cb1100 RS wheel conversion
Houtman_imp Offline
Threads: 115
RE: cb1100 RS wheel conversion
(04-24-2019, 03:04 AM)misterprofessionality_imp Wrote:
(04-24-2019, 02:16 AM)Randy B_imp Wrote:
(04-24-2019, 01:23 AM)misterprofessionality_imp Wrote:
(04-23-2019, 06:09 PM)itstuantran_imp Wrote: Fat tire always look more sexy Big Grin.
One concern is the gap of the swing arm, if it's large enough for the RS rim, as the tire is 180.
(04-21-2019, 11:43 PM)misterprofessionality_imp Wrote: So, this is my project for next year: Converting my 2014 st.d with 18" wheels to 17" wheels (not spoked). i'm halfway between going all out and getting magnesium wheels for maximum weight savings, but i'm not completely sold on the idea yet. First, I want to explore the idea of simply getting the OEM wheels for the RS and slapping them on. it seems like an easy enough thing to do, but then again i've never seen an RS in person, so i'm calling on you folks in Europe and other markets where the RS is available to help me out with this.
First off, check your local Ebay and parts websites and let me know if there are used CB1100 RS wheels available for sale, and what the average price is. I've been trying to do this using foreign VPN's but i just want to make sure i'm hitting all the right websites to get a good idea of what's for sale. Thanks in advance for any prices you can send back to me.
Second off, For anybody that owns an RS, can you confirm that the wheels are mounted in the same way and would work as a straight swap to a 2014 model? The parts diagrams look very similar, but of course i'm not knowledgable enough to make that determination just from looking at those.
Finally, for RS owners, how jealous should i be of your awesome 17" tires? Biker
i hadn't thought of that at all. perhaps using the OEM RS wheels isn't an option for this conversion, and i should focus on aftermarket 17" wheels. Is there a measurement I can take to determine once and for all whether the RS wheel would fit on the standard swingarm?
I can see from some minor research that the swingarms between the '14 CB and the '17 RS are in fact different parts.
I just did some checking and the 17 EX and the 17 RS use the same swingarm.
Here are some links to Ebay UK on the wheels.
[url=https://www.ebay.co.uk/sch/i.html?_odkw=cb1100rs+wheels&_osacat=0&_from=R40&_trksid=m570.l1313&_nkw=42650MGCJD0ZA&_sacat=0]https://www.ebay.co.uk/sch/i.html?_odkw=...A&_sacat=0
[url=https://www.ebay.co.uk/sch/i.html?_odkw=42650MGCJD0ZA&_osacat=0&_from=R40&_trksid=m570.l1313&_nkw=44650MGCJD0ZA&_sacat=0]https://www.ebay.co.uk/sch/i.html?_odkw=...A&_sacat=0
Quite helpful, thank you randyB. this seems to confirm my suspicion that almost no "used" ones are for sale. these are all factory new replacement parts (which is fine, i just wanted to gauge the availability of used ones).
It's looking like (based on what itstuantran brought up), i may have to actually change to an RS swingarm as well if i wanted to use those wheels. So, if i buy aftermarket magnesium 17" wheels that fit my existing swingarm, or buy CB1100 RS wheels with a replacement RS swingarm, it seems like i'm paying the same amount of money either way.
thus, my initial hypothesis that using the RS wheels would be much cheaper than the magnesium wheels does not hold water. Looks like i'm doomed to the poorhouse either way.
You probably will meet some other CB 1100 owners in the poorhouse as well after spending the house hold budget on unusable bike parts.
Been there , Done that .
04-24-2019, 05:01 AM
Desert viper_imp Offline
Threads: 7
Webike.com. Galespeed Forged Aluminum front 3.50x17” Gold $603 rear 6.00x17” Gold $1093
04-24-2019, 05:13 AM
misterprofessionality Offline
Threads: 126
Likes Given: 1
you are correct Desert, i checked on those though, they don't have super significant weight savings over the OEM wheels. maybe just a little. I'd much rather get the galeforce Magnesium wheels. the pair is about $2500.
Believe me, i'm going to do every ounce of research necessary to ensure that nothing i buy is unusable. and if i do buy something unusable i'm going to tell whatever lies i have to to return it :-p
04-24-2019, 05:57 AM
Threads: 7
I don’t blame you, when I bought my new ZRX1100 in 1999 my first mod was a set of Gold Magnesium Dymags.....that huge 190 on the rear looked awesome
04-24-2019, 06:14 AM
Threads: 126
Likes Given: 1
wouldn't going that wide affect your handling a great deal though? the stock wheel is 140, i use a 160 tire, i don't know if i need to go up all that high, unless i'm wrong and that would improve my handling a great deal.
04-24-2019, 06:21 AM
Threads: 346
Likes Received: 829 in 457 posts
Likes Given: 968
(04-24-2019, 04:50 AM)pkrich_imp Wrote: HI
swing arm is 10 1/2" inside best i can measure with out removing wheel not the same swing arm as ex
rs has box section swing arm and different wheel adjusters measured from my 17rs
pete
Welcome, Pete.
04-24-2019, 07:07 AM
Threads: 7
Well the ZRX1100 came stock with a 5”x17” rear rim with 170/17 tire....The 190 required a 6” rim....it only required a slight amount more pressure on the bars in the corners....the CB1100RS comes with a 120/70/17 mounted on a 3.5x17 rim and a 180/55/17 mounted on a 5.5x 17......should handle great and look great on your bike
04-24-2019, 07:23 AM
Threads: 126
Likes Given: 1
thanks a lot for that measurement PKrich. now i have a much better idea of what i'm shooting for If i want to use wheels made for the RS. The mod will definitely have to come with a new swingarm.
aftermarket wheels are still up in the air though. Going to have to keep my eyes open.
04-24-2019, 08:17 AM
pkrich_imp Offline
Threads: 0
don't know if front wheel is the same between ex and rs has different forks bigger diameter and radial mounted calipers
04-24-2019, 06:25 PM
itstuantran_imp Offline
Threads: 7
EX front wheel is 110/80-R18 while RS is 120/70-R17. Caliper mount is different too.
(04-24-2019, 06:25 PM)pkrich_imp Wrote: don't know if front wheel is the same between ex and rs has different forks bigger diameter and radial mounted calipers
04-24-2019, 07:17 PM
  Wheel Chocks DAC 8 770 07-22-2023, 10:23 AM
Last Post: DAC
  An update on my spoke wheel conversion. FLYTYM_imp 20 1,199 06-17-2023, 02:09 AM
Last Post: FLYTYM_imp
  DLX Exhaust System Conversion Ron in MO_imp 28 1,777 08-26-2021, 10:50 AM
Last Post: bvictory_imp
  Wire Wheel / Cast Wheel Swap pekingduck 37 2,491 06-05-2020, 12:35 PM
Last Post: michael1954
  Touring Conversion Complete caddy425_imp 12 929 08-09-2019, 04:06 AM
  Houtman's new wheel chock The A-man 14 1,008 07-04-2019, 07:05 AM
  modifying wheel trim misterprofessionality 18 1,355 05-14-2019, 02:49 PM
  CB1100EX- Spokes to '14 Alloy Wheels Conversion iamheero_imp 10 872 04-24-2019, 01:26 AM
  Spoke wheel conversion on a 2014 Standard FLYTYM_imp 5 575 03-13-2019, 12:29 PM
  Another question about the spoke wheel conversion. FLYTYM_imp 2 327 05-14-2018, 03:34 PM
