Power commander.
HikerToo_imp Offline
Threads: 114
RE: Power commander.
Guhl had my CB in his shop on his Dyno, he did ask for the PCV map as a starting point for the fuel mixture.
So he did add fuel mixture changes to the ECU, very close to what the PCV map does, and the timing advances and removal of speed limits.
So in my case, the ECU flash replaced the PCV + more......
08-08-2015, 08:09 AM
Olyrider Offline
PNW
Threads: 23
(08-08-2015, 08:09 AM)HikerToo_imp Wrote: Guhl had my CB in his shop on his Dyno, he did ask for the PCV map as a starting point for the fuel mixture.
BIG difference!!! UndecidedUndecided
And the only instance where the ECU re-flash can substitute for the Power Commander.
08-08-2015, 09:10 AM
hxd148_imp Offline
Threads: 1
Hikertoo, I was curious what kind of exhaust you had on your cb. I was thinking about getting my ECU reflashed because Ive got a Yoshi full exhaust installed but was curious if Guhls had any bikes with this setup, thanks.
08-08-2015, 09:15 AM
Threads: 114
(08-08-2015, 09:15 AM)hxd148_imp Wrote: Hikertoo, I was curious what kind of exhaust you had on your cb. I was thinking about getting my ECU reflashed because Ive got a Yoshi full exhaust installed but was curious if Guhls had any bikes with this setup, thanks.
As far as I know, mine has been the only one in his shop.
I have a 13' CB1100 with Staintune and stock intake filter, same as when it was on hi Dyno.
I would think he uses the results from my Dyno for most any CB owner who asks to have their ECU reflashed, unless you ask for something different, like one member here asked for ONLY the rev bump and speed limiter be removed, no fuel or timing tweaks. or maybe if you have full exhaust and intake changes, get a Dyno with the PCV somewhere else, he could apply those fuel maps to the ECU , plus the timing and rev/speed changes.
08-08-2015, 09:55 AM
Pterodactyl_imp Offline
Threads: 75
(08-08-2015, 12:54 AM)HikerToo_imp Wrote:
(08-07-2015, 11:57 PM)Pterodactyl_imp Wrote: More "meaty" in the 2500 - 3500 range? That's a fast idle. In slow city traffic or on the highway cruising at the speed limit (3300RPM) it would be useful but otherwise I generally am in the 4000 - 6000 range so I think I could give it a miss. But if it it feels good for you, then do it.
Geez, you drink a lot of caffeine down there or something, I too am in the 2.5 to 3.5K range most of the time.....but if you look at the graph supplied by PCV, it will even help high revving people like yourself.
Not the caffeine, just the riding style. On the straight I feel uncomfortable (OK, subjective I know) below 3000 RPM and generally kick down a cog. In the twisties I like a minimum of 4000 RPM for a more positive engine response and better engine braking. Comes at a cost though in that my average fuel consumption over 55,000 kms is about 42mpg. Kms and mpg? That is sorta like a mixed metaphor Smile.
08-08-2015, 10:46 AM
hxd148_imp Offline
Threads: 1
Thanks for the heads up hikertoo. Since it might be a while before I can give up my ECU to Guhls for flashing does anyone have a PCV map for a 2014 CB1100 with a stock air filter and full Yoshi exhaust that they would be willing to share? I dont know of anyone local who can do a dyno tune and im worried about the preloaded maps not working to well with my current setup, thanks in advance.
08-08-2015, 01:37 PM
ReedsHondaCB1100_imp Offline
New to the Forum
Threads: 0
@olyrider
I have the same set up on my 2014 CB1100 (full yoshi and k&N filter). I too am running rich (love the popping sound around town but 145mi range is killing me on longer trips).
Sounds like you have a PCV map for this set-up? Is that something you would be willing to share?
Thanks,
Reed
(08-08-2015, 04:07 AM)Olyrider_imp Wrote: Not written with any animus, but I am going to continue to challenge the notion that ECU re-flashes and Power Commanders perform an identical function on the CB1100. Simply not so.
Guhl re-flashed my ECU. Told him I had a PCV and was going to have it dyno-tuned. He asked me to send him mapping files when I was finished.
The re-flash eliminated the speed limiter, and raised the RPM's. And...it had some semblance of a fuel map, but not for my bike. (full Yosh exhaust, K & N filter)
The dyno-tune eliminated a "lot" of popping on decel due to lean mapping after I installed the re-flashed ECU. It also gave me a more linear power band.
The re-flash was to restore the motor to what Honda had built in it before strangling it. The PCV is to make the fuel map work for "my" bike and "my" throttle desires.
08-15-2019, 04:05 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
Won’t the pair valve delete pretty much stop the popping on decel?
08-15-2019, 08:07 AM
HondaJon_imp Offline
Threads: 53
(08-15-2019, 08:07 AM)Lord Popgun_imp Wrote: Won’t the pair valve delete pretty much stop the popping on decel?
YES
08-19-2019, 08:09 AM
Ben70_imp Offline
Threads: 23
^^ What he said.
Ben
08-19-2019, 09:38 AM
  Can someone with a power commander on a 6-speed bike check something for me? PowerDubs_imp 10 872 05-15-2022, 11:42 AM
  Usb-c cable direct to battery or switched power capz65_imp 5 553 04-16-2022, 02:26 PM
  Power Distribution Module (PDM) - Europe/UK Tev62 5 540 11-16-2021, 07:49 PM
Last Post: j3gq_imp
  Power Commander 5 and Dyno Tune iamheero_imp 7 583 07-18-2020, 04:14 AM
  Power Port for 2014 CB1100A (Deluxe) MWV1500_imp 5 473 12-06-2019, 09:00 AM
  2013 cb1100 power commander help 2000zx750r_imp 4 465 06-16-2019, 05:43 PM
  Auxillary USB Power Plug install for IPhone Frulk_imp 22 1,282 05-12-2019, 06:00 PM
Last Post: Bazbro_imp
  JB-Power Magtan JB4 Magnesium wheels lola_imp 37 2,131 07-03-2018, 10:05 PM
Last Post: FLYTYM_imp
  anyone tried power commander with the auto tune sensor? scott will_imp 9 747 04-28-2018, 03:46 AM
  Thumbs Up for Power Commander V and Autotune chync_imp 5 434 02-25-2017, 07:10 AM
