oil change help
Hi
After watching how to do oil change, I decided to change oil today my bike has 700 miles bought the filter and Honda gn4 oil after installing the filter I put 2.5 liter and started the engine for 10 second and then realized I did not put enough oil so I put the whole 4 liter and started the engine for 2 minute and I cannot see any oil in the glass window I have been checking every 5 minute I hope I did not messed up please help Thanks
(12-07-2013, 10:34 AM)jay4252_imp Wrote: Hi
If you put Honda GN4 its sold by the gallon not liters in the US. You want to put the whole gallon ( 4qts) and your good to go. This bike is very hard to get a true reading. You may think your on level ground, reading from one side you can't see the oil turn the bike around the opposite direction and its full. I found a area that reads true after an oil change and check in that spot all the time A gallon of oil will fill the window.
You may be looking at a window full of oil. On my first change I put in the recommended 4 liters. When I checked, I couldn't see any oil. As it turns out, 4 liters will take the level to the very top of the window. The oil is so clean that you can't tell you're looking at oil in the window. I tilted the bike to the left and then I clearly saw the oil level drop in the window.
Another thing you could do is start the bike, let it run for a few seconds, shut it off, then watch the window. You should see the line of oil rise in the window as oil migrates down from the top of the engine into the crankcase.
Thank you so much for all your response, I hope I did not hurt the engine by running the engine for 10 or 20 seconds with only 2.5 liter oil, The dealers here wanted $130.00 for oil change
how to section help it cost only $35.00 dollar
Once again thanks for your help
(12-07-2013, 12:46 PM)jay4252_imp Wrote: Thank you so much for all your response, I hope I did not hurt the engine by running the engine for 10 or 20 seconds with only 2.5 liter oil, The dealers here wanted $130.00 for oil change
You can sleep good tonight because there is no way you hurt the engine with over half the capacity in it for 10-20 seconds.
Just a small point I want to confirm, is the bike on the center stand when you checked the oil level?
yes on the center stand a as level as you can get it .....Also that little slotted screw (on the inspection window) is for a wiper blade on the inspection window
Thanks for the reply
Bike is on the side stand , I try but for some reason I cannot put the bike in center stand, but when I did the oil change my neighbor help me put the bike in center stand I rode 20 miles yesterday I checked the oil window still I cannot see anything
Jay get your neighbor to come over and with you laying on your side on the oil site window side of the bike, shine a flash light on the site window, and have him lift the bike vertically to upright and then let it down again to the side stand. You should be able to see the oil rise and fall in the site window. The oil could be below the site window when on the side stand and above it when the bike is standing vertical. New oil is very clean and it might be hard to see. If you put 4 qts in there ( spec calls for 4.1 qts with filter) you should be good. At 4 qts mine was above the window a hair.
See pics below in post 1
http://cb1100forum.com/forum/showthread.php?tid=202
Jay I also posted a video which may help you when putting your bike up on the centerstand.
Rolleyes Buy one of these: http://www.autozone.com/autozone/accesso...70130_0_0_
I use one all the time. Sit on the bike, look with your mirror and if necessary lean a little so you can see the oil level.
  tire change Tom_imp 7 660 05-31-2021, 11:37 PM
Last Post: Tom_imp
  First oil change for this heathen koehlerk_imp 67 4,103 02-20-2021, 02:42 PM
  Oil Change interest? Scotty_imp 10 779 09-15-2020, 09:40 PM
  Oil Change Time! Jambo_imp 57 3,561 09-06-2020, 08:40 AM
Last Post: Jambo_imp
  Oil change before/after winter? HikerToo_imp 11 729 02-09-2019, 05:08 AM
  Oil Filter Change: Every oil change or every other? dbarkdoll_imp 22 1,147 04-17-2018, 12:46 AM
Last Post: Knave_imp
  Oil change questions... ride4now_imp 16 917 04-12-2018, 02:12 PM
  fork oil change Houtman_imp 4 357 03-12-2018, 08:46 PM
Last Post: Wisedrum
  First oil change SportsterDoc 30 2,002 11-28-2017, 09:24 AM
Last Post: SportsterDoc
  Completed second oil change (DIY) venturer434_imp 5 434 05-11-2017, 07:47 PM
Last Post: Rocky_imp
