Tank slapper bent my rear brake lever
It would be easy to pile on and chastise you for running a bald tire, and I'm not doing that so don't take offence, but this incident could have crippled you or worse.
Please, only run good tires with lots of tread Thumbs Up Thumbs Up
(04-24-2018, 03:58 AM)EmptySea_imp Wrote: What tires are you running?
Stock Bridgestones, but I'm having a set of Pirelli Sport Demons put on this week.
https://www.bing.com/videos/search?q=wat...ORM=VRDGAR
I did not care for the stock Bridgestones at all !!!
I've only had a high speed wobble once in my life.
Coming into my home town, rounding a big sweeping curve, entering about 90mph on my 1973 CB350 at night with my friend on my tail in his yellow VW.
We would race alot and those two were about equal in speed. ;-)
It was a rear wheel wobble for me, pretty scary but I came out of it and lived to ride another day ;-)
I always thought it was because I unweighted the rear wheel de-accelerating coming into that curve that caused it.
I've always said, getting married probably saved my life!
The Bridgestones seem to like to follow pavement grooves more than the Michelins I usually run. I wonder if that tendency contributes to the headshake. Just a thought.
New tires are on and I feel like I'm tip-toeing through traffic instead of dragging my feet across the pavement.
On the way to my local stealership I set the stage for a quick experiment. I let go of the bars (at a safe moment) and felt a very slight wobble in the front. Grab the bars and wobble goes away. Similar to something I felt awhile back that I attributed to local road conditions. I repeated the experiment with new tires and as I'm sure you've guessed, no wobble.
i have no doubt that the front tire was the origin of the instability....but I still don't know what was the catalyst for violent wobble.
Probably some butterfly poop on the road :-)
  question on rear brake pedal arm tdbru 13 2,026 04-28-2025, 06:53 PM
Last Post: rdprdp01
  Arthritis and Clutch Lever jodytek_imp 37 3,270 04-18-2021, 03:48 AM
Last Post: michael1954
  Question re CB1100 rear brake caliper ohiorider_imp 14 983 07-12-2019, 07:12 AM
Last Post: ohiorider_imp
  Whitehouse tank dimensions vs CB750 tank dimensions spartanheed_imp 2 324 04-27-2019, 05:40 PM
Last Post: spartanheed_imp
  Arm > hand > lever relationship Haggard Rider_imp 9 735 03-12-2019, 12:01 PM
  Rear brake squeal B-rad G_imp 4 436 07-21-2018, 07:44 AM
Last Post: Nortoon_imp
  Clutch and Brake Lever Adjustment retroman_imp 6 551 06-18-2017, 12:53 PM
Last Post: NightRider_imp
  Rear brake ABS on a 2013? cb4me?_imp 3 349 04-27-2017, 09:53 PM
Last Post: cb4me?_imp
  2017 Triumphs/Bent Brake Lever/Motocycle lift etc...a miss-mash of comments Frulk_imp 12 872 03-14-2017, 05:19 AM
  Bent brake lever and an early lesson JMA_imp 26 1,701 08-13-2016, 03:31 AM
Last Post: Ulvetanna_imp
