05-16-2016, 10:35 PM
would like to see it too
Crankshaft Balancer backlash adjustment screw
05-17-2016, 12:34 AM
(05-16-2016, 08:04 AM)Speed_imp Wrote: Usually gears don't wear that much they need to be adjusted. I think it is there because it's easier and cheaper to machine the housing for the balancer shaft at the aproximated distance (less accuracy in the machining - cheaper and faster) and then make the final adjustment manually when all the parts are assembled. Then you can achieve a perfect adjustment, cheaper machining and in adition you can adjust it again after the wear caused by kilometers Thanks Speed, This makes sense to me now, cheaper and faster always wins out. (05-16-2016, 08:29 AM)Pterodactyl_imp Wrote:(05-14-2016, 11:08 AM)tomas_imp Wrote: Can anybody explain why this bike has a Crankshaft Balancer backlash adjustment screw? This is the first bike I came across that uses one, and I understand why we have to adjust it. But why doesn't the crankshaft stay balanced? Why does it come out of adjustment? Why don't other bikes use them? It seems like Honda is cutting corners with this adjustment screw, because they couldn't figure how to keep it balanced without us having to do periodically . Tomas, that's not correct. Other manufacturers and bikes have crankshaft balancing adjustment mechanisms. Suzuki on the Hyabusa, for instance. Kwaka KLR650 is another. Cheers FJR1300 as well. Didn't know that, I guess I should have said, that I never seen this technique use on 70's & 80's model motorcycles.
05-17-2016, 07:28 AM
FWIW, the Honda Blackbird has dual balancers and the engine is dead smooth. I'd imagine that Honda could have given the CB1100 dual balancers but then it'd be too smooth, so a single balance shaft is enough to awaken rose-colored memories but not enough that hands would get tired of holding on to buzzing handlebars...
FWIW #2 my Blackbird has 75,000 miles on it, never felt the need to touch the balancer adjusters (the cam chain tensioner is a whole different story :-( ). |
« Next Oldest | Next Newest »
| Valve Adjustment Shims | dave | 13 | 659 |
07-28-2026, 12:49 PM Last Post: MagnaRider |
| JIS screw drivers | Ridem32_imp | 26 | 1,644 |
06-12-2026, 06:56 PM Last Post: Gone in 60 |
| Valve Adjustment and Camshaft Removal | dave | 5 | 610 |
03-21-2026, 04:49 PM Last Post: Cormanus |
| Valve Adjustment | dave | 6 | 851 |
08-29-2025, 10:46 AM Last Post: dave |
| Valve Adjustment Intervals | CBRider_imp | 32 | 2,793 |
04-21-2025, 02:24 PM Last Post: Jurlie_imp |
| Rear Brake Pedal Adjustment | Gone in 60 | 12 | 1,107 |
04-04-2024, 08:18 AM Last Post: Gone in 60 |
| Sight Glass Screw | Mickey Dublin_imp | 16 | 1,505 |
11-22-2023, 08:25 AM Last Post: peterbaron |
| Valve Adjustment Tolerances - How Far Do You Go? | dave | 14 | 1,476 |
10-18-2023, 09:28 PM Last Post: The Gecko_imp |
| Should I adjust my crank balancer? | DutchRutter | 16 | 1,200 |
05-29-2022, 07:39 AM Last Post: DutchRutter |
| Front forks adjustment | Olyrider | 5 | 479 |
05-16-2022, 11:04 PM Last Post: Sparky80_imp |
