Yoshimura RSC full exhaust rusted in less than a year
Elipten_imp Offline
Threads: 13
What brand and model is that light, and how did you mount?
03-30-2015, 02:25 PM
CIP57_imp Offline
Threads: 68
RE: Yoshimura RSC full exhaust rusted in less than a year
Greg, it seems to be the outside down pipe, are they all doing it or just that one pipe. I mentioned to ES to put a fender extender when he bought his Yoshi, mine is pitting in the middle from road debris.
03-30-2015, 09:16 PM
Greg_imp Offline
Threads: 8
(03-30-2015, 09:16 PM)CIP57_imp Wrote: Greg, it seems to be the outside down pipe, are they all doing it or just that one pipe. I mentioned to ES to put a fender extender when he bought his Yoshi, mine is pitting in the middle from road debris.
Steve, it's my two outside pipes and only on the forward facing surfaces. It could only be caused by something in the air ... maybe bugs that burned up while degrading the finish? I'm stumped.
03-31-2015, 12:21 AM
CIP57_imp Offline
Threads: 68
The two outside?? I run hotter plugs on my GS1100 on the two outside cyl because they run richer and colder than my inside cyl. It looks like this is happening from the inside. I'm going to take a plug reading if I have the tank off.
03-31-2015, 12:28 AM
Greg_imp Offline
Threads: 8
(03-30-2015, 02:25 PM)Elipten_imp Wrote: What brand and model is that light, and how did you mount?
Elipten, they're Clearwater Darla LEDs. I posted about them [url=http://cb1100forum.com/forum/showthread.php?tid=3176&pid=78733#pid78733]here. That post was two weeks ago but I took the pictures 5 months ago and the pipes weren't showing any rust then.
03-31-2015, 12:37 AM
DGShannon_imp Offline
Threads: 29
(03-30-2015, 02:14 PM)Rebel73_imp Wrote: So the stainless steel pipes shouldn't rust? Would there be any issue with black pipes? I'm looking at the Moriwaki black 4-2.
Could be. Regardless of what underlying material the pipes are made from, the "black" is going to be some sort of coating that will likely degrade over time.
03-31-2015, 05:15 AM
Elipten_imp Offline
Threads: 13
Yep Clearwater, expensive but superb quality. Been looking for my BMW for a set of extra lights. Got the money but struggle spending that much on lights. Guess I got to man up. Guess if I put it on 2 of three bike I won't cry too long.
03-31-2015, 10:08 AM
Headbanger02_imp Offline
Threads: 4
I'm looking at the yoshimura RSCV full exhaust black stainless steel, doe's anybody have a set of these, I'm curious to how the coating will hold up, any advice maybe, I'm not a diehard all weather rider, I don't ride it when the roads are wet, I ride for an hour most days when the weather is awesome out.
04-26-2015, 03:40 AM
Toddman_imp Offline
Threads: 6
I'm new here but I'd like to chime in. Been riding for about 40 years and have had more than one set of black headers. They just need to be painted when this happens (and it's going to happen). One possibility exists that when they were installed, they weren't cleaned before they were cured. Grease/oil from your hands will eventually lead to this if heated and allowed to cook onto the pipe surface. The fix is easy enough though. Take them off and sand lightly. Shoot them again with heat paint with a thin two coats. After you install them, clean where they were touched and go for a ride. They will smoke a bit at first and they will look brand new too.
04-27-2015, 12:29 AM
CIP57_imp Offline
Threads: 68
(04-27-2015, 12:29 AM)Toddman_imp Wrote: I'm new here but I'd like to chime in. Been riding for about 40 years and have had more than one set of black headers. They just need to be painted when this happens (and it's going to happen). One possibility exists that when they were installed, they weren't cleaned before they were cured. Grease/oil from your hands will eventually lead to this if heated and allowed to cook onto the pipe surface. The fix is easy enough though. Take them off and sand lightly. Shoot them again with heat paint with a thin two coats. After you install them, clean where they were touched and go for a ride. They will smoke a bit at first and they will look brand new too.
Toddman,
Welcome, and thanks for your inputThumbs Up
04-27-2015, 12:50 AM
  Yoshimura RS3 replacement for an '13 Jurlie_imp 7 598 07-28-2024, 01:47 PM
Last Post: Glockrocks83_imp
  Yoshimura RSCV Full Exhaust System Stealth128_imp 43 3,568 11-29-2022, 10:38 AM
Last Post: mrded_imp
  Dart flyscreen and a little Yoshimura stain magic 1985CB450_imp 19 1,637 10-24-2022, 04:12 AM
Last Post: 1985CB450_imp
  PCV with full exhaust worth getting tune?? gretle_2.0 4 426 05-24-2022, 03:43 AM
Last Post: gretle_2.0
  Arrow full exhaust gretle_2.0 2 324 05-17-2022, 11:38 AM
  Moriwaki 4 into 1 full pipe GS1100_imp 9 667 01-30-2022, 12:59 PM
Last Post: rich_imp
  full delkevic exhaust outback_imp 27 2,034 01-14-2022, 11:12 AM
  Yoshimura RS3 Install. 2013 Kit on a 2014 and sorted the center stand issue! rdtshaw_imp 17 1,150 01-05-2022, 10:54 PM
Last Post: Nibis_imp
  Arrow full system exhaust tsmetjen_imp 19 1,301 07-29-2020, 03:46 PM
Last Post: tsmetjen_imp
  Delkevic full system?? juliang_imp 4 428 07-29-2020, 05:50 AM
Last Post: Bheezy27403_imp
