11-20-2013, 01:03 PM
Has the wheel ever been removed?
First oil change, first problem (or two)
11-21-2013, 12:30 AM
Not to my knowledge. I have not removed it (590 miles so no need to, at least I've never had a reason to until this happened and I don't expect to have a reason until the tire needs changing).
11-21-2013, 04:20 AM
Hello fellow bikers.I couldn't resist when I first heard of the CB1100.
I usually keep 2 bikes.I've wanted a new bike since my M109 is got boring and developed a bad fuel leak and the closest dealer has it in for me. So it's just sitting in the garage.I also own a Honda Rune { 2004 model that I got in july of 2003 }.I'm gonna keep it.Best Bike I ever owned by a country mile. The CB1100 has one of those glass sight windows for oil checking. I've only had one bike with that.It was a Kawasaki Nomad which was a total piece of crap bike.I kept it for about 6 months and traded in for a Honda Valkyrie Tourer model.Put around 11,ooo miles on it and traded in for the Rune. I was upset after checking the oil when I had around 60 miles on the CB1100. Plus the bike had new bike smells.Kinda noticeable.I've never had that before on a bike.The glass sight gauge was full.I rechecked again after proper warm up { all Honda are basically 3 minutes On and 2 minutes off }.The sight glass was still full.I called the dealer and asked if he knew how much oil was added at set-up and also if he checked the oil sight gauge to be sure.He kinda said he did. I told him If I had to I was gonna drain the oil out and see exactly how much oil was in it.If it was a full quart over or not.Because that sight glass is worthless if it can't determine the level of oil in a bike. Any thoughts on the accuracy of the bikes glass oil sight indicator {gauge}.
11-21-2013, 05:40 AM
I added what was supposed to be the amount plus extra if you change the filter; sight window was full. But; it was at the low mark when I first checked, added about 2/10's of a quart and she over shot. Did not expect that! After running a bit it seemed to settle a bit but not much.
Forgot to add, the oil level from the dealer was almost to the top line and it stayed there every time I checked.
11-21-2013, 06:05 AM
I added the exact amount of oil that the service manual calls for with the filter change. With the 3 on and 2 off I was right at the upper line. This is after letting the bike sit overnight with the drain plug and filter off. Another 1 hour on the side stand after that.
Yes, I'm anal.
11-21-2013, 10:41 AM
(11-21-2013, 04:20 AM)_imp Wrote: Hello fellow bikers.I couldn't resist when I first heard of the CB1100. Mine was the same way with the break-in oil, I could not see the level. When I changed the oil at the 600 miles service, I can see the level clearly now. I assumed it came over full from the factory. I would not worry about it unless you see oil on your floor or oil leaks. I put 4 qt. and changed the filter and when she's on the center stand it's dead on the top line showing full. if it gets low you will be able to see it. I kept a check on mine and could never find the level until I change the oil.
11-21-2013, 01:08 PM
(11-21-2013, 10:41 AM)Gingersdaddy_imp Wrote:(11-21-2013, 04:20 AM)_imp Wrote: Hello fellow bikers.I couldn't resist when I first heard of the CB1100. Mine was the same way with the break-in oil, I could not see the level. When I changed the oil at the 600 miles service, I can see the level clearly now. I assumed it came over full from the factory. I would not worry about it unless you see oil on your floor or oil leaks. I put 4 qt. and changed the filter and when she's on the center stand it's dead on the top line showing full. if it gets low you will be able to see it. I kept a check on mine and could never find the level until I change the oil. Well being an owner of an original VTX 1800 and then the Rune I think Honda was pretty good about oil accuracy.Except on my Rune,the dealer did add a quart TOO much.I asked about it after about 500 miles because the shifting was kinda slippery.The Dealer acted like Oh Well.Then at 1,ooo miles I was plain sick & tired of the best dipstick on a Motorcycle { The Rune has a precision machined stainless steel dipstick } the level was still way over the 2nd mark as in Overfilled.I went to my Harley buddies garage and we drained the fluid carefully and got exactly 10 pints.meaning it was ONE quart overfilled.Honda does bench test most all Goldwings engines at the famous Maryvilles plant in Ohio. Meaning they also have a habit of shipping those engines to dealers with about a quart of oil still in them. When an engine is ONE Quart over it may foam.That is not Goot. But a Honda Rep,assured me not to worry.Still a quart over can be worse than a quart under. I think that may be the case with my New { 5 weeks ago } Honda CB.It was Over filled.A little more than a half quart over. The First thing I checked after buying the bike and driving home { about 60 miles } was the Tire pressure.It was off.About 5-6 psi in each tire.That is why I decided to check the oil,first thing the next day.I gotta tell ya'all ... Dealers Service dept. cannot be trusted. It is my experience that Service Mngrs./ are in cahoots with the Dealership management and owners. Speaking of Tool kits and where are they.My Rune tool kit was never on the bike.I just let it go.Which eventually caused me to distrust my Honda dealer.I bought the very First Rune in Kentucky in Elizabethtown.They even took pictures for the local paper as to help in promotion. Live and learn.
11-24-2013, 05:39 AM
I bought a new Harley Sportster a couple years ago and it had at most one quart in it. Checked it with 20 miles on it because of what I thought was valve noise. Not happy. Called Harley and they said it would be OK but they put a "note" on the thing saying if a problem developed down the road they'd cover it. I didn't like that particular bike and sold in with less the 2000 miles on it. I Like my 2012 it has a rubber mounted engine and a fat front tire which transformed the ride and feel of that motorcycle.
The Rune is an interesting bike. Seems like there are lots of them sold with almost no miles on them. They are impressive looking machines and I've been temped a time or two. Big bikes however and I guess that's what has stopped me. Collectors item for sure.
11-24-2013, 06:19 AM
(11-24-2013, 05:39 AM)bubblerboy64_imp Wrote: I bought a new Harley Sportster a couple years ago and it had at most one quart in it. Checked it with 20 miles on it because of what I thought was valve noise. Not happy. Called Harley and they said it would be OK but they put a "note" on the thing saying if a problem developed down the road they'd cover it. I didn't like that particular bike and sold in with less the 2000 miles on it. I Like my 2012 it has a rubber mounted engine and a fat front tire which transformed the ride and feel of that motorcycle. Trust me ... you won't find one.Honda made I think One Thousand in 2 production years.I have never in 10 years pulled up next to a Rune.Maybe once a summer I'll catch a glimpse of one going the opposite way on the Interstate.I have appx. 23,000 miles on a bike I took delievery of on the last day of July in 2003.As a 2004 Model. I don't go to big Bike events.Like Daytona or Sturgis.That is where you'll see Runes.The dealer I bought my CB 1100 at is a different dealer than the one in my neighborhood where I bought a VTX 1800 and the Rune.The CB Dealer in Louisville rarely sees any Rune. I don't think they ever got one.Honda was supposed to make sure every Honda dealer got at least one Rune.My Dealer got 3 Rune. Plus before that Dealer went out of business they had 2 used Rune on their sales floor. |
« Next Oldest | Next Newest »
| CB1100 Idle speed instability problem | ericlo69_imp | 1,436 | 123,113 |
10 hours ago Last Post: pdedse |
| idle problem update | 1973cb750 | 37 | 2,172 |
05-12-2026, 08:38 PM Last Post: rdprdp01 |
| Chain or sprocket problem ? | The Gecko_imp | 14 | 1,365 |
07-30-2024, 10:05 AM Last Post: Lord Popgun |
| O ring chain problem | Mixagon_imp | 7 | 685 |
10-17-2023, 07:28 AM Last Post: Charlie Bravo_imp |
| About the problem of high idling. (2014 cb1100ex) | DDUMZI_imp | 62 | 5,165 |
08-02-2023, 05:38 PM Last Post: DDUMZI_imp |
| May have a problem | the Ferret | 12 | 863 |
01-20-2023, 04:53 PM Last Post: max |
| 2017 EX Headlight Dimmer Switch problem? | sleeper_imp | 24 | 1,999 |
10-08-2022, 12:27 PM Last Post: GoldOxide_imp |
| Fast Idle Problem Solved | Nachodaddy | 17 | 1,581 |
10-08-2022, 09:18 AM Last Post: PowerDubs_imp |
| Another High Idle Problem | emptysea | 60 | 4,428 |
07-05-2022, 11:41 AM Last Post: GoldOxide_imp |
| Tail light install problem | iamheero_imp | 9 | 765 |
11-27-2021, 02:58 AM Last Post: Bazbro_imp |
