question on rear brake pedal arm
On the used CB1100 I picked up, a 2014 std model, the tip of the rear brake pedal arm tips in right at the end.  I see no scuffing on it like it got bent.  and bending right at the tip of the arm wouldn't be where it would bend in a tip over anyway, I don't think.  So the question I am asking is about that end of the rear brake pedal arm.  Is it suppose to tip in right at the end of the arm?  or is the arm straight the whole way, which would tell me that on my bike, the arm got tweaked somehow.
thanks in advance for a reply,
tdbru
(04-26-2025, 10:38 PM)tdbru Wrote: On the used CB1100 I picked up, a 2014 std model, the tip of the rear brake pedal arm tips in right at the end.  I see no scuffing on it like it got bent.  and bending right at the tip of the arm wouldn't be where it would bend in a tip over anyway, I don't think.  So the question I am asking is about that end of the rear brake pedal arm.  Is it suppose to tip in right at the end of the arm?  or is the arm straight the whole way, which would tell me that on my bike, the arm got tweaked somehow.
tdbru
Hmmm....  methinks I have a bent one.  well, one more project.  straighten it out.
tdbru
tdbru
Can you post a picture so we can see what you mean?
2017 CB1100 EX | 2024 Africa Twin AS ES DCT
I'll give a go at posting a photo.
-tdbru
evidently I don't have permissions to upload a photo. sorry.
(04-27-2025, 01:31 PM)tdbru Wrote: I'll give a go at posting a photo.
-tdbru
rpdrpd1, is there a file size limit?  I do the "click or drop some files here to upload..." and the copy bar seems to work but no file is ever attached.
Here's what mine looks like if this is the angle you need. If not tell me which angle and I'll post more pics
[Image: 4agGYKM.jpg]
tdbru, the file size limit for photos is 2MB. If your picture file is larger than that, you'll have to compress it. If it's an acceptable size, after uploading, you should see a request to attach it to the post at the bottom of the Attachments box. If that doesn't work, rdprdp01 will have to respond.
(04-27-2025, 02:01 PM)Cormanus Wrote: tdbru, the file size limit for photos is 2MB. If your picture file is larger than that, you'll have to compress it. If it's an acceptable size, after uploading, you should see a request to attach it to the post at the bottom of the Attachments box. If that doesn't work, rdprdp01 will have to respond.
ok, I think my file was too big.  I made it smaller.
Attached Files Thumbnail(s)
I suspect your file is larger than the limit i have set or the Internet connection you are using has problems and is timing out before the upload is completed. May I trouble you to tell me how big is your file?
I prefer to use Imgur to upload images but I know most Members prefer drag and drop. Help me calculate what that upload size should be by sharing the size of your photo. Thank you.
2017 Honda CB1100 EX
Rdprdp1,
my phone photo size was 3.8M.  I used paint to scale it to ~780K and it still has enough detail.  Now that I know that 2M is likely fine.  I'll just scale to that.  my phone dumps photo files that run between 3.5M to 4.5M or so.  I'll simply scale them from now on to 2M or less.
thanks,
tdbru
That pedal looks bent to me. The bit your toe rests on seems twisted forward and left, if that makes sense.
Here's mine from that view
[Image: ZLRAVVz.jpg]
  rear shocks question tdbru 7 1,033 08-10-2025, 07:42 PM
  Question re CB1100 rear brake caliper ohiorider_imp 14 986 07-12-2019, 07:12 AM
Last Post: ohiorider_imp
  Rear brake squeal B-rad G_imp 4 443 07-21-2018, 07:44 AM
Last Post: Nortoon_imp
  Tank slapper bent my rear brake lever egleaves_imp 27 2,143 04-26-2018, 04:12 AM
Last Post: chync_imp
  Rear brake ABS on a 2013? cb4me?_imp 3 350 04-27-2017, 09:53 PM
Last Post: cb4me?_imp
  Rear axle torque question. jdvalero_imp 10 943 03-21-2017, 09:29 PM
Last Post: jimgl3_imp
  That rear brake Insolentsquid_imp 46 2,687 11-01-2014, 01:24 PM
Last Post: old blue_imp
  Final Rear Brake update! Jayimpalaman_imp 9 788 08-30-2013, 05:20 AM
Last Post: AzBob_imp
