strange thing, Yata-Garasu. I'm not saying your report is incorrect; but, to the best of my knowledge, you are the only person to have reported this phenomenon.
The Honda dealership overfilled it too. And sold me a new fill cap and gasket when I noticed oil dripping from the fill cap... lol
The dripping stopped when the overfill condition was corrected.
I'm being transparent about my experiences so that others might avoid the same mistakes. .
I doubt I am the first person to overfill... Apparently I am the first one to admit it here.
And T5 10w30 is still an excellent oil in my CB1100, even though it doesn't say Honda or MA anywhere on the jug.
Others have overfilled. Me included. No-one has previously claimed the user and service manuals are wrong.
I reckon you're right to use the sight glass as it's got to be the most accurate way to make sure the engine has the right amount of oil. Seems to me, though, that accuracy may be affected by even the slightest slope.
Kudos to Lord Popgun for posting the amounts the first time around. I merely verified them in my 2010 user manual and in an online version of the 2013-16 workshop manual.
   Rotella T6 -> 5w40 vs 15w40? Yata-Garasu_imp 28 2,421 08-02-2024, 11:36 AM
Last Post: Ollie
  10w30 vs. 10w40 Boonetown_imp 30 2,697 07-31-2024, 11:05 AM
Last Post: Pauley
  Rotella T6 - Now in 10W30! Yata-Garasu_imp 10 948 10-10-2023, 10:39 PM
   Actual Oil Capacity of the CB1100??? Yata-Garasu_imp 43 3,477 07-26-2022, 11:26 AM
   front suspension oil change CB1100 EX 2015 (23700 kms). recommendations ?. Alfgaxatico_imp 7 686 11-23-2020, 07:34 AM
Last Post: Alfgaxatico_imp
  Shell Rotella Snythetic 5w40 oil in CB1100 capttwb136_imp 38 2,605 09-04-2016, 08:47 PM
Last Post: capttwb136_imp
