Engine warning light after fitting Arrow Exhaust and TSR Intake Funnel
I have an update....
I spoke to the Tuning Shop today and they agreed that it wasn't right, but said that the instructions from Dynojet for the PCV only mentions one O2 Sensor. Fair doo's as Dyno only specify a PCV for 2013, which only has one sensor I think, right?
All the same, there was no quibbling and they are ordering me another O2 Eliminator. They are going to re-map FOC and just charging for a Fueling Check, which I'd need with the new pipe and TSR Air Funnels and Intake. £40 all in.
Very fair I thought.
He did say that the remaining sensor would only correct the fueling to emission friendly settings and it wouldn't do the engine any harm.
They also did the PAIR valve mod. as par the course, as he said you couldn't accurately measure for the mapping if it wasn't done.
Beardy,
Your are correct. The 2013s have only one O2 sensor.
Beirdy, did you also remove and plug the O2 sensors? I may be reading it incorrectly but it appears you only disconnected the O2 sensors and left them in. You really should remove and plug them, otherwise if you ever want to reuse them in the future they will probably be fouled to the point of failure. At around $200 a pop ($400 for the pair) that is a pretty expensive repair, especially compared to a simple bolt in plug.
I did leave them in, or rather the shop did. I only just realised we had them fitted to the bike when i removed the original exhaust. If I'd known I would have had them out, top tip. I would also then have realised that one was still connected!
This is the first modern bike I've owned that has such trickery.... And I'm still learning.
Photo First Check Engine Light Ever on a Bike doug1976 2 229 01-14-2026, 06:47 PM
  engine light tpo12001_imp 16 1,457 01-14-2026, 05:26 PM
  Could old/low battery trigger misfire and engine light? Motorsport3_imp 13 1,273 12-17-2023, 08:41 AM
Last Post: Jgarciajr40_imp
  Oil light turn on/off with hot engine Alessandro78Rome_imp 3 435 07-03-2023, 10:18 PM
  Arrow Slip on issue - stock gasket didn’t fit Ddawg1144_imp 4 468 02-21-2023, 07:51 AM
   Engine light Blinking tory_imp 25 1,828 12-04-2019, 10:38 PM
  H4 led replacement WARNING !!! Houtman_imp 9 725 10-10-2019, 09:07 PM
  check engine light stays on, on my 2017 Houtman_imp 51 3,453 07-27-2019, 01:27 PM
Last Post: itstuantran_imp
  Location of Engine Number on Engine? cb1100_dude_imp 2 334 05-29-2019, 01:44 PM
Last Post: cb1100_dude_imp
  Muffler Gasket for Arrow Slip-On CaptainChris_imp 10 763 05-01-2019, 04:54 PM
Last Post: Franksie_imp
