Thinking about a wider rear tire
rboe Offline
Phoenix, AZ
Threads: 64
Likes Received: 6 in 2 posts
Likes Given: 7
RE: Thinking about a wider rear tire
Along with size, the tire profile is important too. My old Quota went from so-so handling to "flickable" went I went to a more rounded profile. She would drop into corners like no mans business. The Griso is certainly more flickable, more so than the CB (but not sport bike quick) but when it comes to the twisty bits the big old Quota could show the CB a thing or two.
07-26-2013, 12:50 AM
CA200_imp Offline
Threads: 42
the ferret is right, changing size always distorts the shape of the wider tire and will mean the bike will handle different.
It is never a +.
silascopathic_imp Offline
Threads: 28
Lots of things to consider. glad i started this thread rather than just jumping into it
07-26-2013, 01:00 AM
thumper_imp Offline
Threads: 7
(07-26-2013, 12:50 AM)CA200_imp Wrote: the ferret is right, changing size always distorts the shape of the wider tire and will mean the bike will handle different.
It is never a +.
It's also putting a level of stress on the entire tire that was never intended in the design:
The bead: Pinching a tire much more than intended (putting a tire meant for a 5.5" rim onto a 4" rim), would cause a huge amount of stress on the bead area, and the bead itself would not mate to the rim as required.
The sidewall: Tire manufacturers spend huge time and $$ designing their tires. The sidewall is meant to stand at a certain angle when mounted on the rim. Just imagine how far off that sidewall aspect would be after pinching that large tire onto a small rim.
The internal belts, bands, etc: Bending the tire farther than designed could cause internal tears and damage to the reinforcing aspects inside the tire, that would never be seen until catastrophic failure.
I could go on and on about this topic.
07-26-2013, 03:50 AM
Ack-CB11_imp Offline
Threads: 46
(07-26-2013, 01:00 AM)silascopathic_imp Wrote: Lots of things to consider. glad i started this thread rather than just jumping into it
That's always been my mistake. It's most likely overkill anyway, unless you do track days. Maybe just find a pair better then the 205's.
All this talk about wider wheels, I just remembered you would need this: http://cb1100forum.com/forum/showthread.php?tid=876
07-26-2013, 06:24 AM
Threads: 28
you guys are great resources!! that's why i love forums!!
07-26-2013, 07:21 AM
The Spaceman_imp Offline
Threads: 42
Right after I got the bike a guy was checking it out in front of Cycle Gear. He said it would look better with a 180 or 200 rear.at tire. Frankly I think he missed the point of the bike altogether. Its not supposed to be a super-sport.
07-26-2013, 07:29 AM
Threads: 28
hahahahahahahahaha ^^^^
07-26-2013, 07:34 AM
DAC Offline
Threads: 17
Likes Received: 12 in 6 posts
Likes Given: 12
(07-26-2013, 07:29 AM)The Spaceman_imp Wrote: Right after I got the bike a guy was checking it out in front of Cycle Gear. He said it would look better with a 180 or 200 rear.at tire. Frankly I think he missed the point of the bike altogether. Its not supposed to be a super-sport.
This.
07-26-2013, 12:03 PM
Jim21680_imp Offline
Threads: 4
This probably isn't true, but I would hope any good service shop would refuse to mount a 180 tire on a 4" rim. I wouldn't even risk a 160. Now, if going to a 150 gave me better or more diverse tire options, that's definitely something I would consider (sadly, it doesn't Sad ). But I would be really weary about going over a +10 on the tire width. Good luck to you Sil, keep us posted about what you decide, and how it works out.
07-26-2013, 12:19 PM
  Wider handlebars, Tracker style. JLEECB 18 1,916 05-16-2021, 09:31 PM
Last Post: Zee9_imp
  Thinking of a new gadget... Csory_imp 296 19,591 07-14-2020, 12:06 AM
  Goldwing Rider Pegs (wider than stock ones) Huladog_imp 17 1,164 06-30-2016, 03:42 AM
Last Post: Papa Weeley_imp
  Thinking about belt conversion Ralph_imp 12 1,131 10-19-2015, 08:41 AM
Last Post: Ralph_imp
  Givi Rear Rack vs. Honda OEM Rear Carrier lagoje_imp 29 1,899 04-24-2015, 06:03 AM
Last Post: specialist8
  larger rear tire aquasition_imp 26 1,833 11-04-2014, 11:29 AM
Last Post: jose_imp
  Thinking about gaiters the Ferret 10 737 08-06-2013, 02:04 PM
Last Post: BuffaloBill_imp
