2013 CB1100 Rear Shocks - Adjustable KYB Reservoir shocks - CHEAP!
pekingduck Offline
Southern California
Threads: 41
Likes Given: 39
My complaint about the stock shocks has been a little too much initial compression harshness. I've had Ohlins on other bikes, and they can be plush and firm at the same time, if adjusted properly (or terrible if not adjusted right).
Anyway, I wouldn't spend the money for Ohlins or Works Performance here, and really don't trust the sub-$100 adjustable Chinese copycat Ohlins, although they may be fine. The stock 2017 RS shocks are over $700 each retail AND have no dampening adjustments.
The circa-2000 Kawasaki ZRX1200R (Lawson Replica replicas) came with adjustable-damping attached-reservoir Kayabas (KYB) of the same length. I took a chance and bought a used pair off eBay for $200 plus shipping. All in at $250. I re-painted the springs and re-plated the adjuster hardware, changed the lower bushings, and bolted them on.
On my bike, for some reason, the silver grab handle on the right was a lot lower than the left - maybe 8mm. (The forward nut may have been welded a bit lower.) I had to grind away about 8mm of aluminum off the bottom for clearance. When fully compressed, the shock reservoir will angle up a bit, so it needs 4-5mm more to be safe.
I initially mounted them with the reservoirs facing forward, which looked and worked fine, but blocked seat lock key access.
I settled on the compression damping knob at 2 and the compression wheel at "III", and it feels fine, without the stock shocks' harshness when hitting tar strips or freeway section gaps.
04-15-2017, 07:24 AM
chync_imp Offline
Threads: 20
Hopefully you won't run in to the problem I had with those grab rails. I installed some Ohlins fully adjustable shocks on my cb1100 and noticed the rail interference on the right side too. And I also ground down the grab rail as much as I could. I eventually realized that the reason is that the left side shock mounts are further out on the left side of the bike to clear the chain. I had about an eighth inch gap between my rails and the shock adjustment knob on the reservoir. I thought it would be fine. A month later I noticed oil all over the right side of my rear wheel. The grab rail had crushed the shock adjuster under riding load. I had ridden some with a passenger and I assume it happened then or on a hard bump somewhere. I had to get both shocks serviced and the valves replaced. Mine are under gas pressure so I just inverted them. Someone on the forum pointed out that the old cb1100's had their rear shocks mounted that way. When the sag is set correctly they are an amazing improvement.
[Image: f9bf754f8917ab1bea7277acc5f2f971.jpg]
04-15-2017, 08:35 AM
pekingduck Offline
Southern California
Threads: 41
Likes Given: 39
RE: 2013 CB1100 Rear Shocks - Adjustable KYB Reservoir shocks - CHEAP!
chync dateli
[hr' Wrote: [url=http://cb1100forum.com/forum/showthread.php?pid=168845#pid168845]
(04-15-2017, 08:35 AM)chync_imp Wrote: Hopefully you won't run in to the problem I had with those grab rails. I installed some Ohlins fully adjustable shocks on my cb1100 and noticed the rail interference on the right side too. And I also ground down the grab rail as much as I could. I eventually realized that the reason is that the left side shock mounts are further out on the left side of the bike to clear the chain. I had about an eighth inch gap between my rails and the shock adjustment knob on the reservoir. I thought it would be fine. A month later I noticed oil all over the right side of my rear wheel. The grab rail had crushed the shock adjuster under riding load. I had ridden some with a passenger and I assume it happened then or on a hard bump somewhere. I had to get both shocks serviced and the valves replaced. Mine are under gas pressure so I just inverted them. Someone on the forum pointed out that the old cb1100's had their rear shocks mounted that way. When the sag is set correctly they are an amazing improvement.
[Image: 55c95b565ac84c6a3281545b5950628e.jpg]
chync, Thanks for your observation. The left shock is a little farther outboard. The adjusters on my shocks are out of the way, but I double checked clearance as compressed as I could, and a little more clearance would be more comforting.
Now, the real question is, how and where did you get that tank for your 2014?
04-15-2017, 03:56 PM
chync_imp Offline
Threads: 20
I got the tank from Samurider.com
04-15-2017, 08:54 PM
Elipten_imp Offline
Threads: 13
Chync
Will that gas cap on the 2017 tank replace the cap on the 2014/2013 tank?
Sent from my iPad using Tapatalk Pro
04-16-2017, 12:49 AM
BestStandard_imp Offline
Threads: 4
(04-16-2017, 12:49 AM)Elipten_imp Wrote: Chync
No, it takes a special tank recess with five tapped holes for the exposed screws:
https://goo.gl/images/cHPRZe
My '91 CBR1000F has the same flush cap.
04-16-2017, 04:16 AM
chync_imp Offline
Threads: 20
I got the new cap from Samurider too
04-16-2017, 09:25 AM
Elipten_imp Offline
Threads: 13
Darn
04-16-2017, 11:50 AM
pekingduck Offline
Southern California
Threads: 41
Likes Given: 39
Chync,
Thanks again for your warning on clearance for that right shock.
No matter how much I ground, I couldn't get enough clearance. Decided to put it back to how I had it originally, reservoirs forward, and "clearanced" the key instead. Actually, I usually have house key bolted to the ignition key anyway, so I don't have a cluster of them over the switch. All is good now.
04-21-2017, 12:55 PM
chync_imp Offline
Threads: 20
pekingduck
Creative solution with the key. I had considered doing something like that myself or possibly trying to move the seat release latch. Not sure if my Ohlins are any bigger than your shock reservoir. Is the key access difficult with your shocks installed that way?
04-27-2017, 01:49 AM
  How to Source a Rear Rack for a CB1100 rdprdp01 5 678 11-18-2025, 01:52 PM
  Nitro Piggy Back Shocks touchetteweb_imp 3 385 03-29-2022, 12:39 AM
   BEST Cheap Headlight Upgrade for the CB1100 BE WELL SEEN IN THE DAYLIGHT! Havasu Secret_imp 18 1,576 02-25-2022, 12:16 PM
Last Post: Scoot_imp
  Hagon Shocks: Response to Inquiry Huladog_imp 10 1,028 12-20-2021, 06:32 AM
Last Post: LikeAfox_imp
  New YSS shocks,Hyperpro Progressive front springs,gators ozigoo 10 976 10-03-2021, 04:03 AM
  Rear Rack for 2013 CB1100 Closeout Redbird_imp 4 518 07-21-2021, 11:34 AM
Last Post: tj_gee_imp
  2014 CB1100 EX Seat Fit On 2013 and Older Bikes SUPERCRUZ_imp 36 2,198 06-05-2021, 08:14 AM
  ZRX Shocks( Probably Revisited) Rox_imp 3 392 10-30-2020, 12:16 PM
Last Post: IndianRider_imp
  Aftermarket Brake and Clutch Reservoir Covers michael1954 11 940 06-17-2020, 08:42 AM
Last Post: Mtneers
  2013 CB1100 with Pipemasters 4 into 4 Creasy_imp 33 1,993 12-06-2019, 01:15 PM
Last Post: iamheero_imp
