Anyone know the size of the Brake Light Bulb?
dBuster_imp Offline
Threads: 7
RE: Anyone know the size of the Brake Light Bulb?
We have 90% florescent compacts, the daylight models only and the other 10% are led bulbs, more expensive but so much brighter. I can use a 402 watt equivalent led bulb where in the past I would need a 60 watt traditional or cfl bulb. I plan on switching over to led as much as I can and as funding permits. With the exception of like bedroom and living room as they will remain the daylight cfl bulbs.
Now those that take time to get bright I have found to be the cheaper models of cfl.
Sent from my XT1055 using Tapatalk
05-06-2014, 11:56 PM
Red Mist_imp Offline
Threads: 12
I bought an LED bulb that looked identical and the light output was nothing like the stock incandescent 1157. I didn't use it. Don't need to be rear-ended. Brighter is better.
05-07-2014, 01:45 PM
Huladog_imp Offline
Threads: 23
Installed that SuperBright LED bulb in my Lucas-style tail light since the regular bulb was weak and the reflector surface isn't that good.
There is some info somewhere on the SuperBright site explaining why the red output light works better than the bright white. Sounds counter-intuitive but had to do with wavelengths and stuff.
Aloha,
Huladog
05-07-2014, 03:42 PM
Ridem32_imp Offline
Threads: 51
Huladog post link to superbright
05-07-2014, 03:59 PM
Elipten_imp Offline
Threads: 13
The white LED lights look pink due to being so bright when seen through the tail light plastic. So they recommend red color.
05-08-2014, 12:32 AM
Huladog_imp Offline
Threads: 23
Here's the info from SuperBrightLEDS site
#26
Found it:
http://www.superbrightleds.com/carbulb_n...turnsignal
"Which Color LEDs should I use?
For best results the LED color should be the same as the lens color or if bulb is behind a clear lens, use the appropriate color for turn and brake light functions. As an example: a red lens will filter out all but the red portion of the light so if the light is all red, none or very little light will be blocked by the lens. The light from a White LED contains very little light in the red portion of the visible spectrum so most of the light would be filtered out by a red lens."
Aloha,
Huladog
05-08-2014, 06:12 AM
  Is the 2014 Deluxe seat a unique size and/or fit? LucienLeFranc 12 778 03-29-2026, 10:31 PM
Last Post: LucienLeFranc
  Preferred Brake Light Bar Farkles TooManyBikes_imp 12 1,501 03-18-2024, 02:46 AM
  Tube type/size KubaGrom_imp 12 1,008 02-27-2023, 02:44 PM
Last Post: Mafd2_imp
  LED headlight bulb fitment Gone in 60 13 1,128 07-22-2019, 09:19 AM
  Pulsing brake light modification Cqrlm911_imp 11 1,177 06-08-2019, 12:43 PM
Last Post: LikeAfox_imp
  3-wire to Connector for Brake Light for Custom Fender Eliminator x(why)z_imp 5 545 02-05-2019, 12:40 PM
  Attaching led strip light to running light? The Beast J7_imp 6 711 06-28-2018, 12:58 PM
Last Post: The Beast J7_imp
  Wheel Size Change Saga and Amazing/Rare Customer Service from a Vendor chync_imp 4 438 03-12-2018, 08:27 AM
  Tire Size Question. BackroadsRider_imp 3 439 09-29-2017, 07:37 AM
Last Post: BackroadsRider_imp
  The right size saddlebags the Ferret 117 8,657 06-17-2017, 03:42 AM
Last Post: ChiefJP_imp
