wire spoke wheels
jlhalsey_imp Offline
Threads: 2
RE: wire spoke wheels
all parts are new OEM Honda in Honda packaging. Tires and tubes Dunlop Radial D205 Sportmax Touring. Both axles are supplied. New sprocket and hub, rubber biscuits are re-used as is the rear brake disc. both front discs are new. Takashi supplied all items and parts schematics highlighted so you can visualize the correct orientation and location of all the parts. You need to have the tires mounted and balanced.
the price was no where near the figure mentioned by Randy B.
The wheels look muscular, quality stuff. Rear brake caliper shipped today so will post when finished.
08-04-2014, 12:26 AM
jim rosenthal_imp Offline
Threads: 1
I tried to find out from Honda if they plan to offer the CB1100 with the wire spoke wheels for the 2015 model year. Well, if they know, they aren't saying. And there's no information about when the new model information will come out.
Fun deferred is fun lost, I think, so I am going to watch JHalsey's project with a great deal of interest, and see how things turn out. He does not have ABS, so I will have to ask Mr. T about that- do the Honda wheels that he sells work with the ABS system? And anything else he can tell me.
08-04-2014, 03:08 AM
Ack-CB11_imp Offline
Threads: 46
(08-04-2014, 03:08 AM)jim rosenthal_imp Wrote: I tried to find out from Honda if they plan to offer the CB1100 with the wire spoke wheels for the 2015 model year. Well, if they know, they aren't saying. And there's no information about when the new model information will come out.
I bet they do. It would top the DLX off and really complete the package. Add another $1200 to $1500 too?
08-04-2014, 05:52 AM
Randy B Offline
Palm Bay, Florida USA
Threads: 85
Likes Given: 133
(08-04-2014, 12:26 AM)jlhalsey_imp Wrote: all parts are new OEM Honda in Honda packaging. Tires and tubes Dunlop Radial D205 Sportmax Touring. Both axles are supplied. New sprocket and hub, rubber biscuits are re-used as is the rear brake disc. both front discs are new. Takashi supplied all items and parts schematics highlighted so you can visualize the correct orientation and location of all the parts. You need to have the tires mounted and balanced.
This is a good thing. Everything I was seeing was the wheels would be around $2,500 for the set and then the rotors alone would be in the range of $300 each (I thought you needed to replace all 3) and then add in the tires and tubes. I never even considered the rear caliper being different so take off the rear rotor and add in the rear caliper....probably close to a wash.
Well it turns out Mr. T. has a pretty good deal going on the wheels, tires, tubes and rotors for about $2,125 as of today. Not sure about the added cost of the caliper, but my guess would be in the $200 range so my revised total guess would be with shipping around $2,400 which isn't really all that bad.
08-04-2014, 07:28 AM
grover_imp Offline
Threads: 6
wire spoke wheels
Anyone given any thought to just buying the hubs and rear rotor, then lacing the hubs to new alloy tubeless rims (Sun or similar)?
It might not be too different in terms of cost and could open the door to a lot more tire options, especially for those folks interested in a wider rear tire. Just a thought...
08-04-2014, 07:42 AM
Randy B Offline
Threads: 85
Likes Given: 133
I don't believe the hubs are sold separately, but I don't have access to a EX phish so I can't b e sure.
08-04-2014, 09:54 AM
Threads: 2
Ok, here is an update. The rear caliper solved the width problem. However, the location of the hydraulic port for the brake hose is rotated to the rear about 30 degrees compared to the stock caliper. I was able to reorient the stock brake line to reach the new caliper but had to abandon the OEM attachment hardware on the swing arm. A longer rear brake hose is on the way from Mr T so i can route along the swing arm and reattach with the OEM brackets for a completely stock look.
The caliper replacement process meant bleeding the rear brake. The meant finding the fluid reservoir which is conviently located under the seat behind the tool storage bucket and the fuse/relay module under a cross brace which prevents you from removing the cap. To add fluid then requires one to unbolt the reservoir from the attachment to the rear fender which requires a 1/4" drive socket and wobble attachment and considerable patience to loosen. Then the reservoir can be pulled forward far enough to add DOT 4. I give Honda an F- for this crap. Maybe someone else has figured out an easier way to top off the reservoir, if so i would love to hear about it.
I have only riden the bike a few miles today to work, have to scuff the tires in but it rides just like before except to my eye looks more "awesomer". Will post a picture shortly if i can find the attachment button which does not seem to appear with "Quick Reply".
Have OEM 2014 DLX exhaust system on my dining room table and center stand that i am going to attempt to install this weekend. Hopefully will be fewer adventures than with the spoked wheels.
Here is the one picture i have at this point.
ok that didn't go so well. no picture appeared. stay tuned.
08-29-2014, 09:01 AM
Likes Received: 877 in 480 posts
Likes Given: 1,011
wire spoke wheels
Looks very good indeed.
08-29-2014, 12:11 PM
Likes Given: 789
(08-29-2014, 12:11 PM)Cormanus_imp Wrote: Looks very good indeed.
+ 1
08-29-2014, 02:11 PM
gossman_imp Offline
Threads: 16
My last bike had spoke wheels, don't see the attraction. Time consuming to clean, increased cost of tire replacement since the tubes should be replaced with the tire, one flat and the tire shot. One of the great attractions was the mag wheels on the CB. I don't mind the look, but thankful it came with mags.
08-29-2014, 02:26 PM
  An update on my spoke wheel conversion. FLYTYM_imp 20 1,308 06-17-2023, 02:09 AM
Last Post: FLYTYM_imp
  Wire colors not matching the diagram (2013 A / 2017 NA)? LayerCake_imp 16 1,319 05-30-2022, 05:45 AM
Last Post: LayerCake_imp
  Adapting to 17" CBR wheels? nsrrider_imp 42 3,047 10-10-2021, 11:34 PM
Last Post: nsrrider_imp
  Ignition switch live accessory wire? ozigoo 10 882 02-18-2021, 02:32 PM
Last Post: ozigoo
  Wire Wheel / Cast Wheel Swap pekingduck 37 2,585 06-05-2020, 12:35 PM
Last Post: michael1954
  CB1100EX- Spokes to '14 Alloy Wheels Conversion iamheero_imp 10 912 04-24-2019, 01:26 AM
  Spoke wheel conversion on a 2014 Standard FLYTYM_imp 5 591 03-13-2019, 12:29 PM
  3-wire to Connector for Brake Light for Custom Fender Eliminator x(why)z_imp 5 504 02-05-2019, 12:40 PM
  HONDA OEM SPOKED WHEELS for CB1100 CB4ME_imp 21 1,533 11-28-2018, 06:11 PM
  17” wheels...again Foxcroft007_imp 12 904 09-12-2018, 12:35 AM
