Interesting read on Final Drive Gear ratio's
Without dyno charts it's difficult to see what is happening with horsepower and torque and I notice they quoted horsepower at torque and not peak horsepower at a given rpm and peak torque at a given rpm. Changing sprockets just rearranges where the peak hp and torque numbers come in the rev zone.
When I raced motocross we had a stack of front and rear sprockets on a dowel for use at different tracks. If it was a tight track you geared it down, if it was an open track with long straightaways you geared it up. Find the right gearing for a particular track and you'd write it down so the next time you came to race you could concetrate on lines and not working to get the gearing right on the bike.
It's why MotoGP bikes have cassette type gear boxes. They have gear clusters already set up for each track which they have recorded from past races.
  Changing final gearing STLTHMSTA_imp 1 279 02-12-2023, 09:53 AM
  Front drive chain sprocket wear 1970Cadillac_imp 15 1,287 11-29-2022, 07:49 AM
  Interesting Maintenance YouTube Channel tommymck 4 434 09-10-2022, 03:14 AM
Last Post: alprider
  Interesting article on tire pressure the Ferret 9 847 11-28-2021, 04:23 AM
Last Post: j3gq_imp
  Drive Chain upkeep LakeWylieJoe_imp 18 1,160 05-20-2020, 01:36 AM
  Checking Drive Chain Slack Townie_imp 26 1,863 01-15-2020, 11:14 PM
Last Post: cocojamboo_imp
  Read Wheel Alignment Symptons activedirt_imp 6 504 06-19-2018, 12:46 PM
Last Post: jimgl3_imp
  interesting conversation about draining oil the Ferret 68 4,075 11-06-2017, 09:58 AM
Last Post: Ole
  How to read fault code Jeya_imp 4 405 11-01-2017, 05:09 AM
  Drive chain replacement time, probably. Rolls_imp 34 2,112 06-02-2016, 12:59 PM
Last Post: flynrider
