Mounting a GoPro on the CB1100. Some ideas.
Pterodactyl_imp Offline
Threads: 75
RE: Mounting a GoPro on the CB1100. Some ideas.
(03-09-2016, 10:43 AM)The ferret_imp Wrote: Wow, that's insane. There is nothing about a camera that would change the safety of the helmet one would think.
In the USA? Well in most states we are not even required to wear helmets. I have heard that the police don't like being videoed ( or photographed for that matter) but I don't think it's actually illegal to do so, and many do film encounters between themselves and police.
Another aspect is police feel they should be able to confiscate the camera to use as evidence of wrong doing by the motorcyclist, but I believe that has been settled in court, with the outcome being the cameras are private property of the owner and cannot be confiscated, but police can subpoena them I believe.
All I have said is hearsay however since I have never verified things I have heard/ read since I have no desire to film my riding anyway. I mean who wants to see bad lines ridden slowly?
Come on mate. Your modesty, while commendable, is entirely unwarranted. Smile
03-09-2016, 11:53 AM
curlyjoe Offline
boston metro
Threads: 18
Likes Given: 6
(03-08-2016, 05:26 PM)Pterodactyl_imp Wrote:
(03-07-2016, 08:48 PM)Cormanus_imp Wrote: Good work, lad.
You've put new mirrors on Last Blast?
Thanks mate. Yes the mirrors have been there for some months now. I was inspired by Chip Beck's posts. When I first put them on I was a little disappointed with "the look" compared with the OEMs. But after a few days I became accustomed to the new look and now wouldn't go back. The actual mirror function I certainly prefer to the OEMs. As a matter of interest the mirrors, as are Chip's and others on the forum, from the CB500F. Just under AUD 35 apiece. I looked at mirrors from a Crossrunner and could not detect any difference to the CB500F mirrors but they run out to about AUD 113 apiece. The parts bloke tells me it is because they are made in Japan and the CB500F's made in Thailand.
(03-07-2016, 09:59 PM)curlyjoe_imp Wrote: I had never thought of mounting the gopro on the clutch fluid reservoir. I like your point of representing the true angle of the bike. It must also be easy to turn the camera on and off. How is the wind noise from that position?
I have been using a chest harness which is a bit of a hassle in that it's hard fumbling for the on/off switch on the go.
Great stuff and thanks for sharing the great video of the twisties! Smile
Joe, yes, it easy to control and monitor the operation of the camera when it is mounted on the clutch fluid reservoir. Another way to control the camera is through a Smart Remote (SM). The SM will control the camera recording and functions from up to 600ft (180M) away. Useful, I guess, if you want to take some "ride by" or other footage with the camera on a tripod. However the SM is really good for controlling the camera if it is mounted on a chesty or any other mount that is not easily accessible. No one should become part of the scenery because they were fiddling with a GoPro. On the other hand it might make for some exciting footage. In the photo immediately below you can see the SM mounted, by velcro strap, on the bars just above the USB charger. It is not as big as it might appear in the photo and it can be attached anywhere that is convenient. I have used it strapped to my right wrist. It is not a cheap bit of kit though.
[Image: 5297c77364d28fa300f309b83b49bc57.jpg]
Noise is something I have just begun to experiment with. On a video I posted () there is a section towards the end with raw noise recorded. I like it as the Staintune noise is good and wind noise minimal. You can hear peg touchdowns at points. I was using the open back case mounted on the clutch. There has got to be a better way though. To this end I bought a Røde microphone, pictured here:
[Image: 0f8b7d382089f37bb63f675650f2efcb.jpg]
It is plugged into the Mini-USB input on the camera. More on that in a moment. A 1.5 meter M-M 3.5mm extension cord allows it to be positioned just about anywhere on the bike. Below is an example of it plugged to the camera on the bike fuel tank side. I am having some success placing the microphone on the pillion grab bars just above the muffler. At first I tried it with the wind cover but found that the cover also reduced the muffler sound. Without the cover it is much better, it just needs to be in a wind protected position. I want to try it put behind the screen I have fitted to my bike. Work in progress.
[Image: f81a1aa0a37e8a253f8fb1e230d20cc9.jpg]
To plug a microphone into the GoPro camera while in the waterproof case, irrespective of the back used, required some modification to the case. So, after some thought, I drilled a 10mm hole in the case, centred over the Mini-USB port. With a little bit of rounding off to the Mini-USB cord end it fitted so that it is water resistant and would keep light rain out.
[Image: 7b1ee6f5954c93a8666d719308c8a659.jpg]
When not in use I plugged the hole with a rubber blanking grommet that, despite coming in an imperial size, fitted the metric hole perfectly.
[Image: 3b8060778aefd08c5a0a80a0220c9a78.jpg]
[Image: 671d9a4b06371ea2c8b465fcfd8f991c.jpg]
[Image: d17b16ae4db63574ec350ed230046918.jpg]
I only had one type of grommet available when I did this so, on looking closely, you might think I have installed it arse about with the rounded head inside. Not so. The grommet, if fitted with the heavy face inside, will not allow the camera to fit into the case. With the rounded face inside, the camera rests flush against the grommet ensuring a waterproof seal. I have tried it to two meters of water and all OK (despite my advancing years I still like to play with a longboard and a kayak).
However, microphone aside, this modification gives another, and entirely unplanned, benefit. Battery life of the GoPro allows about two hours recording and shooting. This figure is rubbery as battery life depends on a number of factors. Two hours might seem enough and in most cases this is so, particularly if a spare battery is carried. But if you are touring and plan to ride six hours and then, say, camp out at a spot where a charger is not available, then you have a problem. Also some people like to use a "looping mode" where the camera operates continually up to its battery limit. This modification allows the camera to record and charge concurrently. Or just charge if required. This is good. It is done by connecting the charging cord to that same Mini-USB port. See this:
[Image: 810d65ef11663fad6ccbcf3627af22a1.jpg]
So this will give unlimited recording time as long as the USB charger is operating, plus two hours.
(03-07-2016, 10:07 PM)JF Coastal_imp Wrote: Pretty cool Pterodactyl. .. I usually end up just leaving a mount on top of my headlight for easy on and off... I'll have to play around with a few of these ideas.
We should have a sticky thread on here somewhere with people posting gopro testing / settings / everything related. ..
What settings do you leave yours on ? 1080 / 60 fps ?
JF, I try to record in as high a definition as possible, up to 4K. So that is my default setting. However it will depend on other factors. One is that all fields of view are not available in some definitions. For example in 4K only Ultra Wide FOV is available. Battery life is also affected by definition. But in general 1080p/60fps is a good compromise. The first video I made, the one referred to above, was made in this resolution. Higher definition is great for viewing your videos at home but come with the penalty of long upload and download times for sharing. If everybody had optical broadband at the highest possible speed then not a problem. But, alas, not so in the real world.
Hope the above is of interest.
Cheers.
(03-07-2016, 11:04 PM)redbirds_imp Wrote: Very instructive Ptero. Sparky watched the video with me and thinks your Aussie accent "divine". Great music also "La Bamba".
Thanks 'Birds and Sparky.
Thanks for taking the time to post all this information in such detail. Thumbs Up
I looked into the SM remote to see if it's compatible with my [url=http://shop.gopro.com/cameras/hero/CHDHA-301.html]"entry level" HERO. Apparently, it's not. So that's a bummer.
Your wind noise was perfectly acceptable to me in the clip. Perhaps you have a higher quality microphone in you camera model? BTW, the staintune sounds great! Smile
I'm not sure if I can use a remote microphone in my HERO so I'll look into that in more detail.
03-09-2016, 09:59 PM
Likes Received: 880 in 482 posts
Likes Given: 1,016
Just to add to the great Australian helmet modification saga, all bar one jurisdiction has now approved the use of helmets complying with AS/NZS1698 and the relevant European standard. Helmet importers say they won't import European approved helmets until all jurisdictions have approved them, but all the big states are now in, so I suspect it won't be long before we have a bit more choice.
I have a recollection (which could well be wrong) that the prohibition on modification is actually contained in the standard, which is part of the appalling racket that's been created by governments giving into the big business lobby and mandating standards in legislation. It is certainly not contained in the Queensland legislation.
Police in Victoria and NSW have been particularly enthusiastic about booking motorcyclists with camera mounts on their helmets; I read recently that a magistrate in Victoria had thrown out a prosecution on the basis that the laws were too difficult for the public to access. She or he did not address the legality of modifying helmets. There has yet to be a judgment on that question.
It will be hard to stop the enthusiasm for bike mounted cameras now they've become relatively cheap and widely available. It will also be hard to stop people sticking them to their helmets. At some point, I suspect someone will do some serious research on what is likely to happen to a person in an accident when they have a camera stuck to their helmet.
03-10-2016, 06:47 PM
Django Offline
Threads: 71
Likes Given: 20
Man, and I thought, we Germans are overregulated. It can always get worse, as I see... Smile
03-10-2016, 08:33 PM
capttwb136_imp Offline
Threads: 12
Politicians seem to love to control everything! Sometimes I wish they would play more golf and not"work" so hard! lol! ROFL
03-10-2016, 11:12 PM
davidantoniocostarica_imp Offline
Threads: 6
[Image: d104e6e303acbd95cff1c3033a6fb9c8.jpg]
Too easy Wink
Samsung Note 5
03-13-2016, 09:47 AM
Threads: 75
^^^^^ Nice looking unit. Lets see some Costa Rica scenery going past Smile
03-13-2016, 10:17 AM
bflint Offline
San Diego
Threads: 72
Likes Received: 24 in 7 posts
Likes Given: 7
Thanks for the video commentary! I want to buy a gopro as a touring toy and your piece explained a lot. Thanks again.
03-17-2016, 03:42 AM
Threads: 75
No worries mate. Let us know how you go. Editing programs, and techniques, are also something worth having a good look at.
03-17-2016, 04:57 AM
Riko_imp Offline
Threads: 47
Yeah, I agree with the fact that using a cam makes you feel kinda 'safe' you never know when it comes in handy.
But for most parts, I think it will be just for fun Smile
Speaking of action cams, this is my first and I figured out a cool way to mount a cam not on a helmet, but in a helmet Smile
Now thats First Person View huh.
A whole DIY thread was made: http://cb1100forum.com/forum/showthread.php?tid=8310
03-31-2016, 07:36 AM
  Honda Top box mounting Lord Popgun 8 868 06-22-2023, 12:09 PM
  3D printed strap adapters for the CB1100 mounting pegs LayerCake_imp 33 2,452 07-10-2022, 12:04 AM
Last Post: 1973cb750
  Some ideas for my EX Rod 1975_imp 33 2,131 06-14-2022, 05:07 AM
Last Post: LayerCake_imp
  OPTIONAL TAILLIGHT IDEAS ALPHADOG69_imp 1 261 11-12-2021, 06:11 AM
  Phone mounting issues ride4now_imp 37 2,728 09-29-2021, 05:42 AM
  Mounting a garage door remote Gone in 60 21 1,450 06-24-2021, 01:40 AM
  iPhone anti-glare case (or alternative ideas) emptysea 9 848 08-05-2019, 08:10 AM
  Custom lavalier mic setup for GoPro vids… Guaza14_imp 8 688 07-17-2019, 03:11 PM
Last Post: max
  '80's style appropriate front fender ideas misterprofessionality 6 675 01-17-2019, 11:02 AM
  Denali sound bomb mounting location? Jeeves_imp 3 452 10-08-2018, 08:30 AM
