Handlebar Risers??
Buffalohead_imp Offline
Threads: 10
RE: Handlebar Risers??
(07-27-2013, 06:26 AM)2013 CBXX_imp Wrote: I tried Rox set backs and they would not hold in the stock risers. I have the scratch
in my silver tank stripe to prove it. I bought some risers out of japan and they worked
but had to much movement in the bolt holes that came up through the triple tree so
that resulted in another little scratch in a different location on the same silver stripe
(The plastic on the handle bar switch has a sharp edge and when you turn the bar it
contacts ever so slightly). So now, after trying 919 bars (not wide enough) I took the
stock risers turned them upside down (dot down) and installed the stock bars with after-
market mirrors (read about it on the Ultimate Motorcyclist road test on the 11) and I like it.
That's too bad your Rox Risers didn't work on your bike. It is strange that they wouldn't get tight. My friend has a set on his CB1100 and they work great. The set on my Suzuki are perfect on my bike too. Maybe you got a bad set. Lots of guys in the Suzuki club have them and like them as well. I hope you returned yours. Your experience is the first negative report I have heard.
The more I think about it, if what you described happened to me, I would take the stock caps to a machine shop and have a little shaved off. The Rox Pivoting Risers are too cool not to use.
07-27-2013, 06:40 AM
2013 CBXX_imp Offline
Threads: 0
I bought them off a guy who had them on a V-strom 1100 and the CB stock
risers will not tighten down enough to keep Roz set back from slipping down.
Bummer...
07-27-2013, 02:34 PM
Nachodaddy Offline
Litchfield Park, Arizona, USA
Threads: 10
Likes Received: 194 in 110 posts
Likes Given: 501
(07-27-2013, 05:35 AM)Buffalohead_imp Wrote:
(07-27-2013, 03:48 AM)The ferret_imp Wrote: http://www.happy-trail.com/Rox-Pivoting-...y-7/8.aspx
Interesting. Never seen anything like those before.
They are a lot less expensive at Amazon as opposed to happy-trails, FWIW.
If you use the part number I gave above (1R-P2SSN), they will fit specifically 7/8" handlebars instead of 1-1/8" handlebar type with adapters for 7/8" bars. There's no need for the universal/adapter type, but they will work.
I also have a set on my Suzuki and they are great, IMO.
If you use the part number I gave above (1R-P2SSN), they will fit specifically 7/8" handlebars instead of 1-1/8" handlebar type with adapters for 7/8" bars. There's no need for the universal/adapter type, but they will work. I just got a set of these from Amazon, but before I try to install them, I'm hoping someone who has them will answer a couple of questions.
1. Are you SURE there is no problem with the cables? They are two inches and look like a LOT more than most of the risers.
2. Since they swivel, are you having any trouble with them not staying in place? Sure looks like they will not be as stable as the ones that do not swivel.
Thanks for your help.
01-23-2022, 12:35 AM
I use these on the Honda Africa Twin.
In my case, no cable adjustments for a 2" model.
They stay in place for me.
01-23-2022, 01:17 AM
Nachodaddy Offline
Threads: 10
Likes Given: 501
(01-23-2022, 01:17 AM)GoldOxide_imp Wrote: I use these on the Honda Africa Twin.
Thanks GO. Thanks
01-23-2022, 01:20 AM
calipo223_imp Offline
Threads: 10
I bought these for my 14 standard. My bolts are not long enough to fasten into the Rod Rizor. I will try to get bolts 2 inches longer and see what happens
07-14-2022, 10:05 AM
Threads: 10
Update the Rox Pivot risers work fine straight up and a lil forward. Definitely a more comfortable riding position for me. I think you may have a problem with cables if you pivot back. You would need to talk to others on the forum about that. I used the fasteners supplied. There is a little buzzing in my bars.
07-16-2022, 06:04 AM
  USB ON HANDLEBAR - connection at battery direct . Alfgaxatico_imp 38 2,998 05-17-2026, 10:20 PM
  Quad Lock handlebar vs clutch perch and bar-end mirrors Uncle Sixer 1 333 01-04-2026, 01:26 PM
  Handlebar control symmetry Uncle Sixer 17 1,787 08-07-2025, 05:24 AM
  VOIGT Risers Duderino_imp 3 467 11-23-2024, 01:09 AM
Last Post: Obleo
  What to do with the handlebar mounts when converting to clip-on controls? misterprofessionality 7 773 04-08-2022, 03:41 AM
  CB 1100 EX Handlebar original or other? MALACAY_imp 4 558 04-03-2022, 01:00 AM
  ROX Risers and longer brake line? MrBob_imp 3 475 06-14-2021, 12:19 AM
Last Post: MrBob_imp
  Rizoma risers on the cb1100 Zee9_imp 20 1,674 05-28-2021, 02:20 PM
Last Post: Zee9_imp
  Handlebar from 919 motorider6_imp 10 974 05-27-2021, 12:47 PM
Last Post: Stichill
  CRF1000 handlebar mspaansnl_imp 0 238 05-25-2021, 04:57 AM
Last Post: mspaansnl_imp
