Arrow Exhaust / PC V Installed
thessler3_imp Offline
Threads: 7
RE: Arrow Exhaust / PC V Installed
Note that Arrow has posted a dyno chart for the CB1100 stock, with slip-on and with baffle removed. With the baffle in, horsepower is very close to stock. With baffle removed, you get a small gain right at the top.
I am happy with the Arrow, because I was looking to save weight and make just a little more noise.
I don't want to add PCV if I do not have to. They require blocking the O2 sensor, which defeats the stock ECU ability to adjust air/fuel ratio. I like my 56mpg on the highway.
If you want to make a lot more power, you have to remove the cat. Arrow does make a nice looking header with no cat.
03-20-2015, 03:11 AM
uscgmac_imp Offline
Threads: 23
I installed a Yoshimure RS3 slipon on my 2014 standard. No need for a PC V unless I'm changing out the head pipe without a cat and changing to a K&N or more free flowing air filter. The stock ecu is more than capable for compensating the air fuel ratio on today's fuel injected bikes with just a slip on installed.
03-20-2015, 06:58 AM
lola_imp Offline
Threads: 18
Those torque numbers are very good! your tuner did a good job maximizing low end and midrange on the power band.
03-20-2015, 07:08 AM
mjezek_imp Offline
Threads: 6
(03-20-2015, 06:58 AM)uscgmac_imp Wrote: I installed a Yoshimure RS3 slipon on my 2014 standard. No need for a PC V unless I'm changing out the head pipe without a cat and changing to a K&N or more free flowing air filter. The stock ecu is more than capable for compensating the air fuel ratio on today's fuel injected bikes with just a slip on installed.
I am sorry, but i do have a question to your statement .... how does the stock ECU know that there is aftermarket slip on installed, especially, if the O2 sensor is before the cat ... ? Or in other words, an after market slip on is good for sound and weight saving, but unless you change the fuel mapping, nothing will change the HP/Torque output.
Not sure if our detuned 1100 motor really cares about having less "back pressure from the exhaust " .... when there is still the cat between ....HeartHeartHeartHeart
03-20-2015, 08:35 AM
uscgmac_imp Offline
Threads: 23
There is still less restriction and more flow regardless of the cat being there. The ecu will compensate in open loop. Not so much in closed loop. The diffrence is not great but yes there is a diffrence and the air fuel ratio will change. Its much more prevalent with no restrictive cat and a after market air filter which will really open it up and make the bike run lean in which case you would need the fuel processor.
03-20-2015, 10:33 AM
JF Coastal_imp Offline
Threads: 23
Anyways.... I'm loving the new setup. All of this conversation is over my head, bike is performing great even if the mod was necessary or not. Here's a new photo. If anyone is interested in seeing.. I also, just got done installing the fender eliminator kit and some new rear turn signals.
[Image: c773d330eb80a2233e7f3a39b1333815.jpg]
03-21-2015, 04:56 AM
lola_imp Offline
Threads: 18
Lookin sharp!
03-21-2015, 05:31 AM
mjezek_imp Offline
Threads: 6
agreed ! very simple and clean !
03-21-2015, 05:50 AM
HikerToo_imp Offline
Threads: 114
What about video, you can't hear pictures!
03-21-2015, 06:34 AM
Threads: 23
Thanks guys !! Yup, I like clean simple lines. Hikertoo, i'll get some video for you. Just give me a lil time.
03-21-2015, 09:27 AM
  Has anyone installed a louder horn? Doug Shepard_imp 36 2,844 01-29-2024, 05:14 AM
  Arrow Slip-On Thoughts le_penseur_imp 84 5,756 05-15-2023, 05:20 AM
Last Post: mrded_imp
  I installed the Emgo Reverse Cone Universal slip on danieljrmurray_imp 2 398 05-15-2023, 04:29 AM
Last Post: 3rd Gear Steve
  Arrow exhaust. Mixagon_imp 11 951 10-25-2022, 01:56 AM
Last Post: ymtnpoah11_imp
  Arrow full exhaust gretle_2.0 2 359 05-17-2022, 11:38 AM
   Traxxion AR-25's installed... great upgrade!! Sparky80_imp 2 357 10-18-2021, 12:38 AM
Last Post: Sparky80_imp
  loose the arrow jimgl3_imp 33 2,116 08-30-2021, 11:14 PM
  Arrow slip on mufflers DougsZ28_imp 15 1,275 05-13-2021, 04:09 AM
  Hepco & Becker Luggage Installed CaptainChris_imp 61 4,096 12-12-2020, 11:51 PM
  Arrow full system exhaust tsmetjen_imp 19 1,431 07-29-2020, 03:46 PM
Last Post: tsmetjen_imp
