“Katsumi” - a new project in the making
JLEECB Offline
Threads: 8
RE: “Katsumi” - a new project in the making
Pirelli Angel GT 120/70 front and 160/60 back is what I run. Slightly bigger than stock but I love the looks and handling. Not a great longevity tire, but I’ll take the grip over cost savings any day.
05-18-2021, 11:13 AM
Tev62 Offline
Threads: 33
Likes Given: 95
I think the handling on the CB1100 with stock tyres is pretty sharp. One downfall of a wider tyre (amongst some others) is that your contact patch is further away from the centre of the tyre in a corner, requiring you to lean further than stock to balance those same cornering forces. Look how upright a 250cc bike with skinny tyres can get round corners. You might get a slightly larger contact patch too but the power the CB1100 lays down is not testing the regular tyres patch in the first place, I'm not so sure you are getting any extra grip that would make any real world use to you. You are also carrying extra weight, un-sprung mass and making more work for the engine with the heavier rubber. To me there are too many negatives going up a tyre size but I will admit a big fat rear tyre does look nice.
05-18-2021, 05:03 PM
Threads: 349
Likes Given: 1,101
I’m sure you’re right Tev. I used oversized rear tyres for some time as they were the only radial options available. I’m not a good enough rider to notice the difference and I liked them.
05-18-2021, 06:12 PM
Zee9_imp Offline
Threads: 3
Rizoma 60mm risers and a black Rizoma bar. 30” wide. Done!
[Image: 964dd06ad8b0212ba34030ed054dfa07.jpg]
[Image: eacd28a8ff013ac1b2214f63327ec7eb.jpg]
[Image: a0219e8e9315eea1ef69019858dd7ecc.jpg]
[Image: 948162840bb2f21fe221ba57a3f9d816.jpg]
05-23-2021, 08:35 AM
Zee9_imp Offline
Threads: 3
Next project is the grote 7” led headlight. Which should be just a plug and play.
I’ve been pondering over a muffler replacement. I have a dented yoshimura RS3 at the moment and was thinking of doing something different. Since I have the linkage pipes i’ll take of just the yoshimura muffler and try and find a short stubby muffler that can fit in the diameter of the yoshimura linkage.
This leo Vince looked nice on a cb1000r and was considering this one. Any thoughts?
https://www.revzilla.com/motorcycle/leov...on-exhaust
05-25-2021, 01:13 AM
Kdogg2077_imp Offline
Threads: 3
Looks good. Would offer contrast to all the chrome.
06-14-2021, 10:36 AM
Obleo Offline
Threads: 16
Take a look on you tube for Delboys fix for bar end mounts , easy hardware store fix using concrete anchors.
06-14-2021, 11:17 PM
Rox_imp Offline
Threads: 3
Firstly, that's a gorgeous Thunderbird Sport. In both forms.
You'll love the CB. Especially when it's sorted and unleashed.
I see where you may be going with it.. Good taste.
Here's my little unleashed. Once the ECU is tuned and unlocked and you let the engine breathe it becomes a whole other bike.
06-22-2021, 02:16 AM
Threads: 138
Likes Received: 197 in 86 posts
Likes Given: 115
I like my Yoshimura header/exhaust, but then again, i'm biased.
Note on the rear tire - you don't have to go much larger than the stock width before the tire will rub on the center stand. Some have ground down the inner flange(s) of the stand to create room. The 160/60ZR18 70W rear works on my bike without modifying the center stand, but something just a bit wider would rub for sure.
06-22-2021, 02:33 AM
  Finally making some progress............. FLYTYM_imp 19 1,867 07-18-2021, 01:49 AM
Last Post: FLYTYM_imp
  Designing an Engine Oil Temperature Display Gauge Project 17-CB-002 37 2,993 11-06-2019, 04:10 AM
   Saturday morning project - Road Comet 2 Fairing LuckyNLife_imp 11 1,092 09-16-2019, 11:36 PM
Last Post: Cobalt23_imp
  Turn signal relocation -- Making room for my backseat rider JMA_imp 13 1,192 06-15-2019, 12:44 PM
Last Post: QUINTtastic_imp
  Making closed end grips work on the CB Skypilot_imp 6 704 05-18-2019, 10:40 AM
  CB1100 Backrest Project metalmaven_imp 64 6,004 03-14-2019, 10:56 AM
   My Cafe Racer project CSODenmark_imp 21 1,889 04-07-2018, 07:21 AM
Last Post: Reiver_imp
  White House project started Ack-CB11_imp 60 5,094 10-20-2016, 03:38 AM
Last Post: use2b_imp
  My CB Project Paul_imp 14 1,250 07-26-2016, 09:32 PM
Last Post: Paul_imp
  Vintage Saddlebag Project - Mounting tips please? specialist8 7 676 05-16-2016, 02:05 AM
Last Post: emptysea
