16,000 valve check
(01-27-2015, 11:34 PM)The ferret_imp Wrote: Were they loose and tight but still in spec? or did they replace 4 shims? if so did they charge you for the shims? if so how much? What was the charge for the valve adjustment?
If at all, by milage they should go tight, not loose. Anything else wouldn't make sense to me, looking at the mechanics.
  Valve Adjustment Shims dave 13 709 07-28-2026, 12:49 PM
Last Post: MagnaRider
  Valve Adjustment and Camshaft Removal dave 5 635 03-21-2026, 04:49 PM
Photo First Check Engine Light Ever on a Bike doug1976 2 235 01-14-2026, 06:47 PM
  Valve Adjustment dave 6 869 08-29-2025, 10:46 AM
  Valve Cover Baffle lining ? bflint 6 951 07-26-2025, 11:27 AM
Last Post: bflint
  Check your clips! Gone in 60 3 635 07-01-2025, 11:27 AM
  Valve Adjustment Intervals CBRider_imp 32 3,026 04-21-2025, 02:24 PM
Last Post: Jurlie_imp
  Basic Maintenance: Daily Check rdprdp01 17 1,421 03-01-2025, 02:52 AM
  Time to check the air cleaner! The A-man 6 685 08-22-2024, 09:39 AM
  Valve Adjustment Tolerances - How Far Do You Go? dave 14 1,547 10-18-2023, 09:28 PM
Last Post: The Gecko_imp
