Suspension mods started
Ohiorider, you could join the flow to Imgur or Postimage.
(09-13-2017, 03:58 PM)Cormanus_imp Wrote: Ohiorider, you could join the flow to Imgur or Postimage.
Thanks for the tip! I've signed up for Imgur, though haven't attempted to upload any pix yet.
I'll also be looking for a simple-to-use app that will allow me to move all the individual pix and albums I have stored on Photobucket to another host.
Bob (Ohiorider)
That would be a good find, although it would be better if it could go through this site and update all the links. The most infuriating thing about Photobucket's decision is that effectively all those photos have been lost.
(09-15-2017, 01:22 PM)Cormanus_imp Wrote: That would be a good find, although it would be better if it could go through this site and update all the links. The most infuriating thing about Photobucket's decision is that effectively all those photos have been lost.
Not only on this forum, but on any forums that used the IMG links to post individual pics. It's a mess.
Bob
Well, getting closer! I wimped and decided to let an independent shop install the Traxxion Dynamics fork kit. A good friend and riding buddy and I pulled the forks, and took them to the shop, after purchasing a new set of Honda fork seals and sliders (just in case.) I picked up the forks with kit installed this afternoon.
All that's left now is to reinstall the forks and the other vital parts, like the front brake calipers and wheel.
As I said before .... fingers crossed that this modification will work for me.
And even if not perfect on the first pass, there's still fork oil weight and adjustments to the RaceTech emulators that can be made. I suspect if I weighed 200-210 instead of 155-160 pounds, the suspension on the CB would have been more compliant for me. I've ridden and owned older Airhead Beemers that, though mushy, rode like a limo over bad roads. And these Beemers weighed less than the CB1100, so it isn't all about bike weight.
As of today:
20 Weight fork oil
125 mm below top of fork when fully compressed and prior to installing the spring (non progressive.)
stock spring and spacer replaced with kit parts.
stock damper rods replaced with kit dampers.
This is probably way more than anyone wants to read, but this is an informative link on damper rod forks vs those with emulators installed. May be propaganda! But a good read.
http://racetech.com/html_files/DampingRodForks.HTML
Bob
Probably took more time to write that post than to reinstall the forks/wheel/calipers. Very very simple quick job.
(09-19-2017, 09:50 AM)PowerDubs_imp Wrote: Probably took more time to write that post than to reinstall the forks/wheel/calipers. Very very simple quick job.
Does the post upset you? You know, you don't have to read it. How hard is it for you not to comment?
Huh Huh Huh
Yikes!! That's the last time I joke in your threads...
Sorry for my previous comment. I was obviously taking myself way too seriously.
Bob
  CB1100 parts discontinuation has started bflint 24 2,390 11-12-2020, 12:24 AM
Last Post: Bazbro_imp
  Suspension settings Whippa_imp 9 863 10-02-2020, 10:49 PM
   CB1100 mods Timpo_imp 175 12,884 04-10-2020, 01:48 AM
Last Post: quiffy_imp
  Great Day to Ride? Seat Mods Whippa_imp 14 2,397 01-28-2020, 06:02 AM
Last Post: Whippa_imp
  I need slight ergonomic mods ohiorider_imp 1 244 04-22-2019, 09:08 PM
  How common are wheel & suspension upgrades? Syscrush_imp 8 706 08-09-2017, 12:22 PM
Last Post: 736cc_imp
  Getting close to suspension mods ohiorider_imp 11 1,319 08-09-2017, 08:45 AM
Last Post: Syscrush_imp
  Wish me luck! (suspension upgrade) ohiorider_imp 5 522 07-14-2017, 02:49 AM
  Suspension the Ferret 22 1,380 05-04-2017, 07:34 AM
  Front suspension? pechorin75_imp 70 6,293 03-20-2017, 01:34 PM
Last Post: IndianRider_imp
