oil change help
Center stand use can be fun. On this bike I do what I normally do, grab the handlebar and grab rail - one in each hand. With my right foot I'll lower the center stand until it hit the ground. Tilting the bike away from me I'll use my foot to tap the center stand on the ground while tilting to make sure BOTH feet of the center stand are on the ground.
Once I know the stand is properly in contact with the pavement I'll rock the bike back a bit, when the bike is coming back I'll stand on the center stand arm with my full weight and lift the rear a bit with my right arm (while it's tempting to man handle the bike up by lifting with your shoulder; and I get sucked into this mode from time to time, your body weight should be enough to push the center stand down under the bike).
It takes some practice but this bike is easier than many.
And Rboe's way is exactly how I do it.
Just to be sure, you are checking the window when it is NOT running, yes? Once you start it up, you will not be able to see oil in the window.
When in doubt read your manual, it says 3.9 liters, It's on the spec. page 128. You can't see the oil line because you put a little too much in, you can always loosen the oil filter and drain a little out but it ain't hurting anything. 4 liters is = to 1.06 gallons, I often wondered why they set this up to use 4.1 gallons, probably where these are made they use the metric system. I guess that extra QT of oil will last me a long time!
  tire change Tom_imp 7 656 05-31-2021, 11:37 PM
Last Post: Tom_imp
  First oil change for this heathen koehlerk_imp 67 4,088 02-20-2021, 02:42 PM
  Oil Change interest? Scotty_imp 10 767 09-15-2020, 09:40 PM
  Oil Change Time! Jambo_imp 57 3,512 09-06-2020, 08:40 AM
Last Post: Jambo_imp
  Oil change before/after winter? HikerToo_imp 11 720 02-09-2019, 05:08 AM
  Oil Filter Change: Every oil change or every other? dbarkdoll_imp 22 1,134 04-17-2018, 12:46 AM
Last Post: Knave_imp
  Oil change questions... ride4now_imp 16 915 04-12-2018, 02:12 PM
  fork oil change Houtman_imp 4 350 03-12-2018, 08:46 PM
Last Post: Wisedrum
  First oil change SportsterDoc 30 1,988 11-28-2017, 09:24 AM
Last Post: SportsterDoc
  Completed second oil change (DIY) venturer434_imp 5 427 05-11-2017, 07:47 PM
Last Post: Rocky_imp
