Rear brake light LENS removal DIY?
Threads: 698
Likes Received: 623 in 279 posts
Likes Given: 789
RE: Rear brake light LENS removal DIY?
ok someone should do a pictorial for the How To section on how to remove the lens and /or replace the tail light bulb. Sounds like it's not the old 2 long phillip screws from the face anymore. ANYBODY?
01-04-2016, 03:31 AM
Riko_imp Offline
Threads: 47
Its actually the whole assembly thats hekd by those bolts, not the lens.
01-04-2016, 04:05 AM
White Dog_imp Offline
Threads: 59
(01-04-2016, 04:05 AM)Riko_imp Wrote: Its actually the whole assembly thats hekd by those bolts, not the lens.
Correct. On the 2014, the lens assembly has to be removed, then the bulb socket can be undone to replace the bulb.
Looking at the pics on the Japanese website that sells the clear LED lens, is that the chrome assembly visible around the lens? It may be a bolt on product.
I like the blinking tailBlazer bulb assembly I bought. It appears to be brighter than stock bulb and also flashes.
01-10-2016, 01:15 AM
Riko_imp Offline
Threads: 47
yep it should be bolt on, only wire it in and good to go.
I would use their assembly but keep the stock red lens...
01-10-2016, 03:41 AM
  Preferred Brake Light Bar Farkles TooManyBikes_imp 12 1,460 03-18-2024, 02:46 AM
  Crank Case Cover removal? JF Coastal_imp 47 3,270 08-04-2023, 01:26 PM
  longer length rear brake pedal darmahman_imp 3 420 06-11-2022, 07:12 AM
  Accessory Removal Wagonpeddler_imp 13 1,000 03-22-2022, 05:22 AM
Last Post: Wagonpeddler_imp
  Pulsing brake light modification Cqrlm911_imp 11 1,053 06-08-2019, 12:43 PM
Last Post: LikeAfox_imp
  Tank Removal... Bazbro_imp 17 1,269 03-08-2019, 05:42 PM
Last Post: Bazbro_imp
  3-wire to Connector for Brake Light for Custom Fender Eliminator x(why)z_imp 5 511 02-05-2019, 12:40 PM
  Attaching led strip light to running light? The Beast J7_imp 6 669 06-28-2018, 12:58 PM
Last Post: The Beast J7_imp
  Custom rear fender removal. Rebel73_imp 17 1,257 03-15-2017, 06:49 PM
Last Post: c-breezy_imp
  Rear brake light flasher. walrusz06_imp 15 1,131 01-18-2017, 08:56 PM
Last Post: Rocky_imp
