New YSS shocks,Hyperpro Progressive front springs,gators
Tev62 Offline
Threads: 33
RE: New YSS shocks,Hyperpro Progressive front springs,gators
(10-02-2021, 11:33 PM)tod.branko_imp Wrote:
(10-02-2021, 06:58 PM)Tev62_imp Wrote:
(09-11-2020, 10:55 AM)ozigoo_imp Wrote: So I decided on a mild suspension upgrade to suit my budget of very little...
My local YSS guy, Walter, put together some rear adjustable shocks to suit my weight, and suplied some Hyperpro progressive springs for the front forks to go with my PD emulator valves.
I had the gators ready to go, so installed them yesterday and am quite pleased with the result..the front feels alot smoother over bumps and more planted in the corners..The rears I cant really tell much of a difference ..Its pretty hard to judge bumps...Happy with the overall look and cost at @ AU$1k for the lot..
YSS are a very popular brand with a good value/performance ratio. I can't quite see but do those YSS shocks have a rebound damping adjuster collar at their base? If so wind them to fully damped, take a spin down the road then wind them to minimum damping and take the return trip on the same road. You will get a feel for their range and you can then set them somewhere in-between to your liking, firmer or plusher.
If anyone is considering new rear shocks I would as a minimum getting some with adjustable rebound damping, preload adjustment is a given.
(10-01-2021, 10:09 PM)tod.branko_imp Wrote: @ozigoo I know you haven't been online in a while, but I'm hoping you'll see the message and give some feedback on the YSS shocks you have as I'm looking into a set.
Having said that, has anyone else tried the YSS on their bikes? I found an affordable 380mm set (20mm longer than stock) and I'm considering them seriously. Before you say anything, I have spoken to IKON, and they take their time with delivery, I can't be bothered to order and wait, Ohlins are way out of my current budget, so that's out of the question, too.
I'm thinking I should pay attention to the chain slack with longer shocks as well. Now I'm thinking about chain and sprockets and think I could get a set in advance for when the time comes. Anyways, as usual, any input is appreciated
'14 CB1100 STD 5 speed
Personally I would not do this Tod. You have to ask yourself what is to be gained with that extra 20mm? You are going to lift the rear of the bike and shorten your trail changing the way the bike handles. You might find it is OK for you but you might find it is very much less than ideal. Just because the shock is 20mm longer doesn't mean it has 20mm more travel either.
As for the last sentence, I agree, I sent an inquiry about actual travel of the shocks as it's not stated clearly on the webpage. Hope they will clarify this.
As for the geometry I'm perfectly alright with shortening the trail, especially because I'm going with the 120/160 tires. I've already dropped the triple clamps by 1cm, and my preload is maxed on on the rear, and I still feel like there is too much squat out of turns and I would like more more weight on my arms, I feel like I'm sitting way too much. I understand it's a personal preference, this bike is being built for me specifically and they way I ride
Ah good, you could get your rear preload back for full travel Thumbs Up
10-03-2021, 04:03 AM
  Front fork seal Guards, not gators peterbaron 30 2,151 02-12-2024, 02:06 AM
  Nitro Piggy Back Shocks touchetteweb_imp 3 371 03-29-2022, 12:39 AM
  Hagon Shocks: Response to Inquiry Huladog_imp 10 982 12-20-2021, 06:32 AM
Last Post: LikeAfox_imp
  ZRX Shocks( Probably Revisited) Rox_imp 3 382 10-30-2020, 12:16 PM
Last Post: IndianRider_imp
  Gators -Honda vs Kawa vs Triump ozigoo 8 557 05-28-2020, 11:12 PM
  Amazon rear shocks DBM_imp 11 788 03-10-2019, 01:26 PM
Last Post: qmaven_imp
  Ohlins shocks for 2017 Houtman_imp 27 1,662 11-29-2018, 02:50 AM
Last Post: nhawk7504_imp
  Ohlin Shocks for 2017 Houtman_imp 4 407 09-02-2018, 03:02 AM
  Gears Racing Shocks camoto_imp 16 1,327 12-03-2017, 12:16 AM
Last Post: camoto_imp
  2013 CB1100 Rear Shocks - Adjustable KYB Reservoir shocks - CHEAP! pekingduck 20 1,275 11-10-2017, 11:45 AM
Last Post: okredneck_imp
