Oil Consumption During Break-in?
I have learned not to trust the sight glass on my CB1100. Apparently the oil does not always flow back into the engine after turning it off at the same rate. I followed the instructions for checking the oil level in my owner's manual and I was shocked to discover the level was low (down to the lower level line) when I knew it was filled to the upper level line less than 200 miles earlier. I waited an additional 15 minutes to see if additional oil would drain into the engine (from the oil cooler?), but this never happened. I added enough oil to bring the level in the sight glass back up to the upper level line. After my next ride I rechecked the oil level (exactly as the manual defines), only to discover the lever is too high; the sight glass is completely covered. I haven't decided if it is worth draining the excess oil out or not yet.
I had a similar moment of panic not long after the 12,000km service. I checked the oil only to discover I couldn't see any. Got in a right state trying to find out exactly what the dealer out in it and got a litre so I could top it up. The service head at the dealer told me not to worry about it if I could even see oil in the bottom of the sight glass, but I stuck some more in any way.
I'm still wondering what's wrong with a dip stick.
(08-26-2014, 10:26 AM)Dave_imp Wrote: I have learned not to trust the sight glass on my CB1100. Apparently the oil does not always flow back into the engine after turning it off at the same rate. I followed the instructions for checking the oil level in my owner's manual and I was shocked to discover the level was low (down to the lower level line) when I knew it was filled to the upper level line less than 200 miles earlier. I waited an additional 15 minutes to see if additional oil would drain into the engine (from the oil cooler?), but this never happened. I added enough oil to bring the level in the sight glass back up to the upper level line. After my next ride I rechecked the oil level (exactly as the manual defines), only to discover the lever is too high; the sight glass is completely covered. I haven't decided if it is worth draining the excess oil out or not yet.
If you added more than 100ml or so then drain it. Better a little low, but visible in the sight glass, than over-full. You should heed the owners manual. DO NOT OVERFILL.
"Wet-sumping", caused by an overfill, is not good for an engine. Oil level a little low just reduces the margin in the event of oil loss. There seems to be no reason to suspect your bike has an oil leak. So relax. Read The ferrets post. It's good. I think, through the plonk haze, that Cormanus, on our last road trip, may have checked the oil level on my bike in the ferret approved manner.
Dave,
That seems pretty weird. Not to sound like you don't know, but you are checking it on the center stand, right?
(08-26-2014, 09:47 PM)Lord Popgun_imp Wrote: Dave,
Hi Popgun,
Yes, the bike was on level ground and on the center stand. I guess I'll have to look for the ferret's advice on checking oil.
(08-26-2014, 12:33 AM)The ferret_imp Wrote: Lol I never even look at mine between changes. Every once in a while i'll have some one straighten it off the sidestand while I stand back and see if I can see oil rise in the window and I always see oil coming up, so I'm good.
Just has to have oil between the marks.
Hi Popgun,
Hi Popgun,
STs are like that for some reason when you are doing an oil change. you run it and turn it off wait 3 mins and it looks low. So you throw 3 or 4 oz in. You take it for a ride and when you get back and check it, it looks over filled. Now, I just throw in a gallon at oil change time and trust oil is in there until the next change, except for the occasional tilt it up to see if oil runs up in the site glass. For better or worse that's what I do, but follow your own conscious when it comes to your personal ride. Now if I saw puddles under the bike or it looked like a crop duster as I rode down the road, I might take oil inspections more seriously, or is in the case of certain known oil burners like the CBR 1000 or some BMWs.
I do wish they would have put a dipstick in the 1100 like the old 750s. Its a minor pet peeve of mine. I mean what a couple of bucks more for a dipstick? Huh Seems every conceivable corner is cut these days and I mean on everything. Not fussing but just saying.
Guilty as charged also. I need to change oil now and have not even checked it since the last time I changed it. I hope it still has some in it! And I know better. Have had lots of oil burning cars in my youth that you had to check the gas and add oil weekly. When you finally get something decent the incentive to check the oil goes away because you get more confident and comfortable. At least that is my excuse.
(08-27-2014, 12:18 PM)OldF7Guy_imp Wrote: I do wish they would have put a dipstick in the 1100 like the old 750s. Its a minor pet peeve of mine. I mean what a couple of bucks more for a dipstick? Huh Seems every conceivable corner is cut these days and I mean on everything. Not fussing but just saying.
A shortcut? I dunno about that mate. What to do? Build a sight glass into the cover and fit a wiper or fit a dipstick. If the oil level is variable in the sight glass would it be just as variable on a dipstick? Maybe someone thought the sight glass was a better idea. Anyway either would seem to work.
Yep. Either works and bot are variable. But it's a PIA having to squat or kneel down to peer with ageing eyes at that bloody sight glass and not be sure what you're seeing. A dipstick is altogether easier to interpret.
So, in my humble opinion, the clown who thought of the sight glass was a dipstick. Big Grin
  What did I break? Cbcarolina_imp 4 401 12-03-2023, 10:44 PM
  High mileage and oil consumption Jurlie_imp 24 2,091 04-07-2023, 06:05 AM
  Engine break out tips and tricks ACE_IRA_imp 7 497 01-29-2019, 12:30 PM
  Engine break in test - recommended vs aggressive chync_imp 7 643 11-23-2018, 06:21 AM
  RANGE and BREAK IN Streetshark07_imp 9 798 11-15-2018, 03:02 PM
Last Post: Streetshark07_imp
  Break pads.....just in time....so eaaaaaasy!!!!!! jdvalero_imp 16 1,028 08-12-2018, 09:32 AM
  Clutch Cover Removal - How To Break Goo Seal ??? markT_imp 9 703 05-30-2018, 09:30 AM
Last Post: BayAreaRick_imp
  Oil Consumption dave 37 2,441 11-30-2016, 12:05 AM
Last Post: soggybottom_imp
  New Engine Break In zippooriginal_imp 3 333 07-12-2016, 01:47 PM
Last Post: riceburner_imp
  Break in oil? Fleetwood_imp 32 2,301 01-27-2014, 02:25 AM
